2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Steering Weight and Self Centring
      08-21-2021, 11:14 AM   #1
churchieD3
Drives: ALPINA D3 F31
First post ...
I'm 200 miles in with my brand new M340d Touring and I have concern about the steering. On mine it drives "straight" OK, but as soon as one starts to turn right (and I mean immediately) the steering weights up - not too heavy, but noticably. However, when one starts to turn left (again from straight) the resistance/weight is noticably less and does not weight up until further into the turn. Also I note that when driving the steering self centres much quicker/aggressively following a right hand turn. From a left hand turn the wheel returns towards centre slower, but never comes all the way back to centre.
My car is back to the dealer on Tuesday, but I'm interested to understand how other G2x behave.
My thanks in advance.
PS Great site, so much useful info here.
JFray23102.00
      08-21-2021, 12:09 PM   #2
jlapicki
jlapicki's Avatar
Drives: 2022 M 440 convertible
Originally Posted by churchie-g21 View Post
First post ...
Sounds like maybe an alignment issue....
GRB60122.50
      08-23-2021, 02:31 PM   #3
alpinewhite3
alpinewhite3's Avatar
Drives: 330i
First post ...
Curious to see what the dealer says but this has been a common gripe about the G20/22 steering from myself and many others on this site. The steering can sometimes feel "non-linear" which in turn makes it feel unnatural. Spongy, rubbery & sloppy are also adjectives that come to mind. You'll get used to it. Keep it in comfort mode and keep the front tire pressures high.
2019 G20 330i RWD
2014 F30 328i RWD
2009 E90 328i RWD
2006 E90 330i RWD
2002 E46 330i RWD
      08-25-2021, 09:36 AM   #4
JFray23
Drives: 2017 xdrive28i X1
First post ...
First post ...
The G20 has a slow return to center in my opinion, especially on low speed turns. On higher speed turns it's much improved but still requires more effort than previous BMW's I've owned.
      05-24-2022, 06:39 AM   #5
medlyleeds
Drives: G20 320D x-drive
Hi OP. I have an 320d x-drive (in the UK) and I am experiencing exactly the same issue as you. They dealer has replaced some bolts that mount the steering rack as per a technical bulletin but this has not changed anything. Just wondering if you could let me know if you ever got this resolved? Thanks.
      06-05-2023, 11:07 PM   #6
arajshekar10
India
Drives: Bmw G20 330i m-sport
Hi i own a bmw 330i m sport 2022 i have the same problem your facing my car has been to the dealership multiple times and the steering rack and column has been changed by the dealer but the steering weight distribution has not been solved yet.its hard to steer towards right and easy towards left no proper solution has been provided by bmw has your problem has been resolved regarding this? it has dead spot towards left a few degrees
