10-04-2021, 01:21 PM | #1 |
Rep 85
Drives: BMW G20 320i M Performance
(G20 DIY) Strut Brace Bar Retrofit (parts for G22)
All G20 has not Strut Brace Bar.
But, G22 has Strut Brace Bar. Strut Brace Bar connect to left, right suspension mount and front bar. -Parts Number- G22 Connection - 51648491817 G22 Strut Brace Bar - 51617456115 *2 Hexagon Bolt - 51716966566 *4 Total Price = 160~180$ (180,000won at Souht Korea) -Need Tools- Hexagon Socket 13mm, 16mm Star Socket E18 Star Wrench T30 Tapping Screw M10*1.5 *Torque Tools (preferbly to have) -Main DIY- G20 has not screw hole for Brace, need two works. 1. You need change connection parts (G22 Parts has screw hole for Brace) 2. need tapping to suspension mount hole (G20 Body has not screw hole for Brace) Go DIY (watch my video or repair guide) (I'm so sorry... video is not Eng sub. only Korean) 1. Remove parts 2. Tapping to suspension mount 3. Change connection parts to G22 parts 4. Assemble parts 5. Assemble Strut Brace Bar using Torque Tools
Freelancer without work
10
10-05-2021, 02:57 AM | #2 |
Rep 682
Thanks for posting the schematics and torque values... I'll have to double-check mine.
I'm thinking of taking the braces and radiator cover out to get power coated black, so I'll get the right torque on everything when I reinstall. Thanks again. |
soi3847187.50 |
08-21-2022, 04:20 PM | #3 |
"It's so choice...I highly rec. picking one up"-FB
49
Rep 133
I did this mod thinking it might make some difference, even if it was mostly placebo effect.
I was wrong, it makes a massive difference. Highly recommend, if handling is as important to you as power. |
soi3847187.50 |
12-21-2023, 09:50 PM | #5 |
988
Rep 4,360
Drives: M340
Great Video & Great Instructions.
After watching your video, I have ordered all the parts to do this mod. 감사합니다!!!!
soi3847187.50 |
