2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Remove seat back
      05-17-2021, 06:02 AM   #1
xenon
xenon's Avatar
England
1394
Drives: 2021 G21 330i M-Sport
Remove seat back
Anyone know how to remove the plastic cover on the rear of the standard M-Sport front seat. I can see no obvious clips or clip covers so it may just pull off?
Ian
      05-17-2021, 08:38 AM   #2
hamera
hamera's Avatar
442
Drives: 320i M Sport (G20)
There are some screws at the bottom.
Have a look at this
xenon1394.00
Seaford1143.00
      05-17-2021, 08:51 AM   #3
xenon
xenon's Avatar
England
1394
Thank you!
Ian
      05-17-2021, 10:53 AM   #4
225
Drives: 340i
New seat backs or adding lumbar?
      05-17-2021, 12:26 PM   #5
xenon
xenon's Avatar
England
1394
Going to fit a lumbar bladder if I can get the back off.
      05-18-2021, 08:19 AM   #6
225
Drives: 340i
Let us know how you get on as I fitted one of these to the f31 and would be interested in doing the same if the backs come off as easy.
https://www.demon-tweeks.com/real-es...8;gclsrc=aw.ds
      05-18-2021, 10:30 AM   #7
xenon
xenon's Avatar
England
1394
I will do if it ever stops bastard raining.
      05-19-2021, 03:39 AM   #8
xenon
xenon's Avatar
England
1394
I bought this one Amazon, cheaper, next-day (Prime delivery) and fits well:
https://www.amazon.co.uk/dp/B01F8NX6...hk_typ_imgToDp
Getting the back off is easy enough (thanks to hamera for the detailed instructions) but I strongly recommend trim-removal tools. You also need a Torx T20 screwdriver / bit. Top pic shows the bladder pulled down between the springs and the foam. The other pipes and connections are for the side-bolster bladders and the seat heating. It's on the piss by 90 degrees because of the way this forum handles iPhone pics, but you get the idea. Bottom pic shows a selection of trim removal tools.
The pump for the bladder (the same as a doctor's blood pressure gizmo) lies neatly down by the rest of the seat controls. When pumped up it works really well and probably inflates to a more noticeable degree than the factory lumbar in previous cars.
Ordered one for passenger side now.
Ian
hamera441.50
CCM11285371.00
OM3RTA391.00
      05-19-2021, 09:40 AM   #9
225
Drives: 340i
Brilliant thanks. Did the clips come out OK or did the break?
      05-19-2021, 10:44 AM   #10
xenon
xenon's Avatar
England
1394
Came out easily - they are very substantial and would be difficult to break. There are just a couple of more fragile clips that clip the fabric to the base but they’re easy with a trim tool.
      05-28-2021, 10:00 AM   #11
225
Drives: 340i
Did the same today and I can say the seat is much better built than in the f31. Flip side is there was a lot of swearing from the back of an m340 this afternoon! Now I don't doubt its down to my cack handedness but my tips would be..
Definitely get trim tools as mentioned they really help.
Remove the fabric fastener from the bottom of the seat back so it comes all the way off. This makes it easier to go back on. This was the fiddliest bit for me trying to get the cover back on with fabric tucked in.
Needless to say I won't be adding one on the passenger side anytime soon but it will be worth it on a long trip.
Forgot to say thanks for the info above!
      05-29-2021, 12:59 AM   #12
xenon
xenon's Avatar
England
1394
Do you find it an improvement?
      05-29-2021, 08:23 AM   #13
225
Drives: 340i
Yes. Just spent 2.5hrs and no issues. Seats are better than the f31 for support but it was worth the hassle.
      05-29-2021, 08:59 AM   #14
xenon
xenon's Avatar
England
1394
Just did the pax side- only took ten minutes now I know how to do it
      05-29-2021, 09:31 AM   #15
225
Drives: 340i
Show off.
      05-29-2021, 11:44 AM   #16
xenon
xenon's Avatar
England
1394
Originally Posted by 225 View Post
Show off.
      07-03-2021, 02:06 AM   #17
xenon
xenon's Avatar
England
1394
I can confirm after a few weeks and 1500 miles that this little mod makes a *huge* difference to the seat comfort. All is not lost if you don’t have lumbar adjust or it’s been deleted.
hamera441.50
      07-07-2021, 03:35 AM   #18
PauloBairn
Scotland
16
Drives: BMW G20 320d Sport
Just fitted one of these into the passenger side. Thanks to all who posted the details - there is no way on gods earth I would have figured how to remove the back panel without a trip to screwfix for a wrecking bar!
works a treat
      08-09-2021, 08:04 AM   #19
dutchbmw
Drives: Polestar2, Audi A4 convertible
Question, how do you unclip the welts of the seat cover area at the bottom, step 1? My seat is covered with brown fabric at the bottom.
      08-09-2021, 08:06 AM   #20
dutchbmw
"Remove the fabric fastener from the bottom of the seat back so it comes all the way off. This makes it easier to go back on."
This part I mean
      08-09-2021, 11:43 AM   #21
xenon
xenon's Avatar
England
1394
You just pull it. The fabric is attached to a flexible plastic strip that clips into a recess on the seat back bottom.
      08-10-2021, 03:34 AM   #22
dutchbmw
Ah yes, pull downwards; thanks. works!
