| 11-25-2022, 11:49 AM | #1 |
![]() ![]() ![]() ![]() 357
Rep 991
How to code exhaust flaps always open. M440
Trying to see of i can code exuast flaps to be always open. Also want to remove fully artificial engine sound
Do I need bimmer code or bimmer link for that. M440.
Current: 2022 BMW M440gc / 2022 BMW x5 45e
| 11-28-2022, 04:00 PM | #2 |
Rep 58
yea with bimmerlink it. cost like 50 forgot. exactly. might be cheaper I just paid . plus the adapter .
it has. a menu. says exhaust on. just says open or. close for the other noise go there. tells. u about it post 9 https://g20.bimmerpost.com/forums/sh...8#post29579998 |
totalone356.50 |
| 11-29-2022, 08:53 AM | #3 | |
Rep 991
I got bimmer code will just get bimmer link since we have 2 BMWs now. seems to be worth it.
| 11-29-2022, 08:59 AM | #4 | |
B58 Power
1076
Rep 1,444
You can only open it with Bimmerlink and it stays open until you stop the engine. The only way to control the valve are boxes that open the valve at every startup of the engine. Or you could just do the golf tee mode and drive around with the valve always opened.
| 11-29-2022, 10:32 AM | #5 | |
Rep 991
| 11-29-2022, 10:39 AM | #6 |
B58 Power
1076
Rep 1,444
The valve needs to be opened with Bimmerlink at every startup.
| 11-29-2022, 01:33 PM | #7 | |
Rep 991
What do you mean by that?
| 11-29-2022, 03:30 PM | #9 |
Rep 1,716
Drives: 2014 650xi Gran Coupe Msport
Golf tee mod. Old BMW trick. Look it up.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
| 11-29-2022, 03:34 PM | #10 |
Rep 991
Oh so basically unplugging the valves connection so it will just stay open always.
I like this idea lol. I think I might just do it. Do you know if I have to unplug it while car is running in sport mode when flaps are open, or if I unplug it while it is off on the start up it will open the flap?
| 11-29-2022, 03:43 PM | #11 | |
Rep 1,716
totalone356.50 |
| 11-30-2022, 02:55 AM | #12 | |
B58 Power
1076
Rep 1,444
Again, there are three options for the G20. 1. Bimmerlink: You need to connect after every engine start and manually open the valve in the app. 2. Golf tee mod: You need to find the open position of the valve and then remove the plug. I´m not sure if it´s work but you could try to start the engine, stay in park and switch to Sport. Heard this would open the valve. 3. Exhaust Valve Controller: Some shops offer a box that can be hooked to the OBD port or directly wired at the BDC to control the valve. This gives you freedom over the valve and you could close it when needed. 4. Engine tune with valve control: Some engine tunes like MHD offer options like the valve staying open in Sport+. The valve will be closed when the engine is stopped. External controls like Bimmerlink or Exhaust Valve Controllers can only change the valve when standing still. Only methods like the engine tune from MHD can control the valve while driving. BMW changed something in the behavior and what can trigger the valve to change position. Sorry for the confusion.
| 12-04-2022, 08:30 PM | #14 |
Rep 126
This works on my 2020 340. You do have to do it every time you start you car. If you make it one of you favorites, it's two clicks.
| 12-05-2022, 09:22 AM | #15 | ||
Rep 991
On the other note, does anyone know, if I turn off engine sound in the cabin will that actually temper with exhaust or that is just sound that is coming from speakers?
| 12-05-2022, 09:56 AM | #16 |
![]() ![]() ![]() 174
Rep 562
I have turned off ASD (speaker noise) with Bimmer Code in my M440. Engine Sound settings in the menu now effects (very obviously) the exhaust sound (and flap). (It always closes the flap for a short warm up period after a cold start < minute.)
| 12-05-2022, 09:59 AM | #17 |
Rep 991
Got it. Is the instructions are same as someone posted before? My car in service right now so cant go out and take a look at it
| 02-22-2023, 10:02 PM | #18 |
Rep 9
Drives: 22 X5 M50i
Foxwell
Since Bimmerlink you have to open the flaps every time you turn on the engine. Does anyone know if the Foxwell scan tool will just leave the flaps open all the time?
| 02-23-2023, 08:48 AM | #19 |
Rep 991
I coded and my flaps always open. I dont need to open them every time. The only time one of them is closed is when engine is cold and it is trying to warm up.
| 02-23-2023, 08:23 PM | #21 | |
Rep 991
I have m440gc 2022
| 02-24-2023, 12:45 AM | #22 |
Rep 1,221
On my 2020 G21, I've coded the following to give you the Engine Sound menu. I've set mine to always Sport which opens the valve every time you start the engine. Not sure if this is different for M440i / newer builds?
HU_MGU - CAFD_00003E52 - DISPLAY_MENU_CONFIGURATION_ENGINE_SOUND - Ausgelesen = enabled - DISPLAY_CONFIGURABILITY_ENGINE_SOUND - Ausgelesen = aktiv |
| Bookmarks |
