| 03-10-2022, 08:01 AM | #1 |
Rep 1,530
Remote Start = Check Engine Light???
Let me share my current situation: 2020 M340i (no engine or tune modifications - all stock) During the colder months of the year I utilize the remote start function via the key fob. In most cases the car starts with no issues but in the recent months I have experienced this issue twice - vehicle starts, runs approximately 15sec, shuts-off and check engine light illuminates.
The first experience the check engine light remained active regardless of the number of on/off cycles. Made an appointment with the dealer for a warranty claim. Dealer stated the issue was a direct cause of a loose gas cap. The second and most recent experience (2days prior) I immediately verified the gas cap to be secure - no issue, gas cap was tight. I have driven over 200miles, verified the gas cap multiple times and even filled up with fuel - check engine light is still illuminated. Prior to scheduling a time to swing by the dealer, I wanted to quickly verify if anyone has experienced the same issue, and if so what was the culprit? I have verified the "allow engine to start" option to be selected within the climate control settings with iDrive. What is the beset way to verify active/inactive codes? Any insight or direction is always appreciated! |
| 03-10-2022, 11:32 AM | #2 | |
Permanently confused
1754
Rep 2,197
My battery was replaced under warranty yesterday and all is well today. |
Chubbiejones966.50 |
| 03-10-2022, 12:02 PM | #3 |
![]() 1745
Rep 1,498
Best bet is to pull the code and see what it says.
| 03-10-2022, 12:14 PM | #4 |
Rep 1,530
| 03-10-2022, 02:03 PM | #5 |
![]() 1745
Rep 1,498
No, need a scanner but I do believe autozone will pull codes for you. You may have to research BMW specific ones but should get you started.
I bought an OBD scanner to use with bimmercode, it's been a great tool for $65, I helped out one of my employees last week with his lincoln, was throwing a misfire bank 2 and he changed his coilpacks and found one that the shady dealer had glued back together! |
| 03-10-2022, 04:11 PM | #6 |
![]() 59
Rep 100
I had the same exact issue on a '21 540i, happened 3-4 times over the span of a month when using remote start.
Car turned off after a few seconds and check engine light showed up. In my case, the light went away after 1-3 on/off cycles. It was a rental so never looked into it. |
| 03-10-2022, 05:55 PM | #7 | |
Rep 1,530
Appreciate your help! |
| 03-10-2022, 05:57 PM | #8 | |
Rep 1,530
| 03-11-2022, 06:17 AM | #9 |
![]() 1745
Rep 1,498
This is the one I have and apparently it's almost doubled in price since I bought it, but it is super handy:
https://www.amazon.com/OBDLink-Bluet...7000989&sr=8-2 |
| 03-11-2022, 06:20 AM | #10 | |
Rep 1,530
| 03-11-2022, 07:22 AM | #11 |
![]() 1745
Rep 1,498
Yeah it has its own app. Can also do additional gages and performance testing as well.
And data logs. |
| 03-12-2022, 08:05 AM | #12 |
1982
Rep 3,519
Yes they can. I have an OBDLink LX that does the same things the MX does (when it comes to BMW cars). I barely use it now. I can let it go for a decent price if you are interested. Let me know. New on Amazon costs $90+tax
| 03-12-2022, 08:26 AM | #13 | |
Rep 1,530
| 03-12-2022, 06:09 PM | #14 |
1982
Rep 3,519
| 03-13-2022, 04:48 PM | #15 |
Rep 1,530
Was able to determine the code - P0456. Anyone have any ideas? I've read multiple threads but most of them are older and have no direct correlation to the utilization of the remote start function.
| 03-13-2022, 07:36 PM | #16 |
![]() 120
Rep 56
I had a very similar issue living in Canada,the remote start would do the same exact thing, the dealer found it to be my grill…. Long story short when you start the car remotely, the grill opens and closes for a few seconds, my clip on the grill broke making it impossible to open if needed. This may be your issue but not sure. I got a CEL just like you
| 03-13-2022, 08:15 PM | #17 | |
Rep 1,530
| 03-13-2022, 09:03 PM | #18 | ||
Rep 2,411
Seaford1753.50 Chubbiejones966.50 |
| 03-14-2022, 05:30 AM | #19 | |||
Rep 1,530
| 03-14-2022, 08:15 AM | #20 |
![]() ![]() 210
Rep 301
Put your car on a charger and see if it goes away. My car stopped remote starting and was having a check engine. Dealer thought maybe it was a low battery. After that I had a 4 hour road trip. It was a sufficient amount of drive time, to where it must had charged the battery enough. I never got the error after that and remote start has worked every time since.
| 03-14-2022, 05:36 PM | #21 | |||
Rep 1,530
| 03-14-2022, 05:38 PM | #22 | |
Rep 1,530
| Bookmarks |
