02-16-2021, 08:51 AM | #1 |
Rep 34
List of Problems I had - M340i
I guess my friend is right. Never buy a first year production model. Too many teething problems with software and the likes. In no particular order... and thank goodness for warranty.
1. Car refused to unlock / lock. Only way to unlock was using the connected app. Car would not start. Both keys defunct. BMW Assist called out but no joy. Car lifted / towed away from drive by BMW. Solution: Ring antenna replaced, receiver replaced and, two new keys registered to the car. 2. Bass Cut Issue on Harman Kardon. Randomly bass would disappear from music. Solution: PUMA for this. RAM Booster Replaced. 3. Virtual / Live Cockpit went blank driving. Would sometimes flicker. Intermittently turn on / off. Solution: Software Update. 4. Auto-hold stuck on. Solution: Switch / Control Panel Replaced. 5. Apple Car Play. Music would skip, stop and, fast forward by itself. Solution: Software Update. 6. Mirrors would not fold despite option being selected to fold on lock. Eventually the mirror stopped unfolding. Solution: Driver mirror motor replaced. 7. Active Grill stopped working. Solution: Grill motor(s) replaced. 8. High-beam assist not activated above 40 mph on laser lights. Solution: Software update. 9. Parking Assist Failure. Solution: Park Assist Module replaced. 10. Cruise Control stopped working. Solution: Software Update After a year of bawl ache. I have decided to ditch the G20 and head back to a 4 Gran Coupe. A 440i to be precise. It's tried and tested tech. My initial worries were that the something might happen such as the iDrive being stolen or the steering being taken in the dead of the night but it's a risk worth taking. I remember a lot of stuff on how to work on the F3X platform when New Tis Info was open source. I had an F30 and F32. Then an F32 and F36. So I know about some of the issues and how to work on the cars, code them etc. The G20 is a great looker in my view, a pretty sweet ride in terms of improved handling but it is not a massive step forward. I guess it will be like marmite to some. I drew the line when I could not unlock/start my own car and think if it had been an emergency... well thankfully, I have a Mercedes E400d to fall back on. I think I will wait for the issues to be ironed out... once all the G20 issues are known/addressed then I may venture back into it. This thread is for awareness. I am not claiming "watch out" or "don't buy" and may be it was a Friday afternoon car in my case. In total it spent more than 33 days off the road and in the service bay. It worked out as roughly a visit a month and I got to know the Technician on a name basis. Last edited by LineBacker; 02-16-2021 at 09:25 AM.. |
02-16-2021, 09:02 AM | #2 |
Rep 246
Wow it seems you have had a lemon! I've been living with a G21 340i and had very few issues so far, mostly trivial (or user error), so not bothered to to get the car in to have anything looked at.
02-16-2021, 09:22 AM | #3 |
Rep 326
Obviously just one of those cars, mine was an early production run and not had one problem in over 10,000 miles.
02-16-2021, 09:23 AM | #4 |
Rep 8,115
Sorry to hear of your troubles but I guess it’s possible, given volume, to find similar stories regarding any manufacturer and any model. Generally all the BMW I have had were reliable but the F31 was so horrendous in terms of NVH, it was with a bit of trepidation that I ordered my G21.
02-16-2021, 09:29 AM | #5 |
Rep 34
To it’s credit NVH was not an issue. The acoustic glass works well. The sports gear thud was pleasant rather than a jolt. Nothing rattled in the interior. The cabin was well soundproofed other than the artificial engine notes being played in the speakers. Agreed it was a lemon of biblical proportions. What’s lemon car in German? Zitronenauto.
02-16-2021, 09:36 AM | #6 |
939
Rep 4,329
Drives: M340
Mine is a July 2019 production and it has been 100% trouble free so far for 15K miles.
As much as the car, it can possibly be your dealer as well continuing to mess things up. I think these days with quality controls in place, 1st year production myth is quite over. One can always get a bad car but I would not avoid a vehicle just bec when it was produced. We still own a 2002 Mini Cooper S which clearly as the very 1st year of Mini. It has ben 100% trouble free, I also owned a 2007 E92 335 which was a great car as well. I think, you might have a lemon but glad to hear, you found a way out of it.
02-16-2021, 01:14 PM | #7 |
Rep 34
That’s a good point on the dealer messing things up. No doubt the techs have had training but it’s new to them in a way. Everything was going back and forth to Germany. So it took longer. Of course HQ would be interested in problems with their newest model. The procedures for service are new too and slightly more expensive. Apparently the oil change is a bit like Mercedes where the oil is sucked out of the engine/drained. It’s a shame. I think it would make a cracking motor if it weren’t for the issues. As said I will hold for the LCi and if it’s not beaver like then I might attempt it again.
02-16-2021, 01:16 PM | #8 | |
Rep 34
02-16-2021, 08:17 PM | #9 |
Rep 2,699
Drives: 23 X5MC
2020 M340 since August 2019. Only a few niggles. Worst issue was side mirrors , fixed with software update
02-17-2021, 02:44 AM | #10 |
Rep 246
May all your problems be little ones! My biggest issue in the G21 is the 12V socket isnt live so I cant run my dashcam.
One month in and just loving it tbh. Almost got the hang of all the gadgets and software. Just need a dry day to test out the launch control Totally disabled CarPlay now and life is settling down. THat thing was a nice idea but totally takes over the dash. Hated it. regards Neil |
02-26-2021, 02:53 PM | #12 |
Romanian Spy
64
Rep 144
Out of all of these, I can only say the bass cut out happened to me twice and I have 12k miles on the car. Hope you got all the little gremlins out of it!
03-08-2021, 02:53 PM | #13 |
Rep 193
Faults (and observations) with my M340i...
1) Squeaking / creaking sunroof 2) Apple CarPlay maps (both Apple and Google) and WhatsApp don’t work - most of the map displays just show small grid lines with no map detail and WhatsApp doesn’t show messages 3) Annoying notification after every startup saying an app is available for an iPod Touch (which actually is NOT available in the App Store) - why does BMW assume people don’t just want to leave iPods permanently plugged in under the front armrest? 4) Misaligned steering wheel (sorted in under ten minutes by local independent garage adjusting the tie rods) - I knew it would be pointless asking the fitters (rather than proper mechanics) BMW dealers employ as they would doubtless have said it couldn’t be done because of all the driver assistance system nonsense. Needless to say, adjustments were done, wheel was straightened, car still tracks dead straight (ties rods wouldn’t affect that anyway) and no warning lights about Lane Assistance (not that I ever have any such systems switched on anyway!) 5) Harman Kardon Surround Sound is much more hollow and boomy sounding than the H-K system I had in my 2018 440i Coupe 6) Sport program for transmission has seemingly been recalibrated and seems to “hang onto gears” (more than same gearbox in my old 440i) and produce silly mock “heel and toe” manual gearbox downchange sounds (again, same setting in my 440i didn’t produce the same theatrics) 7) Cerium Grey is two different colours on the mirror housings and wheels which seems very strange After a completely trouble free time with my 2018 440i, I am a bit disappointed with the M340i. |
03-09-2021, 03:02 AM | #14 |
Rep 343
Item 2 is because your phone is logging onto the car's wifi hotspot and hence doesn't have any data to show the maps etc.
Make sure internet check box is unticked in the car settings. If it is then delete and reinstall your phone. The clue is on the carplay screen do you see a wifi symbol or 3G/4G. Wifi symbol means it is using the car's hotspot. |
03-09-2021, 04:38 AM | #15 | |
Rep 193
Clearly the way the connected device is labelled on the iPhone’s “Settings - About” menu is crucial and the car really only likes devices to be described in very generic terms i.e. “iPhone X” rather than trying to show who’s phone it is! Last edited by NthKent; 03-09-2021 at 07:47 AM.. |
03-09-2021, 10:53 AM | #16 |
Rep 343
Glad it helped, it was driving me batty. I have to repair it once again since as it happened again. I changed my phone name but kept my name in it as it is useful for some other bits I do.
03-09-2021, 11:03 AM | #17 |
Rep 193
The trouble with IT developers is that they always expect end users to have far more basic knowledge about what, of course, seems obvious to those who developed the software but really really isn’t in the real world!
10-25-2021, 09:58 AM | #18 |
Rep 142
Hi NthKent - did you manage to get your sunroof fixed and if so was it an easy fix ? That's just about the only complaint I've got with my M340i after 17 months, and I've got a walk-in appointment this Thursday for them to look at it. No doubt they will say I need to take it back another time and leave it for 2 days ! |
10-25-2021, 02:26 PM | #19 |
Rep 935
Not had any of those problems.
In the past, I had no problems with the supposedly problematic e60/61 and plenty of problems with the supposedly trouble free e39.
10-25-2021, 02:42 PM | #20 |
Rep 391
Think I'm on maybe 14 new BMWs now and the only issue I've ever had was on a G20, windows stopped working and the mirrors wouldn't retract! Good fun trying to get a ticket at a car park barrier...
Started working again before I got it to a dealer! |
10-27-2021, 01:07 AM | #21 | |
Old Member
65
Rep 196
Drives: M340i, Mineral White
I have had a few BMWs since my first E46 in Jan 1999. The only one that has had problems was my 2007 E90 335i. Brake squeak when moving off after being at a stop, and an I-Drive problem with the Navi GPS thinking it was 300km away from where the car was. That was easily fixed, the brake squeak need I think 4 service visits. Since then a 2012 335i, a 2015 428i GC, a 2017 335i and now a 2020 M340i. And my wife is on to her 5th 1 series since 2005..none have had any issues. Maybe we are just lucky...and I do sympathize with those that have had far too many problems. |
10-27-2021, 04:01 AM | #22 | |
Rep 391
No cars are perfect but in general it's not just a case of paying for the badge with BMWs
Current: G20 320d xDrive F22 M240i
Previous: Many, many boring BMWs, 116d (F20), 220d, M240i (F22), 318d (F30), 320d (F30 and G20), 330e (G20), 420i (F32), 420d (F32), 435d GC (F36) |
