01-16-2021, 11:40 PM | #1 |
Rep 40
Drives: BMW X3, Mazda 3
Wheel balancing issue Australia
Hello All
Recently, I felt a bit of vibration coming through the steering wheel and floorboard. Usually happens when I am travelling at speeds more than 80km/hr. My car is 2018 X3 30D. I had a quick look at the front wheel weights and was surprised to find that the passenger side wheel has one long piece of weight in the outer rim and drivers side has two small ones (one outer and one inner rim). I am running 254/45/R20 run-flats. Is this normal? Because I assumed both wheels should have identical weights. The car has done 22,000kms and I guess it is time for a rebalance. Do you recommend going back to BMW or somewhere like Bridgestone select or Beaurepairs? |
01-17-2021, 01:43 AM | #2 |
ANM8
87
Rep 189
There's nothing strange about having different balancing weights on the same axle wheels, just because they're the same wheel doesn't make any difference when balancing. When a tyre is produced they put a yellow marking dot on the sidewall of the tyre that denotes its lightest point (it's almost impossible to produce a perfectly balanced tyre) this yellow dot is then lined up with the valve stem when fitting the tyre on the alloy (considered the wheel's heaviest point)
Your car does sound as though it needs to be rebalanced though. https://www.toyotires.com.au/news/se...cing%20weights. Last edited by ANM8; 01-17-2021 at 04:13 AM.. |
01-17-2021, 05:11 AM | #3 | |
Rep 40
Thank you for a detailed answer. In addition to my question above, what is interesting is that a local tyre shop recently took off my front wheel (tyre +rim) to try out an aftermarket rim and tyre. The original wheel was not touched and was only taken off and put to the side. I took a test drive with the new wheel and tyre before I bought it. I got the store to put the original wheel and tyre back on. What is strange is that I started noticing that slight vibration after that day. Is this a coincidence? I cannot see why taking off the wheel would cause it lose its balance. |
01-17-2021, 05:25 AM | #4 | |
Rep 912
01-17-2021, 07:10 AM | #5 |
Rep 40
Thanks for that. I hope it is just that. I just went for a drive and went up to 100km/hr and can definitely feel the vibration. It will be uncomfortable during long drives. I will check and see if my service advisor is nice enough to accommodate me tomorrow and will report back
01-17-2021, 07:58 AM | #6 | |
Rep 912
01-17-2021, 09:34 AM | #7 |
Rep 383
Drives: 2023 BMW X3M40 1984 911 TARGA
Every wheel/tire would require different amount of weights. Don't understand your statement-"Is this normal? Because I assumed both wheels should have identical weights"
Is this your first car?
2023 X3 M40I 2018 X3 30i M Sport
2011 550i 2005 325i 1985 535I 2017 F150 2016 GS 2004 545i 1994 525I 1984 911 TARGA 2014 HD ULTRA |
01-17-2021, 11:15 AM | #8 | |
Rep 1,046
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
01-17-2021, 12:11 PM | #9 |
Rep 383
Absolutely!
01-17-2021, 04:19 PM | #10 | |
Rep 40
Thank you for your reply. Not my first car but certainly the first time I have encountered this. Never really had to deal with an issue like this before. But your answer makes sense and I will get it checked out. |
01-17-2021, 04:24 PM | #11 | |
Rep 40
Thank you for your reply. The tyre and rim were just dismounted and mounted. It was not rotated and the tyre never came off the original rim. I am guessing a weight might have come off the rim, as you mentioned. I will get my dealer to have a look today, if possible. Thank you very much for your guidance |
01-17-2021, 04:43 PM | #12 | |
Rep 15,858
Balance should not have changed simply on a wheel being taken off and put on again. |
01-18-2021, 04:35 AM | #13 |
Rep 40
Thanks Pete. I am booked in for next week at BMW dealer. Have another issue that I would like the dealer to look at. But on my way back from work, I stopped by at a local tyre shop and they checked the torque on the wheel nuts and had to tighten two with 140Nm torque wrench. Lets see how this pans out over the week.
01-20-2021, 07:57 AM | #14 | |
Rep 40
Got my only my front tyres balanced at Tyrepower and was told that front passenger side was way off balance. Strangely, this was not the tyre+wheel that was taken off when I was getting a spare wheel+ tyre. Anyway, the car drives much better but there still a bit of vibration above 80km/hr. I am thinking about taking it back and ask them to balance them again. This time, I might ask them to do the rear tyres as well. Do you think that is necessary given that the vibration is felt through steering wheel and floorboard? |
01-20-2021, 03:06 PM | #15 |
Rep 2,046
Drives: X3 G01 30i xDrive
I would have checked all tyres in the case of a vibration like you have. Especially when one of them was already way off.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
01-20-2021, 04:12 PM | #16 |
Rep 40
01-20-2021, 05:15 PM | #17 | |
Rep 1,645
Definitely get all four wheels re-balanced. IIRC issues with wheel balance usually occur at a particular speed range. Does your vibration smooth out say at 100kmh? Or does it keep going? If it keeps going it might be another problem, but anyway get all the wheels balanced first. Are any of your wheels slightly dented (even on the inner part of the rim)? Good luck!
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
01-22-2021, 06:27 AM | #18 | |
Rep 40
Thank you for your replies. Got all my wheels balanced and both rear ones were out of balance as well. Unfortunately, again the drive is a bit better but beyond 80km/hr, there is a slight vibration. It is annoying enough to get my attention. I have an appointment on Monday at Auto Classics to do a test drive with the SA. The vibration does not smooth out with increasing speed. Under 80km/hr, there are no issues, but beyond that I can definitely feel it. No damage to the rims that i know of. Tyrepower also did not report any any issues with either rim or tyre. I am at loss. Looking at other threads, this seems like a major issue with 2018 G01 X3s. |
01-22-2021, 09:26 AM | #19 |
Rep 1,046
I didn't see that you had a 2018. Here's your problem. BMW bought my 2018 back last year because of the problem. Some earlier 2018s were plagued by this issue.
https://x3.xbimmers.com/forums/showt...heel+vibration
01-22-2021, 06:22 PM | #20 | |
Rep 40
01-27-2021, 07:48 AM | #21 |
Rep 40
Hi
Another update. Took my car to the dealer and went for a test drive with the foreman on Monday. He agreed that vibration is definitely there. Went and dropped my car off on Wednesday and SA was confident that they will have me sorted by end of the day. Went to pick up the car in the evening and was told they rebalanced all four wheels again because they were out. I was assured that the issue has now been resolved. But funny enough, they did not charge me because they wanted me to drive the car first for a while and make sure I was happy. Just went for an hour drive at different speeds from 80km/hr to 110 km/hr and the issue is still there (no surprise there!). I have now emailed the SA and hopefully get this sorted. Am I overreacting by thinking about just selling the car and be done with it? |
01-27-2021, 12:38 PM | #22 |
Rep 1,046
If it's still under warranty, let them try to fix it. Changing the axles did help with my problem although it didn't completely solve the problem. Then think about selling it. If you read the thread, a number of cars that had the axles replaced had the problem recur after a few thousand miles.
