05-10-2022, 04:32 PM | #1 |
Rep 200
Drives: 2022 BMW M240i
BimmerCode M240i M-cluster Coding
I was able to code in the M240i cluster that should have been stock on the M240 with BimmerCode.
For those who want to do it, use a wireless/Bluetooth OBD2 adaptor and connect it with BimmerCode. Though BimmerCode does not support the G42 just yet, you can choose 3-Series/M3 and it'll give you some capability to code. Under Instrument Cluster, you should be able to find coding for the display. You can do other ones as well. I did the M performance cluster up to 200mph (160mph is also an option). Has the M240i logo up top. My guess is that when the coding reset the ECU, it added the logo and correct font the car is supposed to come with. Almost as if the car was "hiding" it. Coding was there, but not active. Odd... |
05-10-2022, 06:34 PM | #3 | |
Rep 200
Once I find out more stuff I will put it in this thread. I know you can also do start-up in sport mode and video-in-motion but I haven't done those yet. |
05-11-2022, 10:34 AM | #4 |
Rep 601
Not sure how yours showed M240 after your changes. I selected and coded each different cluster layout and all of the M and M Performance just show ///M at the top.
I'm fine with it as I selected the M layout, not the M Performance as I think the M layout is easier to read and more pleasing to the eyes. Just odd that your somehow popped up M240i |
Sonic RR118.50 |
05-11-2022, 10:55 AM | #5 | |
Rep 200
Sonic RR118.50 |
05-11-2022, 10:58 AM | #6 | |
Rep 200
Note: If you want the M240i logo -- When I switched from the M cluster to M Performance, It took the logo away. So to get it you gotta go to "standard" first and then "M Performance" |
Sonic RR118.50 |
05-11-2022, 12:12 PM | #7 | |
Rep 601
No clue with the designers were thinking having a tiny orange needle over a lighter orange background. |
Sonic RR118.50 |
05-12-2022, 12:04 PM | #12 |
Rep 601
05-12-2022, 01:48 PM | #13 |
Rep 200
05-17-2022, 07:01 AM | #16 |
Rep 200
Just the cluster layout. Doesn't give the option to change the "description." That would be for the previous-gen instrument clusters in the F chassis.
05-17-2022, 09:34 PM | #17 |
Rep 269
Can you get the M specific hud coded?
EDIT: And does the Thor WiFi OBD work for this car? I used it on my F80 so I'm wondering if you can use that with BimmerCode. |
05-18-2022, 07:06 AM | #18 | |
Rep 200
And for the Thor WiFi OBD connector, no clue. You can try it. I use the Veepeak OBD2 connector. Works no matter what BMW model you have. It will always connect to BimmerLink or BimmerCode. |
05-18-2022, 01:59 PM | #19 |
Rep 125
Drives: 2022 M240i
I just coded my cluster from standard directly to M performance 160 and the M240i logo appeared as well. Thanks OP!
2022 M240i
Brett_C_F30_G42381.00 lcortes0.00 |
05-21-2022, 09:21 AM | #20 |
Rep 601
For those of you that have coded the cluster to M Performance and DONT have the M240i logo showing here is how I fixed it:
Go to Instrument Cluster Click on Backups Choose the oldest backup and code it (BimmerCode takes backups prior to making any changes) Exit the Instrument Cluster and then go back in For Layout choose either of the M performance options and code You should now have the m240i logo! My theory is that those of us that choose a layout that was not one of the M performance one’s right off the bat we “lost the ability” for the logo to show up. Once we restore our initial backup and then choose M Performance we get the m240 logo! |
05-21-2022, 08:40 PM | #21 | |
Rep 269
EDIT: VLinker worked great. M240i is now showing on the cluster, auto start/stop has been disabled, and Bower and Wilkins added to the sound profile. Have to figure out what's next. Last edited by NoSuchSol; 05-22-2022 at 02:46 PM.. |
Brett_C_F30_G42381.00 Sonic RR118.50 |
05-22-2022, 11:11 PM | #22 |
Rep 154
Drives: 2022 M240i
So this is a new car (Believe it or not that arrived at the dealer on Friday, which I will possibly buy over my PB on order. So let's call it 3 months since the build and the latest ID7 update.
It seems to have the latest update. If I buy the car I will tell you the OS version at the weekend. |
