01-16-2021, 02:54 PM | #1 |
Rep 78
Fine tuning auto parking/park assist thru coding
Sometimes the car goes extremely close - that the tyre hits the kerb if the kerb is really low. I saw a few settings in the PDC module which define the length/width/height of the car and was wondering if the auto park assist system uses these values to park the car. Maybe i could extend the width/length of the car to allow more breathing space and make it less of a snug fit when it auto parks?
Anyone tried changing these values to see if it makes a diff? Last edited by dreamtheater39; 01-16-2021 at 03:06 PM.. |
01-16-2021, 03:47 PM | #2 |
Rep 2,046
Drives: X3 G01 30i xDrive
As fair as I know, PDC uses cars to measure the parking space a place. Maybe changing the length value can make a difference, where the assist to park in tighter spots.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
01-17-2021, 11:27 AM | #4 |
New member
318
Rep 553
I don't know if this could work--I have never played with the settings that pertain to the physical characteristics of the vehicle. I am worried that I don't properly understand these settings. They could be used by multiple ECUs and functions, not only the parking assistant. For example, the comment for the CAR_LENGTH option in KAFAS reads "The vehicle length. NOTE: This parameter is used by the environment model (UFM) as well. Changes in format of value have to be checked with the responsible person first."
If you are brave enough, you can try changing the options you found and test if they affect PDC. If you don't see an immediate effect, code them back the way they were. If you see an effect, you should still carefully test other functions to make sure they were not adversely affected. But my recommendation is to leave them alone. You are likely playing with fire. |
01-17-2021, 12:44 PM | #5 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3546
Rep 4,230
01-17-2021, 11:07 PM | #6 | ||
Rep 78
Thanks for the detailed response and averting a potential disaster! Quote:
01-18-2021, 09:37 AM | #7 | |
Rep 1,044
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
Tags |
assist, park, pdc |
