11-10-2023, 07:19 AM | #2 |
Rep 463
Please provide a better explanation of what you want to do.
- shut down all hvac air flow (you can turn the hvac off) - shut the center vents but keep the outside upper vents working ( this is possible with the physical thumb wheels) - shut down all the face level vents, keep flow to floor and/or defrost (you can do this with the button on the center of the controls) Or is there some other scenario? |
11-10-2023, 10:16 PM | #3 |
Rep 67
Thanks for the response. There are 2 issues:-
1)There is constant air flow from the vents of the center speaker on the dashboard - I can seem to stop this airflow with any setting 2)there is constant air flow from the windscreen duct just behind the dashboard speaker - the air flow is very mild but again I can’t seem to stop it with any setting - I have tired Manual air on setting with recirculating mode and manual air flow setting tolerated cabin passengers only - but this airflow still keeps coming. Hope this explain the issue. |
