Technical Topics Cosmetic and Lighting Modifications (exterior & interior) G20 LCI Crystal Bling and More Dynamic Ambient Lighting
      10-20-2023, 09:50 PM   #1
IndotagSwizz
IndotagSwizz's Avatar
538
Drives: F30 320i
Added more ambient lighting in the center console and doors, it literally transformed the interior, door ambient lighting is dynamic on the top, also added all the fake crystal I could find
      10-20-2023, 11:47 PM   #2
achan111
Drives: Bmw 430i
Source and Purchase
I wanted to get the same lights for my car could you provide links or a source to acquire them please thank you
      10-21-2023, 08:57 AM   #3
tgrundke
Drives: '23 M340xi; '16 GTI Autobahn
2023 M340  [10.00]
That looks great. Could you please share parts/method?
      10-21-2023, 02:42 PM   #4
IndotagSwizz
538
Drives: F30 320i
Not sure we can name certain places but it’s from that same place you get everything else you ever need from owned by that bald dude
      10-21-2023, 02:49 PM   #5
IndotagSwizz
538
Drives: F30 320i
Center console is one kit, all 4 door another kit, so 2 different kits, center console fairly easy install, doors require removing door panels, and slight disassembly of each door panel, a little patience not easy but doable, both kits 100% plug and play, no coding, can display any color
      10-22-2023, 03:11 AM   #6
K20C4
Drives: 2025 G15 M850i
Now you just need cup holders with silver trim and ambient lighting to complete the look
      10-23-2023, 12:07 AM   #7
IndotagSwizz
538
Drives: F30 320i
Yeah there’s a lot more stuff out there, tho that one I had not seen, I’m def gonna check it out
      10-23-2023, 08:55 PM   #8
Lalava
Drives: 2024 m440i
Where did you get the crystal parts from? How’s the quality? Looking to add to my new m440i because I’m jealous of the bling in my husbands x7!
      10-23-2023, 09:10 PM   #9
IndotagSwizz
538
Drives: F30 320i
Don’t exactly remember what the rules are for posting certain things tho if you look at my first reply in this tread I left a really good hint there.
Quality is pretty good, they look great to me, I’m pretty sure it’s not real crystal because the real BMW crystal parts seem to cost a ton more, so not sure what’s it’s made out of but they certainly don’t look cheap or crappy
      10-24-2023, 05:27 AM   #10
Lalava
Drives: 2024 m440i
Got it, lol! I’ve been looking at that option but wished there was a place I could get actual crystal parts! Not trying to cheap out, just love the look - but glad you are giving it is a positive review so I’ll probably buy it.
      10-24-2023, 02:10 PM   #11
phani_ch
Drives: 16' VW Passat, 24' M340 xDrive
That looks sick.
I've been eyeing on the crystal kit for my G20 LCI as well.
The stock gear selector has a small ambient light strip on the top of the selector.
Does that light pass through this crystal selector as well?
It's very hard to determine this from the pictures.
Also how hard was it to install the ambient lights on the doors?
Thanks.
      11-06-2023, 06:45 PM   #12
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
IndotagSwizz ,
The lighting looks great!
To allay your concerns about posting sources, I can tell that I posted the URL of the mud flaps & other stuff I added to my car.
Besides if there's a problem, administrator will take care of it.
So, would you be kind enough to post the web link (URL) or at the name of the kits you got?
Thanks
Al
Retired: 2014 328i
BMW CCA
      11-06-2023, 07:25 PM   #13
IndotagSwizz
538
Drives: F30 320i
IndotagSwizz ,
Thanks
https://a.co/d/1ryfhu9
Ambient lights doors
https://a.co/d/3ExLAOt
Ambient light center console
RSnic678.00
      11-06-2023, 07:39 PM   #14
IndotagSwizz
538
Drives: F30 320i
Originally Posted by phani_ch View Post
That looks sick.
Thanks.
Great question!!
The light does shine thru but it’s barely visible tho if you look closely when you have it install you can see it lights up, in my opinion the visual looks so much better I can careless that the stock selector light up brighter.
Here’s the why the difference in brightness between the “Crystal” and stock LCI gear selector:
The stock selector is hollow, inside there’s a separate clear acrylic piece that helps transferring the light from the led source to the selector…simple enough..
The “Crystal” LCI selector obviously cannot be hollow because you can see thru it..therefore the acrylic piece that helps the light travel from the led source to the selector has nowhere to go, this is why the light is still visible but not as bright.
Hope this helps
      11-06-2023, 07:59 PM   #15
IndotagSwizz
538
Drives: F30 320i
[QUOTE="phani_ch;30595692"]
It def not the easiest but if you have done some DIY’s and have a little patience once you do the first door it gets a little easier.
You do have to remove the door panels and you are going to need either a plastic soldering tool or some sort of plastic rivet kit.
Light bars wedge in between the top door panel and the panel below that panel therefore you have to remove the rivets that hold those 2 panels together in order to fit the bars and then either reseal the same rivet points with a plastic soldering tool or some sort of plastic rivet
Sounds a little scary but not that hard at all
      11-11-2023, 09:21 PM   #16
IndotagSwizz
538
Drives: F30 320i
That looks sick.
Thanks.
I did my friends car over the weekend and took some pics, so you can see better.
      10-06-2024, 01:05 PM   #17
Sqveeze
Germany
Drives: 2021 - G20
Sorry for gravedigging this thread, but i just found this on the web, and the links since then are not exists anymore, it is possible to repost them?
      12-18-2024, 07:53 PM   #18
Teodor.St
Teodor.St's Avatar
10
Drives: BMW F30 335i
IndotagSwizz hi, sorry for bothering you, I just wanted to ask if the center console ambient lights provide the same as OEM colors and brightness?
I found some of these on Aliexpress, but people there in comments say that they are not as bright as OEM. Are light guides inside the trim made of silicone or hard acrylic plastic?
I am considering buying these and eventually replace the LED modules with OEM ones.
Thanks!
      Yesterday, 03:49 PM   #19
IndotagSwizz
538
Drives: F30 320i
Thanks!
I have bought a lot of ambient trim pieces from Aliexpress(center console/seat belt buckles/center console cubby, they are all just as bright, colors match almost perfect, most are pretty much dead on but keep in mind that there are tons of purples or blues so yeah BMWS’s “Azure might not be an exact match because the LED from the trim piece is made to show a blue that’s fairly close but it’s not gonna be Azure…hope I was able to explain that well enough. all the plastics always match perfectly. The center console lights also need to be installed properly (there tons of videos on YouTube) there’s a small piece of black tape you have to install, if you don’t it will light up much dimmer and that’s probably the issue to the people that say it’s not bright enough. Also keep in mind the placement of the center console in the car…that specific area gets hit by all the direct sunlight during the day which also might be making them think they aren’t as bright. They look great in my opinion, hope this helps
