Technical Topics Cosmetic and Lighting Modifications (exterior & interior) LED Sequential Mirror Indicators
      04-05-2021, 07:16 PM   #1
SapphireG20
SapphireG20's Avatar
Drives: G20 BMW 330i xDrive
I had some free time today and finally got around to installing the sequential LED mirror indicators that I ordered from Unique Style Racing a few weeks ago.
https://www.uniquestyleracingstore.c...fc9f&_ss=r
The install took about 30 minutes and was fairly easy. Step one is to remove the mirror glass which allows you to see the clips that hold on the mirror cap.
hamera441.50
njfoses290.50
VipinLJ1941.50
      04-05-2021, 07:22 PM   #2
SapphireG20
Once you have the mirror cap removed, there is one connector that you'll have to pull out to free the mirror cap from the car. You'll then need a T10 bit to remove the 2 screws holding the stock indicator from the mirror cap.
The Unique Style Racing unit was a perfect fit when put in place. Simply put the 2 screws back to hold the new unit in and reverse your steps to reinstall the mirror cap.
Be careful to protect the mirror glass, it could get damaged when you're removing it from the mirror and could also scratch your paint once removed. Having a shop cloth hand to wrap around it is a good idea.
      04-05-2021, 07:25 PM   #3
SapphireG20
Pictures of the finished product. You'll notice these are actually smoked so they blend right into my black sapphire metallic paint job.
hamera441.50
VipinLJ1941.50
pdxdbo331.00
      04-05-2021, 07:26 PM   #4
SapphireG20
Here's a comparison of the look or stock VS the new mod:
Appreciate 6
hamera441.50
njfoses290.50
VipinLJ1941.50
Moonbags230.00
330iToy71.00
      04-05-2021, 07:37 PM   #5
SapphireG20
Videos are posted to my Instagram:
Appreciate 12
pneumodoc233.00
hamera441.50
njfoses290.50
OM3RTA391.00
SDKevin85.00
k4sh_90539.00
VipinLJ1941.50
Rocket455484.00
wrickem2101.00
      04-06-2021, 12:27 PM   #6
OM3RTA
391
I still have mine that I bought from a Chinese seller on ebay unfortunately one was longer than the other and did not fit so i ended up getting a refund.
I really do think the smoked looks great against the BSM and looked brilliant in my carbon caps but ultimately for me having sequential indicators up front but standard 'binkers' at the rear just doesn't sit right.
VipinLJ1941.50
      04-09-2021, 01:00 PM   #7
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
SapphireG20 ,
They look great!!
Just have one question. How did you unclip the mirror glass?? I am asking because on my old F30, I had some fun doing it
Thanks
Al
Retired: 2014 328i
BMW CCA
      04-10-2021, 09:59 AM   #8
SapphireG20
SapphireG20 ,
They look great!!
Thanks
I adjusted the mirror as far as possible inward (toward the car door) and used a trim tool to apply pressure from behind while pulling as well with my fingers. One side was much quicker that the other but neither were too bad. Just firm but consistent pressure and they let go. All clips are right in the middle of the glass in a circular shape. Here is a pic of the circular piece the mirror clips into.
      04-12-2021, 11:43 AM   #9
Ronan703
Ronan703's Avatar
72
Drives: M340i
That looks great. Nice smooth animation!
      04-12-2021, 05:17 PM   #10
Rocket455
Grumpysaurus Rex
Rocket455's Avatar
Drives: 2022 M550i
1972 Firechicken  [0.00]
1969 Toronado  [0.00]
1970 Camaro  [0.00]
That looks so cool!
Jim-Bow130.50
      04-27-2021, 08:43 AM   #11
SapphireG20
@RSnic
RSnic657.50
      06-21-2021, 10:00 PM   #12
jpowers36
jpowers36's Avatar
Drives: 2020 BMW M340i xDrive
Wish they sold some that were clear to match my clear side reflectors I bought from them.
2008 Infiniti G37S Coupe 6MT - Black/Black
IG: jpowers36
      07-03-2021, 09:40 PM   #13
johnnyg238
Drive it like you stole it
2020 BMW M340i  [0.00]
Can you see which signal is lit up from INSIDE the vehicle? I can’t believe how stupid it is that BMW doesn’t have an indicator on the mirror for drivers.
      07-04-2021, 07:51 AM   #14
VetteGuy
Drives: Arctic Race Blue M440iX
Now that is a serious 1st world problem.
      07-08-2021, 12:32 PM   #15
OM3RTA
391
Partial solution for the rear lights:
https://www.ebay.co.uk/itm/265032242...b6dd%7Ciid%3A1
      07-09-2021, 09:27 AM   #16
SapphireG20
You can see which one is lit by the indicator in your dash. You cannot see the actual light on the outside.
      07-09-2021, 10:49 AM   #17
sd_dracula
Drives: 2020 G20 330e
Or the expensive one: https://www.aliexpress.com/item/1005...c036693b7c54-6
      07-18-2021, 10:02 AM   #18
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Originally Posted by sd_dracula View Post
That AliExpress one looks pretty good - anyone have experience? I'm not usually one to go non-OEM for something like this, but it def has an OEM look.
Current: 2021 340xi
Retired:
2018 330xi | 2016 340i 6MT | 2013 335i 6MT |
2011 328i 6MT (N52) | 2008 335xi (N54)
      07-18-2021, 11:16 AM   #19
OM3RTA
391
Not for me. If I was attempting to do sequentials for the rear I'd rather keep it OEM than opt for an aftermarket set that uses a 6 year old M4 GTS design even if they do have a better 'sweep'.
      07-28-2022, 07:56 PM   #20
TA^Guy
Drives: '19 BMW 330i
Damn, those are disgusting. It’s like three different people designed them and none of them saw the other persons design.
