Technical Topics Wheels and Tires performance tires are fragile? broken three times in past three months
      04-27-2024, 09:55 PM   #1
augustus08
New Bimmer
Drives: BMW X3
Unhappy performance tires are fragile? broken three times in past three months
Hi, I got my M340 on this January. Due to the terrible road condition in US east (Mass), the tires have been broken three times already.
I'm using the run flat performance tire by Bridgestone (turanza t005 rft r19)
First time I was driving on a local road and hit a pothhole. Two days after, the right front tire ran flat (fig 1)Name:  WechatIMG42843.jpg
Second time I was driving on a highway and cannot avoid another pothhole on the road. It turned out left front tire had a bubble (fig 2)Name:  WechatIMG42844.jpg
With above experience, I was driving carefully with the pothhole on roads. However, one week after I just fixed the left front tire, I was driving on a local road with 40 mph and hit another pothhole. This time right front tire had a bubble again... (fig 3)Name:  WechatIMG42845.jpg
Luckily I brought the tire insurance so the cost is tolerable, but having to fix tires in this frequency is really PITA.
Why the performance run flat tires are so fragile? Any advice to improve this experience?
Thank you!
sancat3.00
      05-02-2024, 09:28 PM   #2
Fulqrum
Fulqrum's Avatar
Drives: M440ix
I too, had the Bridgstone RFTs on my M440ix as stock. After 3 years I finally just today replaced them. Originally 225/40/19, I went with some non-RFTs Continental DSW06’s in 235/40/19. I was hoping the lip protection for the rim would be a little better on these 8-inch wide 797M rims, but, still better than what I had in the Bridgestones. I think with 245’s I would have been rubbing somewhere. Roadnoise in the cabin is GREATLY diminished. Bumps are also well absorbed by these.
sancat3.00
      05-03-2024, 11:10 AM   #3
chris_1001
chris_1001's Avatar
541
Drives: 2022 BMW M340i
I'm in eastern MA, the pothole situation is seriously out of control.
Popped one tire, second got a bubble and bent a rim, third was a screw...
I have the warranty as well, sadly it did not cover the bend, it was slight, so I was able to get it repaired.
2022 M340i XDrive, Oxide Grey Metallic/Tacora Red/Shadowline.
2004 330Ci (Sold), 2007 335i (Sold)..
sancat3.00
      05-15-2024, 07:03 AM   #4
sancat
Drives: 2012 335i Convertible
100% agree on mass potholes.
I bent too many wheels, changed too many tires.
I’m seriously thinking of steel rims for the winter.
Fulqrum in your experience with non-RFT does that prevent damaging the rims?
      05-15-2024, 12:40 PM   #5
Fulqrum
Fulqrum's Avatar
Drives: M440ix
A slightly taller & wider sidewall will always help to diminish the potential damage to rims. The trade off being, of course, that it may impact handling a little, as well as slightly distort actual MPH readout on the speedometer. I would think the rft’s sidewalls would have performed better when hitting potholes but I guess not.
      05-16-2024, 07:56 AM   #6
Ruebarb
Ruebarb's Avatar
391
Drives: BMW G42 M240i
I have go flat P Zero peformance tires, no issues. Plus looking far enough ahead to avoid the hole.
      05-19-2024, 03:46 PM   #7
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
First time I was driving on a local road and hit a pothhole. Two days after, the right front tire ran flat (fig 1)Attachment 3444478
Second time I was driving on a highway and cannot avoid another pothhole on the road. It turned out left front tire had a bubble (fig 2)Attachment 3444479
With above experience, I was driving carefully with the pothhole on roads. However, one week after I just fixed the left front tire, I was driving on a local road with 40 mph and hit another pothhole. This time right front tire had a bubble again... (fig 3)Attachment 3444480
Thank you!
This is expected from low profile RFT tires. Your driving environment is obviously less forgiving so perhaps moving to 18" if possible.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      05-20-2024, 07:45 AM   #8
Bc2005
Drives: 2021 M340i
Had the same size tires on my M340 and had five tire sidewall failures over about 50k miles. Mine were 19” Pirelli P7’s, and they couldn’t handle potholes at speed.
I considered switching to 18’s, since they were also a factory option, or trying another brand of tire. Finally ended up selling the car because I needed it for long trips, and the tire blowouts with no spare were really inconvenient.
Calling AAA is a nearly useless solution when you are hundreds of miles from the nearest BMW dealer, and/or it’s a weekend and most tire stores cannot get special order tires until Monday. Most local tire stores do not keep low profile, H or V rated tires on the shelf, unless they are a BMW dealer.
Very frustrating to find a tire bubble on Friday afternoon, and be told the tire store can definitely have your new tire first thing Monday morning.
      05-20-2024, 08:49 AM   #9
Sam Tango
Drives: BMW M340i (2023)
what pressure were you running? its surprising to get flats with potholes
      05-21-2024, 06:43 AM   #10
Bc2005
Drives: 2021 M340i
I was running the recommended pressure, which I believe was 39/42 psi. They were 19” Pirelli P7’s, stock square size, on 792M wheels.
Hitting an unexpected pothole always makes me cringe, but after having the first couple of tires fail it was even more cringe-worthy. The typical failure was to cause a baseball sized sidewall bulge, or actually blow out a flap of rubber about the size of a baseball. I had the BMW tire and wheel warranty, and they always said the wheel was fine.
