Technical Topics DIYs and Coding Discussions Bimmercode coding "shift lights"
      12-26-2022, 08:15 PM   #1
ralboal
Drives: 21 m340i xdrive
Unhappy Bimmercode coding "shift lights"
Hi
I found in bimmercode in headunit an option called "shiftlight". Activated it but it doesnt show up. Below i uploaded a picture of someone who did in my country : https://ibb.co/WxfHKtt . I codded the M Layout, s63 redline because it is closer to the b58 than the s65. Also coded tyre pressure widget in BC via headunit>expert mode>310>mvehicle2018>aktiv . The only difference i can see it's that the tyre pressure widget looks a bit different.. A thread on this : https://g20.bimmerpost.com/forums/sh....php?t=1737398
So.. How can i activate the shift lights like the one in the picture? Maybe is a conflict with other things i codded? Thx
      12-27-2022, 11:56 AM   #2
imported_nick
Drives:
You need one of the spoofing modules -- https://www.yaodechain.com/product-p...rument-cluster
      12-27-2022, 12:02 PM   #3
ralboal
It can be done without any module
lebaaron493.00
      12-27-2022, 04:37 PM   #4
lebaaron
lebaaron's Avatar
493
Drives: 2020 M340i Xdrive -
Let us know how
      12-28-2022, 09:13 PM   #5
ralboal
Originally Posted by lebaaron View Post
Let us know how
Its a conflict with the HUD i think it can be fixed by activating the m-menu
lebaaron493.00
      01-18-2023, 08:42 AM   #6
R1-Racer
R1-Racer's Avatar
55
Drives: '23 M3 Comp X, TT Huracan
Is there new information on this one? I saw a video of a lap around the 'Ring and noticed the LED shift indicators in the center of the dash, as described here. Would be a useful function in Sport mode.
'23 X-Drive Comp M3
TT Huracan 610-4
E63S AMG
Previous M Cars: F80 M3, E92 M3
      01-18-2023, 09:41 AM   #7
MaximK
Drives: F10- Bimmer Works Car
if you want this M shift lights don't need aditional module
      01-18-2023, 11:14 AM   #8
apwm340i
apwm340i's Avatar
Drives: 20 X3 M40i
So how do we do it, any tips via BimmerCode
      01-18-2023, 05:33 PM   #9
DavesZupra4
Drives: Z4 M40
i tried coding with bimmer code and coded nfd and nothing fuking works. is this a scam? tried language options to german? didnt work. tried the m view, didnt work. wtf
      01-19-2023, 03:03 AM   #10
hayko_M340
Drives: 2020 BMW M340I
Please let us know how, greatly appreciated!
      02-24-2023, 02:11 AM   #11
hayko_M340
Let us know how
Homies gatekeeping how to code in shift light he thinks he found out how to remotely crack all 21+ DME's, thinks people are gonna start a business coding shift lights for a living
      02-24-2023, 02:33 AM   #12
c18
c18's Avatar
Drives: F10 M5
2013 F10 M5  [9.50]
nu mai ascunde codul și spune-ne cum, îți voi da bijuterii din aur dacă ne spui
      03-17-2023, 05:49 PM   #13
Wet Fish
87
Drives: BMW G20 M340i
So, I know for 100% this is possible.
When I installed the track module and had the car coded for it using ESYS, this worked fine.
Today, I took the track module out (unrelated, but I have a suspicion it’s still drawing power and killing the battery) and it STILL has those shift lights on the main dashboard - so must be just through the coding part.
Obviously the HUD rev counter is gone when I removed the module.
Current car: G20 M340i Black Sapphire (Stage 2 BM3 and xHP with Downpipe)
Previous cars: 2019 VW Arteon (Stage 1+), 2017 Audi TTS, 2015 Audi S3 Sportback, 2006 BMW 335i Coupe
      03-18-2023, 08:50 AM   #14
MichaelNRW
B58 Power
MichaelNRW's Avatar
1076
Originally Posted by Wet Fish View Post
... and it STILL has those shift lights on the main dashboard - so must be just through the coding part.
Can you send me the ncd files of your DKOMBI4 and HU_MGU?
I´ll compare them to mine and hopefully find the values.
And will you share the FDL coding values with us?
      03-18-2023, 09:32 AM   #15
Wet Fish
87
Sure. If you can tell me how? I’m a bit of a novice.
      03-18-2023, 11:03 AM   #16
MichaelNRW
B58 Power
MichaelNRW's Avatar
1076
Start Esys, connect to the car, read VO, read ECU, then right click on DKOMBI4 and HU_MGU and read the coding data.
This should create .ncd files in your CAF folder of Esys, which is normally located at C:\data\CAF
Sort by newest file and you should see the two files looking like this.
DKOMBI4: CAFD_00004508_007_000_101.ncd
HU_MGU: CAFD_00003E52_008_010_064.ncd
The marked part identifies the ECU while the last part shows the version, so it can be different.
After that you can zip it, upload it to a filehoster of your choice and send me the link via PM.
Thanks for your work!
      03-18-2023, 11:56 AM   #17
Wet Fish
87
Okay. A little more complicated than I was expecting, but can probably follow those instructions. I’ll try and get it sorted this week.
      03-20-2023, 03:06 PM   #18
brianeck
brianeck's Avatar
1721
Drives: 2022 M340ix Mineral Grey
This thread is a real tease! Make sure you guys share what you find lol, that entire menu looks so much cooler than the stock one.
m340ix Mineral Grey/Tacora Red
      03-21-2023, 06:49 AM   #19
MichaelNRW
B58 Power
MichaelNRW's Avatar
1076
Be sure i´m going to share my knowledge!
I´m not here for profits...
Let´s see when Wet Fish has the time to send me the .ncd files.
      03-21-2023, 05:15 PM   #20
hayko_M340
Hopefully we can get some info and replicate it on bimmercode as well!
      03-22-2023, 06:14 AM   #21
MichaelNRW
B58 Power
MichaelNRW's Avatar
1076
I´m confident that this could be the case.
We´re only talking about FDL coding the DKOMBI4 which is compatible with Bimmercode for most of the versions.
03/2022.xy will be an issue because it´s not mapped yet.
And hopefully DKOMBI4 wasn´t switched to secure coding with 03/2022.xy
      03-23-2023, 11:10 AM   #22
Wet Fish
87
So, I've PM'd you.
I managed to get the coding for the DKOMBI, but I couldn't get the HU_MGU to work for some reason.
I've sent you a dropbox link to both the file and the vid for the error. If you know how to fix the error, I can try again for the second file. Happy hunting, hope it helps you all.
MichaelNRW1075.50
