07-25-2021, 09:23 AM | #1 |
Rep 6
Problem with BDC Ista+ programming
During a Ista+ section suddenly comunication stopped, all displays off, OBD plug seems dead. Maybe BDC bricked?
Can anyone give help? Thank you G21 december 2019, 320d, WBA6L51 |
07-25-2021, 11:35 PM | #2 |
![]() ![]() ![]() ![]() ![]() 295
Rep 603
It may already be back working now if you go check.
If it is not, remove a battery cable for 10 minutes and then reattach it. With any luck, this power reset will restore your module to working status. If you are getting power at the old port and can see all of the modules, you may have to flash the module you were working with at the time of failure with the stock program and then do your coding again. |
07-26-2021, 03:22 AM | #3 | |
Rep 6
07-27-2021, 01:21 PM | #5 |
Rep 6
Hallo. Some updates. The problem was that the car has been put in "transport mode" , so no DHCP from bdc. With static ip ista+ has been able to reset status and all errors. Then switched back to DHCP and everything apparently ok. But HU-H has an error "programming interruption" and "ICAM2 non valid IP". Ista then tries to re-program, but during programming something goes wrong and a Red cross Is displayed. Then ista starts all tasks again from beginning. But in a loop. After fourth trial, I have aborted the procedure. The CID Is totally Blue. Can anyone help me? Thank you
