05-16-2021, 10:52 PM | #1 |
![]() ![]() 86
Rep 139
JB+ E85 mix
Have my JB+ set around 75-80% and decided to pump 1.5 gallons of E and mix it with 91. Not sure if it's a mental thing but I actually feel a slight difference. Any of you with similar experience?
If so when refilling tank again how do you calculate E mix if the quarter tank that's remaining was already mixed previously. Don't want to over do it that's why. |
05-17-2021, 12:12 AM | #2 | |
![]() ![]() 2415
Rep 2,958
That said if you want to be 100% accurate on your blend you would have to measure before you pump however we really don't need to be that sensitive if we are after E30 (some variance is not going to matter). Here's a photo of what I made and use to pump E85 and 91 CA gas to achieve E30. My assumption here is that E85 is actually giving us E80 (this was based on a test I did at the station I typically pump e85 at) As an example (and to your question) If you have a 1/4 tank you'll need approximately 10 gallons to get her to full so I look at the ratio and pump accordingly. If you want to work your own numbers simply google "e85 blends" and you will come up with a couple calculators (I would post links here but they have been blocked) Hope this helps ![]() Last edited by chenry; 05-17-2021 at 01:30 AM.. Reason: pic didn't post - I think it does now |
05-17-2021, 11:48 AM | #4 | |
![]() ![]() 2415
Rep 2,958
That said Dinan claims to have a full e85 tune for our stock engines but I haven't seen anyone run it and there have been no logs published etc...so ![]() ![]() |
05-17-2021, 02:35 PM | #5 |
![]() ![]() ![]() 441
Rep 445
I don't have an M340i but a 330i and I just recently added in E85 to get an E30 mix on a JB4 and it is a very noticeable difference. Once I install the EWG connector for the JB4 this week, will hopefully get to a custom tune on map 6. Just wish the JB4 auto adjusted like flash tunes between E30 blend and just 93 but I guess thats what switching maps on the fly is for =).
05-21-2021, 10:13 PM | #7 |
![]() ![]() 692
Rep 1,091
Ethanol burns cooler and releases less emissions so I imagine much longer. Unless your tuned then you'll be pushing more air. So less longer
Instagram: M2_Medusa
05-24-2021, 08:31 AM | #8 |
![]() 125
Rep 1,054
Stupid question - Is the blend point different for 93 gas? Would I still be safe adding just ~1.5 gallons of E85 on a stock M340 with a JB+?
Or since I am starting with 93 will the E85 not make much of a difference?
Current: 2024 i4 M50
Retired: 2021 340xi |2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54) |
05-24-2021, 08:54 AM | #9 |
Joint Chiefs of Staff
![]() ![]() 28871
Rep 199,162
Same logic applies, 91 and 93 both have up to 10% ethanol
https://x-ph.com/sale/ Phone number 702-494-9435 ![]() |
05-24-2021, 08:31 PM | #11 | |
![]() ![]() 2415
Rep 2,958
![]() note: I figure a full tank is about 14 gallons but I know that's off a little bit but not enough that it bothers me |
05-25-2021, 07:46 AM | #13 | |
Not new just quiet
![]() 34
Rep 134
Drives: E60, F30, G22 & G80
Darn it ... I thought a full tank of Fxx/Gxx series is closer to 16 gal.
![]() Quote:
2024 BMW M3Cx G80 | Alpine White + Fiona Red | 2021 BMW M440i G22 Last edited by BlaSTiWi; 05-25-2021 at 07:55 AM.. |
05-25-2021, 09:13 AM | #14 |
![]() 125
Rep 1,054
Appreciate the replies, I've never really messed with E85, but now that there is a station near me that has it I am intrigued. Wondering if those that really understand the inner workings of the B58 (2021 version) could answer a couple more questions on the variables.
There are several JB+ threads on here (here's one), but it seems fairly well established that some sort of limiter (torque?) steps at a certain point when a JB+ is set at 100% and reduces the power/boost. So with that said, here are my questions: 1. Are we saying that adding E85 to a JB+ overcomes this power/boost reduction many have experienced (set @100% or otherwise)? I know E85 causes more fuel to be needed and I am wondering if the limiter some have bumped up against has to do with fuel delivery. 2. I realize the OP is specifically talking about a JB+ @75%-80%, which I think is where people have been seeing the best results, but am I wrong in thinking that adding E85 to a JB+ @75% would likely result in the same issue as a JB+@100% and thus a reduction in power/boost? Full disclosure, I am less clear on exactly how E85 changes combustion/power compared to how the JB+ works. 3. What sort of gains would one see with an E85 mix without a JB+? Does the B58 have a sensor that adjusts for E85 - I don't assume it is a "flex fuel" compatible engine, correct?
05-25-2021, 09:15 AM | #15 | |
![]() ![]() 2415
Rep 2,958
An an example if my car says I have 10 miles to go I assume I am near empty and I pump 10 gallons of 91 to 4 gallons of e85. If my car says I have a half tank and I want to maintain my e30 blend (assuming that's what is already in the tank) I pump 5 gallons of 91 to 2 gallons of e85....so on and so forth Sorry I wasn't more clear - hope this helps ![]() Last edited by chenry; 05-25-2021 at 09:22 AM.. Reason: smiley & clarification |
05-25-2021, 09:24 AM | #16 | |
![]() ![]() 2415
Rep 2,958
ps- they have a pretty slick e85 sensor that they sell - you can find it on the Burger Website https://burgertuning.com/collections/fuel-it Hope this helps... |
05-25-2021, 09:29 AM | #17 |
![]() ![]() 75
Rep 333
If you're curious about the general impact that ethanol blends have on turbocharged platforms there's some pretty good reading you can find online:
https://iopscience.iop.org/article/1...3/1/012034/pdf https://dspace.mit.edu/bitstream/han...953430-MIT.pdf |
05-25-2021, 11:57 AM | #18 |
![]() ![]() 86
Rep 139
Thank you all for the responses
I was just concerned about any possible harm. If my calculations are correct I should be at E18. Car threw a CEL but I think it's associated with my DP |
