06-13-2023, 07:33 AM | #1 |
Rep 172
Factory Alignment
Has anyone put their stock car on an alignment rack or has BMW's specs for the M2? I know the previous gen came with an option to purchase camber correction hubs that were the same part number for all f8x cars, unfortunately I'm seeing a bunch of different part #s for the G8x m2/3/4 which makes it difficult to understand what is what as I was under the assumption the suspension is carried over from the m3/m4.
07-18-2023, 11:55 AM | #2 |
Rep 4,525
if wanting my -ve front camber buy the g82 m4 csl front hub carriers/swivels as they G8x RWD MINUS camber correction front hubs fitted at factory
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
07-18-2023, 03:16 PM | #3 |
Rep 172
07-18-2023, 03:39 PM | #4 | |
Rep 4,525
The MINUS correction hub part no 31217883638 is cross compatible between G87 m2 and g82 m4 CSL as per attached screenshots
Lappy214.00 |
07-18-2023, 05:06 PM | #5 |
Rep 3,016
Drives: A Family Sedan
07-19-2023, 12:22 AM | #6 |
Rep 4,525
Not from the factory no but you could retrofit g82 M4 CSL hub carriers to an g87 m2 for additional front camber using oem parts.
M2siast5943.00 |
07-19-2023, 06:43 AM | #7 |
Rep 172
I saw that and that is where my confusion starts, part # 31-21-6-891-169 also states "minus camber" hubs for the m2 along with a host of other cars so I am wondering what is the difference here. Reason why I even care is that I have a very specific ruleset I have to follow so just because it fits doesn't mean it is legal, it needs to be approved in the factory service manual as an oem form of camber correction. So essentially does part # 38 give more camber than part number 69 or is it just different material as it looks like one is forged and the other isnt.
07-19-2023, 08:15 AM | #8 |
Rep 4,525
Lappy
BMW part no 31216891169 you quoted is -60 camber correction hub for RWD g2x BMW also sell -30 camber correction hub for RWD g2x which will have a different part number from ….69 above. For g8x neither of the above fit. The part I’ve quoted is, as far as I’m aware, is one side of the only minus camber correction hub offered by BMW for RWD g8x cars.
Lappy214.00 |
07-19-2023, 08:28 AM | #9 | |
Rep 172
07-19-2023, 10:19 AM | #10 | |
Rep 4,525
