03-30-2024, 09:12 AM | #1 |
Rep 15
2021 G20 Headlights not aligned after body shop work
Morning from Colorado!
Our son Kason was in a little fender bender. The body shop did a great job making it all look new again, but we noticed that the headlights are not "even". The passenger side has the same gap above and below the headlight. The drivers side actually sits on the bumper, and there is a huge gap all along the top. The shop said they can get it in to fix it "in the next 2-3 months" since they are very busy. So I would like to fix it myself. We tried the 2 torx that are supposedly to adjust the vertical and horizontal alignment. But the headlight itself doesn't seem to move. Any help would be greatly appreciated! Pics below! Best, Bill and Kason |
03-31-2024, 09:21 AM | #3 |
![]() ![]() ![]() ![]() 410
Rep 518
In order to adjust the headlight assembly itself, you will have to losen the fasteners that attach the headlight to the vehicle.
If the headlight mounting bracket is not bent/displaced, you should be able to properly align the headlight assembly. Attached images: 1) Location of upper headlight assembly fasteners (#2). You will have to remove some trim pieces to access these fasteners. 2) Location of lower headlight assembly fastener (#4). You will have to remove the front lower fender-liner to access this fastener. 3) Headlight mounting bracket (#7). Also, double check the bumper cover is properly aligned.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
04-02-2024, 09:18 AM | #5 |
Rep 15
They didn't move the headlights too much, so I think they are WAY off since we didn't pay attention to the alignment of the beam, just the spacing of the actual lights...
04-02-2024, 09:20 AM | #6 | |
Rep 15
Down to the garage we go... ![]() |
04-02-2024, 11:10 AM | #7 |
![]() 17
Rep 83
On a 10’ throw mine is about an inch or so lower. Would it adjust enough for that? I certainly can go to the shop that did mine but if I can do it and not have to deal with them again I would prefer it.
04-02-2024, 12:25 PM | #8 | |
Rep 518
I suspect the mounting bracket and/or the other components (see pic3 in my original post) that the mounting bracket is attached may be bent. What damage did your vehicle sustain?
04-04-2024, 06:37 PM | #10 |
Rep 518
Thank you for the pic.
The bumper cover appears to have been pushed-n so something could have been bent causing the headlight alignment issue.
