02-24-2021, 11:14 AM | #1 |
Rep 4
Audio question
Hi,
My first post on here, "Hello" I recently took delivery of a 2020 G02 This has the U.K. base audio system, couldn't find what I wanted with HK fitted. I've read a lot of threads on audio upgrades on this forum, picked up some good info, but have a few questions I'm planning on upgrading the subs along with the front door speakers (with additional tweeters) My base system has no amp, if it had an amp in the rear of the car, then upgrade would be relatively simple. As there is no amp, I'm unsure where the wiring for the audio is routed, is there a resource that will show that or can somebody tell me if the audio wiring runs through the rear of the car? I'm really pleased with the car, but I came from a 2008 Ford mondeo, so tat really is "night and day" Many thanks Tony |
02-24-2021, 12:25 PM | #2 | |
Rep 2,250
02-24-2021, 12:34 PM | #3 |
Cowboy Astronaut Millionaire
2323
Rep 2,889
Hello. Welcome. Bavsound also has a good setup and easy install options you can check them out.
02-24-2021, 01:07 PM | #4 |
Rep 2,250
02-25-2021, 02:56 AM | #5 |
Rep 4
Thanks for the replies
I was initially looking at what was available in the U.K. Most audio installers, with a good rep', go with either audison or Focal. JL audio amps seem to be a popular option I can do the speakers, not a problem, just looking for more info on wiring location to see what's involved in fitting an amp Thanks Tony |
02-25-2021, 03:46 AM | #6 |
Rep 236
I agree with the JL/ focal plan, I would use both those in mine and I have the HK, which is in the dealer today having the amp looked at !
Quite disappointed in the HK, one because of the fault and two because they have downgraded the amp but still sell it as a 600w HK system, its not its 484w, and to be honest I feel its now underpowered. Even when fixed I plan to look at a JL active sub, they have several that fit under the floor in the boot. If I was in your position I would simply change to front components mid/tweeter, probably to focal, rears if you want but a co-axal not component they cheaper/simpler but just as effective in that position, I would listen to that first, then add something like the active JL sub (this will make the biggest single difference) then listen again then finally consider adding an amp for the component speakers if you want more. People spend a fortune upgrading the underseat speakers but no matter who makes them they dont make bass like a dedicated sub, they are compromised by position/power, they are good at mid bass but if you want to appreciate a uplift the a sub is the only way. (have done this in 3 series and thought to myself thats better, then added a sub and went ok thats what bass is ! ) There is a few people that make plug and play harnesses to add amps to all systems ( https://technicpnp.com seems to be the most recommended. its all diy possible even the battery being in the boot makes powering amps simple. I would do it in stages because you can, you don't have to do it all at once, and stop when you like it. I found once in a 3 coupe that I upgraded the fronts to alpine units ( no amp) and a small jl sub, it sounded lovely and didn't feel the need to spend more on it, |
Ldb2511.50 |
03-01-2021, 05:38 AM | #7 |
Rep 4
Thanks for the info!
That is the plan, replace the front door speakers with components and see how it sounds Checked that link along with info on the audison website. With base system, I found a harness is needed to run from the front to rear of the car and back again to add an amp. So a lot more involved to add an amp! Front components along with soundproofing in the door will be the first stage Thanks Tony |
03-01-2021, 06:55 PM | #9 |
Rep 32
I recently had the Audison amp, speakers and sub installed. No wires were run from the front, and no harness used. They spliced the amp into the speaker wires right next to the RAM unit in the back. Amazing difference in sound!
03-03-2021, 06:26 AM | #10 | ||
Rep 236
The base in the UK is driven from the head unit, Just mid driver in each door and two under-seat woofers, no tweeters, I don't think cabling it ever gets to the rear as i don't think there is a RAM module. Hence the need for a harness, Just an educated guess.........or to put another way navigating the BMW minefield of different specs..... |
03-03-2021, 08:56 AM | #11 |
Rep 617
You wouldn't need to run an amp to the back if you didn't want to. There are multiple very small form factor class d amps available nowadays that you could mount under seat or near the firewall. Not sure if that helps in terms of perceived work load of adding an amp.
03-03-2021, 10:46 AM | #12 | |
Rep 32
03-03-2021, 08:25 PM | #13 |
Rep 58
Can you share where you had the install done (if it wasn't DIY)? I can't find anyone in the DC area but I must not be looking in the right place.
03-05-2021, 08:06 AM | #14 | |
Rep 32
The one that I did hear back from called the same evening and was great to talk to. We talked for quite a while and he was super helpful. Unfortunately, when he asked about my budget, he replied that he only does fully custom installs > $10K. But he told me what to look for sound, part and installer-wise, and then he asked who I had contacted. As I rattled off the company names, he was like "pass on them", "no, stay away" and so on. Then he asked where I was located, he said he knew two guys who would do a great job on a BMW and he would trust them with his cars. He went online and got me their phone numbers during our call. Note that all of this conversation and help was AFTER he told me he wouldn't work on my car. I thought that was awesome of him. One guy was an hour north of me who installs Audison, the other guy an hour west who installs Focal. I called them both, both were very helpful to talk to, and they clearly were very knowledgeable about their products and especially BMWs. Each sent me quotes, which were similar in price but different in scope (Focal = amp and all speakers, Audison = amp, front and under seat speakers, and sub. So it takes some effort, more than I ever expected, but in the end the installer was great and the result was worth it. And I was lucky to have the help of the guy who wouldn't install in my X3! |
Ldb2511.50 |
03-05-2021, 08:26 PM | #16 | ||
Rep 58
