02-21-2023, 12:50 PM | #1 |
Rep 2
Digital audio output from RAM
Does anybody knows if there is a way to get the digital audio output from the RAM? I am using a S8 hertz DSP and one amplifier to feed all the audison speakers but when I reach the 80% of the volume on the Head Unit the sounds comes saturated and not clear. I tried to lower the gains on the amp but the saturation / distortion comes from the head unit.
02-21-2023, 04:11 PM | #2 | |
Rep 13,144
You must set the bass, treble and EQ to flat and then set the S8 gain to minimum so there is no signal saturation at high volume. The S8 high level input is 30V/21Vrms max, and the OEM HK Booster max output is 26V, RAM HiFi max output is 10V, so there is no problem with the S8 being input saturated by the Booster or the RAM at max volume. Last edited by Technic; 02-21-2023 at 07:08 PM.. |
