01-28-2021, 03:26 PM | #1 |
Jumping Jack Flash
324
Rep 1,692
Drives: 2021 X3 M40i
Battery charger for 2021 X3 M40i
I use a CTEK Multi US 7002 charger for my 2011 335d. It sits in the garage a lot. Just a few minutes ago I felt the temperature on the 335d unit and it is cool (but working fine).
I have two of the 7002 chargers, and so I have hooked up the other one to my 2021 X3 M40i. I have noticed two things: the charger unit is running a bit warm and the charger doesn't seem to want to reach steady state (green LED). Something is obviously amiss, but not sure what other than the 7002 is not up to the task. Any of you USA-based people have a recommendation for a good charger for the X3, CTEK or otherwise. Supposedly it is an 80aH battery, but am not sure about that.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
01-28-2021, 03:45 PM | #3 |
Rep 287
I've had this issue as well for both my 7002 and 4.3 Ctek chargers. I just unplug the charger and cables. Then reconnect and restart. I had no issues after doing this. I think the chargers need to reset/reboot the circuitry. Try and see if that works before replacing the unit.
335dFan323.50 |
01-28-2021, 06:48 PM | #4 | |
Jumping Jack Flash
324
Rep 1,692
I did try the unplug charger and cables trick you mentioned. So far it hasn't seemed to make any difference. But I am patient and the unit isn't horribly hot. Update #1: OK, patience paid off. It has now moved off light #2 (where the voltage applied his highest) to light #3 and the unit has cooled down a bit. I bet before bedtime tonight it will be into the green mode.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. Last edited by 335dFan; 01-28-2021 at 07:18 PM.. |
01-28-2021, 10:05 PM | #5 |
Photojournalist, Tech & Product Analyst
521
Rep 474
Do you have the charger set to AGM (the snowflake)? Also, it is possible even though your car is new, the battery may never have had a full charge. This is especially true if you have only done short trips in it since bringing it home.
Current:2024 i4 Mineral White Metallic with Blue Exterior Accents, Canberra Beige Perforated SensaTec, Premium Package, Driving Assistance Pro Package, Drive Recorder. 2019 X3 Mineral White Metallic, Caberra Beige interior with most options. Corvette Stingray Arctic White w red interior.
Past:2002 Z3, Corvette Stingray and about 40 other cars |
335dFan323.50 |
01-28-2021, 10:14 PM | #6 | |
Jumping Jack Flash
324
Rep 1,692
If the weather would let up a bit I would like to take it for a longer drive. Right now I'm treating it with kid gloves.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. Last edited by 335dFan; 01-28-2021 at 10:21 PM.. |
01-29-2021, 10:47 AM | #8 |
Jumping Jack Flash
324
Rep 1,692
Success! Thanks.
JDsX3520.50 |
01-29-2021, 10:59 AM | #9 |
Jumping Jack Flash
324
Rep 1,692
Some of you may be interested in seeing the California regulation insert in my manual. I bought my first device in Maryland and the second in California. I never noticed the California insert before today, nor the table shown AGM for snowflake. So thanks for that.
But in my defense, I didn't even realize the battery was AGM. Where on the car (short of unpacking it in the back) or in any documentation does it give the tech specs for the battery? I looked.
01-29-2021, 04:45 PM | #10 |
Rep 317
I checked the forum stickie Technical Information Documentation > Voltage Supply and Bus Systems and in the battery section specifies the agm battery. Hope this helps.
01-29-2021, 04:56 PM | #11 |
Jumping Jack Flash
324
Rep 1,692
Interesting. This is the only document that I somehow had not downloaded. I seem to be losing my attention to detail. Thanks.
01-29-2021, 05:18 PM | #12 |
Rep 15,858
01-29-2021, 06:01 PM | #13 | |
Rep 1,912
01-29-2021, 07:00 PM | #14 |
Jumping Jack Flash
324
Rep 1,692
Am pretty sure my 2011 335d battery is lead acid too.
01-29-2021, 08:08 PM | #15 | |
Car guy
1041
Rep 1,323
01-29-2021, 09:54 PM | #17 |
Rep 1,046
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
My 2012 X3 35i was AGM.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
01-30-2021, 03:43 AM | #18 | |
Rep 15,858
I guess some of the introduction was market specific, the E83 model X3's had AGM in the UK. Even some E46 3-series had AGM. |
01-30-2021, 05:57 AM | #19 | |
Cailín gan eagla.
72101
Rep 1,008
I get a new one every three to four years or so. I'm due this Summer. Last edited by Lady Jane; 01-06-2022 at 05:11 PM.. |
01-30-2021, 09:57 AM | #20 |
Rep 1,912
interesting, my car has normally aspirated N52 motor....Perhaps that is reason it had lead acid battery? hard at times to tell the logic the Germans actions.
01-30-2021, 12:43 PM | #21 | |
Car guy
1041
Rep 1,323
01-30-2021, 12:56 PM | #22 | |
Jumping Jack Flash
324
Rep 1,692
Lady Jane72100.50 |
