11-27-2021, 09:16 PM | #1 |
Rep 681
Tyre Pressure Recommendations in MyBMW App
Has anyone noticed on the updated MyBMW App that tyre pressures can now be viewed in the App?
Unfortunately for me, the pressure measurements are in BAR, where my preference is Psi. I can't see a way to change this in the App. More alarmingly, the MyBMW App suggests tyre pressures should be 3.0 Bar. This equates to 43.51 Psi. I think this is too high. In iDrive on the car, the suggested tyre inflation is 40 Psi (equivalent to 2.75 bar). Is anyone confused yet? Which recommended tyre pressure is correct? Personally, I will continue to use 40 Psi for both fronts and rears, and I will assume the MyBMW App is incorrect. In the attached image, you will see that my rear tyres have a slightly higher pressure than the fronts. These readings were taken at the end of a 100 km drive. I guess it proves the rears are doing more work than the fronts, even with the xDrive 4WD system.
11-28-2021, 03:28 AM | #2 | |
Rep 306
11-28-2021, 06:21 AM | #3 |
Rep 908
Are you getting any uneven tyre wear? If not then the tyre pressures you're using would be okay. I used to run 39psi all round but found my front tyres wearing unevenly on the outer sides so have increased to 41psi.
On a side note, I sent my car in for service last week and got the wheel alignment done too, the printout they gave me suggested 39F/42R. Upon driving the car it seemed to ride really firm so I checked the pressures and Bmw inflated the tyres to 45F/50R, go figure!! |
12-03-2021, 02:42 PM | #5 | |
Rep 681
The pressures and temps increase a little after a reasonable amount of running. I do mainly long runs (100 km) in my car, so the tyres are normally up to good running temp and pressures……..as opposed to doing short trips when the P/T may not reach the optimal operating range.
12-03-2021, 02:43 PM | #6 |
Rep 681
You are in the right place in the App but need to have TPMS fitted for the temps and pressures to show up in the App.
pseudofusion2.00 |
