03-25-2024, 10:40 PM | #1 |
Rep 3
Antifreeze/coolant recommendations
So i recently purchased my bmw a few days ago and was wondering what coolant is best to use? If anyone can help me out would be greatly appreciated
03-25-2024, 11:35 PM | #2 |
Rep 1,535
For normal usage, I’d always recommend OEM coolant. It is sufficient for most of us, even those of us who track.
03-26-2024, 01:28 AM | #3 |
Rep 3
Thank you, also there is another tank next to the coolant reservoir do i top that up also?
03-26-2024, 03:39 AM | #4 |
Rep 117
Mine used a little coolant over 35000 miles, I purchase OE stuff just mix 50/50
Check both bottles, both have min level markers
2020 BMW 320d M-Sport xDrive Touring
03-26-2024, 07:51 AM | #6 |
Rep 8,201
It should not be low unless you have a problem.
Ian
03-26-2024, 08:03 AM | #7 |
Rep 117
After 35000 miles mine lost a small amount but no leaks, since topping up about 3 months ago used none
03-26-2024, 09:04 AM | #8 |
Rep 1,535
Not necessarily true. The B58 is known to have small leak/evaporation through the top lid. I will randomly at times have 20-30% of my coolant used, even with my normal cruising, slow driving speed manner. Conversely, when tracking, I will have no leak through that seal.
It is documented that some of us have this random leak/evaporation issue that as long as monitored, should not present an issue.
03-26-2024, 10:00 AM | #9 | |
Rep 8,201
Ian
03-26-2024, 10:07 AM | #10 | |
Rep 1,535
The alternative is to simply check coolant levels and top off as needed.
