01-11-2023, 11:17 AM | #1 |
Rep 80
Blown Integrated Supply Module
I'm wondering if I am the only one that has had this issue.
My shop installed Visconti's motiv Reflex kit and blew my integrated supply module as soon as I powered it on. We checked every connection with a voltmeter and cannot figure out a single reason as to why this would have happened. Visconti's harnesses seem to be perfectly assembled. Has anybody else had this issue? I'm going to have them throw a fuse in there so that it doesn't blow the new one as soon as we power it on. |
04-11-2023, 10:30 AM | #4 |
BimmerPost Supporting Vendor
24477
Rep 191,448
04-12-2023, 02:37 AM | #5 |
Rep 219
05-09-2024, 08:58 PM | #7 |
Rep 37
I took my ‘24 M3 CS to the track its been the 11th track day with the car. After the second session everything seemed good, when i turned the car on for the 3 session the CEL was on.
I went home and used bimmer link to read faulty codes and there were a bunch of error codes I used the app to clear them and these 5 remained as well as the CEL. 12 Digital Motor Electronics 5 errors 12B102: Lambda probel heating bank1, control: short circuit to ground 1D2402: Map thermostat, control: short circuit to ground 12B304: Lambda probe 2 heating, bank 1, control: open circuit 12B104: Lambda probe 1 heating, bank 1, control: open circuit 1D2404: Map thermostat, control: line break Only mods are AA catted downpipes, AA single midpipe which I installed back in November last year. Took the car to BMW and they said all wiring was intact but the Integrated Supply Module was faulty. They ordered one and installed it after turning the car ON it blew it again. So now they will change the O2 sensor and install a new ISM. Hopefully that will solve the issue. Im still scratching my head as to why it got damaged in the first place. Car has 6200 miles. Last edited by DRAGM3; 05-09-2024 at 09:54 PM.. |
05-10-2024, 10:30 AM | #8 | |
Rep 6,834
05-10-2024, 12:08 PM | #10 |
Rep 1,041
I know the dealership said the wiring is fine, but are you sure you didn’t cook off some wiring somewhere in the harness or a plug that goes to both sensors on bank 1? It is possible that a bad heater element in either sensor to blow the power producing component up in that chain, but I don’t know if that module controls power for the heater circuits for all 4 sensors or what. You’d think once it’s blown it would show heater circuit issues for both banks and all 4 sensors and not just one bank.
I dunno, track time and resting after sessions and repeating just screams melted shit to me. Mind you, if you’re shutting it down without running the engine for at least a couple of min at no load will cause the O2 sensors to be extremely hot and not be able to cool off quicker with idle or slow driving exhaust gasses going over it. This has been known to cause the complete head of an O2 to just get so hot it breaks off and that will throw a heater circuit malfunction for the respective bank. |
05-10-2024, 02:15 PM | #11 |
Rep 37
Usually open the hood of the car and apply bump stop , leave car running 15-20 min before turning off and thats been regular practice every track day.
They will be changing O2 sensor and ISM and then re check. Good thing is that its being covered under warranty. |
05-15-2024, 04:28 AM | #12 |
Rep 37
Posting this for future users in case they run with the same problem.
After taking the car to BMW and a few hours of testing the wiring for any defects and grounding issues , installing a new IVM module and blowing the fuse, so more testing which eventually showed that the problem was the aftermarket AA DP that was reportedly installed wrong/became loose twisting and jamming the sensor into one of the Turbo bolts causing it to misfire which ultimately lead to the IVM malfunction. Since the DP were installed months ago and car went through 10 track days im guessing what happened was that the bolts became loose at the connection of Bank 1 and also were loose in the connection with the midpipe. Because it was related to an aftermarket installation BMW did not cover it under warranty so a was charged a hefty amount for labor. For future DP installers, should keep attention to the bolts and ensure a proper inspection before doing any track activity. |
05-15-2024, 08:43 AM | #13 | |
Rep 6,834
05-15-2024, 03:18 PM | #14 | |
2028
Rep 5,089
05-15-2024, 03:25 PM | #15 |
You got my money?
3244
Rep 4,711
Drives: Ice Cream Truck
How did you NOT get a CEL with no tune?
I loved my BM3 days on the F series M cars. But I would be terrifed to slap a tune or DP's on a CS.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
05-15-2024, 03:37 PM | #16 | |
Rep 1,041
And why would you be scared to tune a CS? You know it’s the same engine, right? Hell, Stage1 BM3 OTS maps make more than factory CSL/CS tunes. 🤷*♂️ |
05-15-2024, 03:41 PM | #17 | |
You got my money?
3244
Rep 4,711
I used soul performance sport cats on my last 992 and had zero issues. Totally forgot about sport cats. Im so use to catless or stock cats.
