04-27-2023, 07:53 AM | #1 |
Rep 15
48v mild hybrid battery
Does anyone know how much BMW dealers charge (with labor) to replace the 48v mild hybrid lithium battery when they eventually fail in the m440i vehicles? I ask because I see several owners of 2019 Cayennes with 48 volt lithium batteries that have already needed replacment complaining on a Porsche forum that their dealers charged them an incomprehensible $4000 to replace them (more than half of which was for labor).
04-28-2023, 09:01 PM | #3 | |
Rep 37
https://www.bmwpartspros.com/oem-par...IFJlc3VsdHM%3D I can't imagine that I would ever pay $2k labor cost on top of that to change it out. Unless the dealer has some magic fairy dust that has to be sprinkled during the swap... I'm sure when your battery is ready for replacement there will be a DIY Youtube. Oh, the 48v batteries are also warrantied against "defects and workmanship" for 8yr/80k miles, so that would seem to indicate a decent life expectancy. |
AswB581.50 |
04-28-2023, 11:04 PM | #4 | |
Rep 15
04-28-2023, 11:11 PM | #5 |
Rep 15
One thing for sure. If you do have one of the vehicles with the 48v lithium batteries it sure makes sense to hook the vehicle up to a trickle charger whenver you have any extended period where the vehicle isn't being used to protect the battery. At those prices it makes sense to do anything possible to exend the life of that battery.
04-29-2023, 10:48 AM | #6 | |
Rep 15
04-29-2023, 11:14 AM | #7 | |
Rep 363
Drives: 2021 M340i xDrive
04-29-2023, 11:38 AM | #8 | |
Rep 15
CTEK says "A Lithium battery needs to be charged with Lithium car battery chargers" I did find this thread: https://g20.bimmerpost.com/forums/sh....php?t=1779237 |
04-30-2023, 09:15 AM | #9 | |
Rep 464
Assuming the 48V lithium battery is charged in the same manner as the auxiliary 12V lithium battery (if equipped; see 2nd attachment for details), I would suggest the 48V lithium battery will be charged (using the PCU48) in the same manner. So I recommend using a 12V AGM battery charger (assuming your main 12V battery is AGM) connected to the charging terminals in the engine compartment. Please note the 48V battery is disconnected for safety reasons with the (engine) hood open so close the hood when charging the 48V battery.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
04-30-2023, 09:51 AM | #10 |
Rep 538
Here’s some information which is relevant. It has appeared in other posts, but just in case you haven’t seen it before.
04-30-2023, 10:50 AM | #11 |
Rep 83
Please refer to the SIB provided by sjb993.
This is an updated version of a bulletin provided in 2021, both of which explicitly state that the 48V battery will not charge with the hood closed. |
04-30-2023, 10:58 AM | #12 |
Rep 538
For me, one of the most significant things in the SIB is that a charger with >20A output should (must?) be used.
04-30-2023, 02:28 PM | #13 |
Rep 363
I've always charged my 12v battery with the hood open - now I need to test it out and see if I can get the 48v to charge with the hood open and leave it there overnight and see how it does.
04-30-2023, 03:08 PM | #14 | |
Rep 1,810
03-23-2024, 08:04 PM | #15 | |
Rep 23
03-23-2024, 09:11 PM | #16 |
Rep 15
There is quite a bit of discussion on a Porsche forum about 2019 Cayennes that have needed an enormously expensive ($3000+) replacement of their 48v lithium batteries. At first Porsche took the stasnce that once the 3 year warranty period was over you were SOL and had to replace them on your own dime. More recently, some owners have claimed (and posted copies of their service receipts as proof) that at least in some states the dealers were forced to replace them under warranty becuse they are considered part of the emissions system and the emissions system has to be warranteed for eight years. I have no first hand knowledge and am just repeating what I've read from the posts of many others on that forum.
B58-M340iX222.00 |
