F30POST
F30POST
2012-2015 BMW 3-Series and 4-Series Forum
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Transfer case oil change advice
Extreme Powerhouse
      04-30-2024, 04:16 PM   #1
ColTheWol
Drives: bmw f30 x320d
Hi, I am purchasing the tools I will need to change the oil in the transfer case on my 320d F30 2015.
Do I need to buy a replacement plug\screw or could I reuse the existing one?
      04-30-2024, 05:02 PM   #2
dholdi2
Drives: F31 35d
There is only the fill plug, no drain plug.
I reused the existing one.
      05-01-2024, 12:12 AM   #3
Allworth
Drives: X1 xDrive20d (E84)
+1 for reuse. Bolt is similar to one for an engine oil sump, which has no recommendation for a change after every use.
1995 E34 525td auto • 2016 F30 320ed auto
      05-01-2024, 01:44 AM   #4
ColTheWol
Great, thanks, you saved me a few pounts
      05-01-2024, 01:46 AM   #5
ColTheWol
What about the oil seal?
      05-01-2024, 08:08 AM   #6
Mkesler75
Drives: BMW f34
Just my two cents but for the $3-4 cost I’d have one on hand. As history has shown you never know what can go wrong. If something happens you are a few days from getting that new plug.
      05-01-2024, 01:40 PM   #7
Allworth
Just because you can afford a new bolt doesn't mean you need it. 'You never know' is this an argument to buy a bolt?
Personally never had issues with a drain bolts, I once had thread destroyed on my old e34 by some mechanic, and it was sump's thread, not a bolt's thread.
      05-01-2024, 01:54 PM   #8
Mkesler75
Drives: BMW f34
We are not talking a costly part here. I’m extremely budget minded. My point still stands. These are not easy to find. It would be a shame to have down time over a very minor part. Again, I’d side with caution and have an extra on hand. You never know who you may help down the road. It’s just my opinion, take it or leave it. My experience over the last few years doing just about every PM service on my car is that it never goes as planned. Be prepared.
      05-01-2024, 04:25 PM   #9
dholdi2
Drives: F31 35d
Its a steel bolt in an ally case so if you have thread issues then your in a whole world of pain.
I suppose you could drop it and it rolls off into a drain.
      05-02-2024, 02:32 AM   #10
TurboWeasel
Drives: BMW 330D
If it's anything like the rear diff plug with the integrated green viton O ring, I'd stick a new one on personally. If it's a crush washer, they're OK to reuse given how infrequently they come off, but rubber O rings shrink and degrade over time.
      05-02-2024, 02:45 PM   #11
Allworth
Diff I have done had no rubber o-ring, it should be replaced if there is one.
I am aware they often come in a set with a bolt, speaking of integration I once did EGR clean and a rubber o-ring has fused to aluminium and turned to stone, had to scrape that off.
f30post
