05-18-2023, 04:48 PM | #1 |
Rep 99
Code 19302 Fuel Tank Vent Leak
Recently had the CEL come on for my 2019 M5C. Had a shop run the codes since it is no longer under warranty through BMW and they are saying it is come back as "fuel tank ventilation/purge system leak".
Anyone have any ideas what this could be? Any insight would be greatly appreciated. |
05-18-2023, 04:58 PM | #2 |
Rep 402
Drives: 23 M5C, 19 X5
I was poking around in AOS reading all the M5 SIBs and happened to see one that might apply to you and might be under warranty still:
SIB 01 08 21 F90 (S63M) NVLD LIMITED WARRANTY EXTENSION TO 15 YEARS/150,000 MILES E-Series MY Model Description Production Dates Engine F90 2018 - 2019 M5 Sedan November 7, 2017 to June 27, 2019 S63M CAUSE Over time, the Leak Diagnosis Module (NVLD) (with connected hose) component material may fail, this can create a fine leak to develop in the Evaporative Emission Control System (EVAP). Should this occur, corresponding fault codes will be stored in the DME memory and the MIL (Malfunction Indicator Lamp) will illuminate. |
05-18-2023, 05:03 PM | #3 | |
Rep 99
Appreciate that! I'll have to give BMW a call to see if I can bring it in then. |
09-19-2023, 11:09 AM | #4 |
Rep 182
