02-21-2021, 03:29 AM | #1 |
Rep 120
2020-4 latest maps - issue Europe/UK
Posted in the UK forum too but will ask here incase anyone in Europe also having same issue. Just wondering if anyone else has downloaded the latest maps for their car and installed them with no issues? 2020-4 series of maps
Installed mine and now the Sat Nav is stuck in a loop. Tried the 30 second hold of power button to completely restart the idrive but still doing this. Rest of the idrive is working fine. Software wise I'm on 07/2020 Vid of said issue |
02-21-2021, 07:23 AM | #2 | |
Rep 1,182
04-01-2021, 02:37 AM | #7 |
Rep 2,250
They need to get a set of FSC codes for your head unit - for whatever reason the one for navigation is most likely in a "rejected" state. Do you have esys, or know someone that does? They will be able to tell in a few minutes. There's a few on here that can do it remotely as well if you have a cable
04-01-2021, 05:33 AM | #8 | |
Rep 120
04-01-2021, 06:46 AM | #9 |
Rep 2,250
04-01-2021, 07:23 AM | #10 |
Rep 120
Going to have a go now, I've got backups of all the coding etc from 1st March when it came back from dealer and was working then. Looking on my Head unit FSC on Bimmercode everything is "Unknown" followed by a string of numbers and letters. Some show available, some show not available. Have the option to write, read and check. Not sure which one is the maps
04-01-2021, 09:37 AM | #11 |
Rep 2,250
For idrive 7, here's the id's I can find online.
f AppID 369 (0x171) - TouchCommand AppID 370 (0x172) - Navi Professional Application Asia AppID 371 (0x173) - Navi Professional Applikation RoW AppID 374 (0x176) - Diagnostic Log and Trace External AppID 375 (0x177) - Diagnostic Log and Trace Internal AppID 424 (0x1A8) - Deactivate IPsec to Kombi ATM AppID 379 (0x17B) - CarPlay AppID 381 (0x17D) - SpeechAppRow AppID 382 (0x17E) - SpeechAppChina AppID 400 (0x190) - MGU Navi Business Applikation Asia AppID 401 (0x191) - MGU Navi Business Application RoW AppID 423 (0x1A7) - Deactivate IPsec to Kombi AppID 426 (0x1AA) - Component Protection AppID 446 (0x1BE) - MGU SXM Connected AppID 342 (0x156) - Road Map NORTH AMERICA Live AppID 347 (0x15B) - Road Map SOUTHEAST ASIA Live AppID 353 (0x161) - Road Map CHINA Live You will have "Road Map Europe Live" - I dont know the appid for that but it will likely be somewhere between 340 and 360 |
04-01-2021, 09:41 AM | #12 |
Rep 2,250
appid 426 is the important one here - if this is status rejected, component protection has been activated, which will mean the dealer will need to get FSC codes off AOS to fix.
04-01-2021, 10:04 AM | #13 | |
Rep 120
04-01-2021, 12:13 PM | #14 | ||
Rep 2,250
0x17E= 017E0001 for example. I would expect more than 3 accepted codes for your head unit though, definitely goes towards the codes getting borked up. This is definitely something a dealer should be able to sort though, they can request the full set of codes for a vehicle through their after sales portal, or failing that they can raise a case with Munich who will connect remote to diagnose the issue. If your dealer isn't being helpful I suggest try a different retailer ( not sure where in the country you are !) |
04-01-2021, 02:00 PM | #15 | |
Rep 120
04-01-2021, 02:05 PM | #16 | ||
Rep 2,250
Software update will update ecu firmware, but it won't change the activation codes - they are unaffected by the flash ( think how on your iPhone/android , your apps don't get changed when you get an OS update). Only other option really is a bad Hardware, but should be covered by warranty |
04-01-2021, 03:16 PM | #17 | |
Rep 120
Oh it's covered by warranty, just a pain going to/from dealer all the time. I want to go in with as much info as possible this time, and definitely make sure everything gets done! Going to try a USB C memory stick for a final attempt at a map reload. Try a different port. Anything hah |
