| 12-31-2022, 12:46 AM | #1 |
![]() 102
Rep 222
Bmw m340i build
Hello I am building my m340i and wanted to ask if I have everything necessary to get the most hp possible
-Pure 800 or Pure 850 turbo - 6-Piece Ultimate-Spec Cooling Package https://titanmotorsports.com/product...ooling-package - Active Autowerke catted downpipe - ecu sent out to get unlocked right now - Awe resonated touring exhaust For these I have two questions 1. Should I buy a dinan carbon fiber intake or is there a better one available? 2. Is this substantial enough to get 700-600 hp? If not what do I need. |
| 12-31-2022, 08:59 AM | #2 |
![]() ![]() ![]() ![]() 493
Rep 629
Definitely not an expert here, but looking at several build for the B58TU, a guy was mentioning how weak are the pistons when you reach these numbers therefore, I would add forged rods and pistons for a piece of mind.
Also what tune are you planning to run it? |
lithe68.00 |
| 12-31-2022, 10:13 AM | #3 | |
![]() 68
Rep 130
Of course building engine internals always will add peace of mind...but if it isn't necessary... B58 takes to mods beautifully, love this engine! And OP, your mod path looks good. An intake might had 1-2 hp, but the difference in sound (turbo whoosh!) is the biggest change, IMO. Keep us up to date on how your build goes & your experience, thanks for sharing! |
| 12-31-2022, 10:24 AM | #4 | |
Rep 629
Playing with big numbers, even if it's not required you don't want to be stressed when you WOT 😎🎄 I myself broke an engine once cause it was modified the wrong way, didn't upgrade the clutch, and the flywheel ended leaving the transmission case and destroyed the block and more... All that to say some things are not required but strongly advised even on our beautiful piece of engineering that the B58 is. Trying to learn from my mistakes. |
| 12-31-2022, 11:31 AM | #5 |
Joint Chiefs of Staff
32611
Rep 205,889
That is a good list; I suggest you reach out to a custom tuner with your mod list and get their opinion on how much power they can safely extract from this build.
https://x-ph.com/sale/ Phone number 725-221-5267 ![]() |
| 12-31-2022, 02:24 PM | #6 |
![]() ![]() ![]() ![]() 724
Rep 854
Drives: 2021 BMW X3 M
--All you need is the CSF manifold with the phenolic spacer. Everything else isn't required. For these, I have two questions 1. Should I buy a dinan carbon fiber intake or is there a better one available? --Stock intake works fine but if you want get the dinan intake. Intakes won't add any power, just sound. 2. Is this substantial enough to get 700-600 hp? If not what do I need.[/QUOTE] --Yes, with port and a lpfp you'll hit even close to 800 --Most importantly, you need to add port injection with a motiv reflex and an LPFP set up.
2014 BMW 335i M-Sport - SOLD
| 12-31-2022, 03:03 PM | #8 | |
![]() 102
Rep 222
--Most importantly, you need to add port injection with a motiv reflex and an LPFP set up.[/QUOTE] Okay so I am looking around and this is the best port injection I can find its 950 cc. https://precisionraceworks.com/produ...40023028498625 Im not fully sure if this works with the port injection I chose but will figure out later https://www.viscontituning.com/produ...41359169618083 I cannot find any low pressure fuel pump the only one I found is a may delivery https://www.znmperformance.com/bmw-b...e-sp-bmb58-fp/ Is this all good? I would like to order them now if good. |
| 01-22-2023, 04:46 PM | #9 |
![]() 102
Rep 222
Okay so I have now finished and purchased all of my parts for my car,
Mods: Pure 850 turbo, motiv reflex plus, intake manifold csf, pfs LPFP, awe touring resonated, active autowerke catted downpipe Tune: Paul Johnson custom tune I am going to a place called parts score for install/tune and was quoted about 6k. In about 1 month - 2 months I will have it fully built and completed. Now I have 1 more question 1. Do I need anything else that would prolong its durability? Pistons, rods, etc |
| 01-22-2023, 07:15 PM | #10 |
![]() 123
Rep 223
One thing no one has mentioned is the transmission, the stock transmission handles maybe up to 550-600whp before it starts slipping so you definitely need to take it out and get it sent out to get built up to handle that power.
| 01-23-2023, 11:09 AM | #11 |
Rep 854
As mentioned, with a pure850 the trans will literally be crying for help. Also, not sure why you did all of that and stayed on BM3 when ecutek would make the car 10x better. Every fast gen 2 car is on ecutek for a very real reason.
| 01-23-2023, 11:55 AM | #12 |
![]() 102
Rep 222
they dont support my mild hybrid + its a custom Paul Johnson tune on bm3, a lot better than ecuteck
| 01-23-2023, 01:01 PM | #13 |
Rep 498
Looks like your car is a 2022. How are you going to tune it with those mods?
The only option is if you are going to send your ECU to Finland to get unlocked. Nobody else can do it. |
| 01-23-2023, 01:44 PM | #14 |
Rep 1,681
OP mentioned he already sent out his DME to be unlocked.
| 01-23-2023, 11:01 PM | #15 |
Rep 854
Ah, gotcha didn't see it was a 2021+. And sorry man custom tune Bm3 is not better than ecutek. Ecutek is WAY more advanced for this platform. Ecutek even has canbus integration. It can literally read and control port injection, meth, etc and setup fail safes on the stock DME. As I mentioned every fast B58TU car is on ecutek. Just look at the top 50 list. All the best with the build!
22M340iAZ101.50 |
| 01-23-2023, 11:20 PM | #16 | |
![]() 102
Rep 222
xnick101723.50 |
| 01-27-2023, 01:18 AM | #17 |
![]() 102
Rep 222
https://youtube.com/shorts/6gsyPNo_TfI?feature=share
Just got down getting Active autowerke catted downpipe installed in my awe touring resonated exhaust. Here is the sound clip I have all the parts now and just waiting on a good time to ship out the ecus Im also hearing a lot of bad reputation about the pure turbos and the mild hybrid system fighting each other, not sure if true. |
| 01-27-2023, 12:28 PM | #19 | |
Rep 1,516
I would go catless and look at big boost turbos (Precision or EFR).
2026 IOMG M3 Comp xDrive
2020 MG M340ix - SOLD 2018 LBB X4M40i 2014 EBII 435ix - SOLD |
| 01-27-2023, 06:53 PM | #21 |
![]() 102
Rep 222
| 01-27-2023, 08:35 PM | #22 |
Rep 1,516
| Bookmarks |
