2010 2011 BMW 5 Series Forum F10 Thrust Control Arm Bushing Replacement Advice |
07-15-2021, 11:47 PM | #1 |
Rep 194
Drives: F87 M2
Went in for my oil service on my 2014 550ix and the stealership noted that my thrust control arm bushing is failing and requires replacement. I was searching around this forum and didn't see any prior posts... has someone had this service done previously? Dealer is asking for $1200+ plus $250 alignment to get it replaced. I assume this service replaces both sides at once? Is that an accurate price or should I look at an independent shop?
I have not noticed any effect on my suspension or handling. However they said it has cracked and is leaking. Would it leave residue on the garage floor? Any guidance is appreciated. |
07-16-2021, 08:35 AM | #2 |
Rep 598
Thrust arm bushings are indeed wear items and the prices are typical dealer quotes. I've had mine replaced twice already in ~65K miles due to poor roads.
You can easily buy entire new arms online for ~$250 each and have an independent shop replace + alignment for less. Or much less if you opt to replace the bushings only + alignment. |
07-16-2021, 08:48 AM | #3 |
441
Rep 812
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
You're not alone. These commonly fail around 60-70K mark. My dealer quoted me $1k to replace one side, which needless to say is ridiculous. My breakdown was $450 for the part, labor, and alignment.
The thing is, the original part is made by Lemforder which you can buy from FCP Euro for $125. It's the same identical part since Lemforder is the OE supplier for BMW. If you're handy with cars, it's on the medium difficultly scale. Took me about 1.5 hrs each side for a total cost of $300 (with some additional BMW nuts and bolts). If you can find an indy shop that uses Lemforder instead of BMW stamped Lemforder parts, it should's cost you more than $800 for both sides to have them do it for you. I'm not sure why the alignment is honestly needed - the thrust arm doesn't have much impact on wheel alignment. https://www.fcpeuro.com/products/bmw...rm-31126777733 https://www.fcpeuro.com/products/bmw...rm-31126777734
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
07-16-2021, 12:19 PM | #4 |
Rep 965
I second this ^. I got an alignment after and everything was still in spec. I bought these Lem. and did it at home as well. Pretty quick once you get the under tray out. I have heard these Lem. are not as durable as the OEM though? I bought it from FCP, so can always exchange.
07-16-2021, 12:30 PM | #5 |
Rep 194
Drives: F87 M2
Thanks everyone for the feedback, I am fairly handy and have done some mechanical work, but unfortunately I lack the tools to do a proper job on it. Is the guidance to replace both sides simultaneously? Or that does not matter?
07-16-2021, 03:33 PM | #7 | |
Rep 697
Drives: 2013 535xi
2013 535xi, Carbon Black, beige interior, M Sport package, HUD, DDC & ARS, ACS springs, Kelleners wheels
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
07-16-2021, 06:31 PM | #8 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
This job is easy and if you want to upgrade at the same time this is an option here… this will also show you the install…
07-16-2021, 07:50 PM | #9 |
Rep 505
Drives: 2013 BMW F10 N55 535i XDrive
Damn Brow, clean that workbench!!! hahaha
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
07-16-2021, 08:58 PM | #10 |
Rep 1,058
I just replaced these myself, in my driveway, in about two hours. I used Lemforder parts that looked identical to the OE parts, same numbers cast in and everything. I posted it here:
https://www.bimmerpost.com/forums/sh...php?p=27760240 Both bushings shipped to Canada for $80 tax and shipping included. Any shop charging more than $300 for this job is profiting handsomely! |
07-27-2021, 01:02 PM | #11 |
Rep 194
Drives: F87 M2
Update: Just had an independent shop replace both thrust arm bushings for $600 OTD including a 10% discount they gave me for being a BMWCCA member. Since the dealership quoted me $1200+ for this service I feel like I got away relatively inexpensively.
07-28-2021, 12:46 PM | #13 | |
Rep 194
Drives: F87 M2
Keep in mind that I am not tracking/modding and not an overly aggressive driver. YMMV. |
07-28-2021, 01:03 PM | #14 | ||
Rep 1,445
07-28-2021, 11:09 PM | #15 | ||
Rep 1,058
It is a subtle improvement overall, but it's there. |
