02-01-2021, 04:40 PM | #1 |
Rep 34
wife's keyfob keeps bringing up my driver profile
Everything worked just fine until this morning: whenever I opened the car with my fob, the seat and everything else would adjust for me. Whenever she drove the car, it would adjust for her.
This morning every time she enters the car, it brings up my driver profile. She changes to her profile -- which doesn't adjust the seats anymore -- then adjusts everything, drives, gets out, locks the car, comes back an hour later and my name still pops up. What gives? Me and my key have been nowhere near the car. Is there a way to more permanently tie the profile to the fob used for the future? |
02-02-2021, 02:39 AM | #3 | |
Rep 912
If you car has ID7, try if not already done so, setting up a separate connected drive account for each driver/driver profile and and re-associate each key to each profile. For ID5/6 cars try deleting profile, re-creating profile and re-associating keys to profiles. If this does not solve then you can reset HU (in privacy, deleting personal data resets HU to factory default). Last edited by MJE60; 02-02-2021 at 04:47 PM.. Reason: Avoid confusion between ID7 and ID5/6 |
02-02-2021, 09:24 AM | #4 | ||
Rep 2,046
Drives: X3 G01 30i xDrive
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
02-02-2021, 11:08 AM | #5 | |
Rep 912
Well, for a start, having a connected drive account means your settings are saved and you can get in any modern BMW, enter your account and your profile gets put in the car. BMW saves your profile to your connected drive account. My point is that it is well documented that problems with getting cars to load profiles, remember them and keep settings can be improved by creating two connected drive accounts. A car key can be assigned to a driver profile but if multiple profile are saved to only one connected drive account in a car this is where problems can sometimes occur, hence setting up an account for each driver/profile. Last edited by MJE60; 02-02-2021 at 04:41 PM.. |
02-02-2021, 12:13 PM | #6 | |
Rep 2,046
If there is something wrong with key a driver profiles, then recreating that profile (delete/make a new one) in the car and associate it with the desired key fob should be enough I guess. I really don't see how connected drive can be involved in this. Edit:can you add more connected accounts in iDrive? I have only one (1) connected drive account, and two (2) iDrive profiles. Didn't have a problem during my ownership.
MJE60681.00 |
02-02-2021, 02:00 PM | #7 | |
Rep 912
02-02-2021, 03:24 PM | #8 | ||
Rep 2,046
02-02-2021, 03:36 PM | #9 | |
Rep 912
When you create a connected drive account, you can link a car/s to this account, this allow you to buy connected services and it also saves your drivers profile (using email address as account Id).. If you link another car to your connected drive account or log-in into connected drive in a different car via the iDrive, it downloads your saved profile into the new car. This driver profile back-up between idrive and connected drive appears to help prevent profile settings from being lost in a car (which can happen when two or more profiles are sharing a car), hence the value of each driver opening a connected drive account. In some iDrives it now specifically asks if you to log-in to your connected drive account within profile management (if you do not have one it will create it), otherwise the link is automatic when the car VIN is added to the connected drive account. Last edited by MJE60; 02-02-2021 at 04:49 PM.. Reason: Avoid confusion between ID7 and ID 5/6 |
02-02-2021, 04:03 PM | #10 |
Rep 2,046
I don't have anything like that in my manual. MY18 X3 G01 with ID6.
02-02-2021, 04:13 PM | #11 |
Rep 912
O.k that is useful to know, I did not realise this was an ID7 only facility, not having had ID6. I knew it was not available in F series cars but incorrectly assumed it was a feature in G series (having seen it in some other new G series).. Apologies for any confusion caused, I will try and update the post/thread to make clearer and avoid crating confusion. Thanks
