| 09-01-2023, 09:06 PM | #1 |
![]() ![]() 122
Rep 307
Removing side mirror cap without popping out the mirror
Hi all.
I understand there’s two ways to go about removing the mirror cap on the the G20 and a video by Kies doing it by pulling the mirror glass out. Apparently the mirror doesn’t need to be pulled out if not replacing the black support frame. Is it easier to remove the cap this way, or can it just as easily be removed by disengaging the two clips behind the mirror and pulling the cap off. I need to replace the right side mirror cap and want to do it whatever way to avoid scratching or breaking anything. Unfortunately BMW does not have instructions on this. Thank you. |
| 09-01-2023, 09:15 PM | #2 |
Unapologetic Tool Hoarder
1031
Rep 1,248
It's actually far easier/quicker and less likely to break the cover clips if you just push on the top of the mirror glass until it's all the way up and then pry the bottom out. It pops out pretty easily and then you can gain access to the clips. I just did this a couple weeks or so ago to my daughter's to put black M style mirror caps on.
FYI ... that's the official way to do it by BMW. |
| 09-02-2023, 02:19 PM | #3 | |
![]() ![]() 122
Rep 307
| 09-04-2023, 03:38 PM | #6 | |
![]() ![]() 122
Rep 307
| 09-04-2023, 03:48 PM | #7 |
1031
Rep 1,248
I just left the mirror glass hang with the wires. There's really no reason to remove the wiring. Just be mindful of if scratching the paint if it's swinging around. Also, if I recall correctly, the mirror base has some slots in it for the cap so line those up as you slide it back into place. It's not obvious unless you're looking for them. Good luck.
| 09-04-2023, 09:44 PM | #8 | |
![]() ![]() 122
Rep 307
| 09-05-2023, 10:53 AM | #9 |
![]() 95
Rep 167
you can actually tilt the mirror using controller to very outside or inside which will create enough space to shove your finger behind the mirror.
That you wouldn't need any tool to pop the mirror out. if you are fingers are too big.. you can use that space for tool for better contact. |
| 09-05-2023, 09:45 PM | #10 | |
![]() ![]() 122
Rep 307
| 09-08-2023, 01:09 PM | #13 |
Rep 484
I installed carbon mirror caps and didn’t remove the glass. I just pointed the glass all the way down and I was able to get a trim tool in to help free the clips. It was pretty easy. Be super careful putting the cap back in and making sure the clips align, else you may break them when pushing the cap on.
| 09-09-2023, 07:27 PM | #14 | |
![]() ![]() 122
Rep 307
| Bookmarks |
