2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions iDrive 8 screen burn in
      06-15-2023, 12:36 AM   #1
ayv_g20
Drives: 2023 BMW 330e
(2023 330e) Is there any way I can prevent this screen from popping up while my car is charging? The “BMW” text gets burnt into the display after sitting for hours.
      06-19-2023, 01:55 PM   #2
SoCalJon
Drives: 2023 BMW330e
I only charge my 2023 330e at night... on a timer/schedule, so I'm not aware if my care does this or not.
I'm curious if this is consistent across the model or if your car is an outlier for some reason. Also, it looks like the light behind your hazard button is on.
Any other 2023 330e owners able to chime in?
      06-19-2023, 02:30 PM   #3
StevenDS85
I ///M Fan
Drives: BMW 330i M-Sport
Looks like your keyfob is in the neightbouhood. Leave your keyfob away and return after around 15 minutes. Then everything should be switched off.
      06-19-2023, 02:52 PM   #4
dhock_holiday
Drives: M340i
BMW uses an LCD panel they should not be burning in. That should really only be a problem on OLED panels. You may have a defective screen
      10-19-2024, 09:02 PM   #5
pegogetem
pegogetem's Avatar
Drives: BMW 740i
2023 BMW 740i  [8.33]
Any permanent screen burn in to report?
      10-21-2024, 02:59 PM   #6
nxgavin
Drives: x5m competition, m340i
??? Is that an OLED screen? If it's a LCD, it won't burn in at all.
      10-22-2024, 02:09 PM   #7
JK479
JK479's Avatar
1272
Drives: I6-> iX
Believe it or not- LED and LCD can bend the plastic and “burn” in if left on long enough.
      10-22-2024, 02:12 PM   #8
ayv_g20
I have been seeing people say that LCDs never burn in for ages but I’ve had many experiences with it happening
      10-22-2024, 02:15 PM   #9
ayv_g20
No, but the temporary burn in still happens to this day. Even after short drives now, the guages and other information that that stays put burn in
