05-01-2024, 11:18 PM | #1 |
Rep 12
Help downpipes issue
I just got my downpipes installed, and my car is rattling and jolting from 0 to 1 rpm back and forth. I’m freaking out i don’t know what to do. Can someone please help me. I installed ARM Catless Downpipes on my G82 M4 Competition 2024. What do i do.
05-01-2024, 11:28 PM | #3 |
Rep 427
O2 sensor not get plugged back in? Only thing I can think that would do that and even then that seems unlikely
2015 VW GTI (446whp/414wtq)
2024 M3 Comp xDrive |
05-02-2024, 07:34 AM | #4 |
Rep 1,069
This may not be possible due to the connections, but I’d make sure they didn’t mix up the O2 sensors between the primary and secondary ones. They are different… but you’d definitely get a CEL for something like that. Video would help see what you mean specifically.
05-02-2024, 10:48 AM | #5 |
BimmerPost Supporting Vendor
2040
Rep 5,100
O2 not plugged in or backwards are really the only things that can cause this.
If it was at a shop it should of never of left like this though.
05-02-2024, 01:08 PM | #6 |
Rep 12
05-02-2024, 11:09 PM | #7 |
2040
Rep 5,100
Sounds about right. Good luck!
05-03-2024, 06:58 AM | #8 |
Riding the knock sensor
2434
Rep 1,617
Drives: 21 X5MC | 23 M4CSL
So many good s58 experienced shops in LA area too
05-03-2024, 02:40 PM | #9 |
Rep 172
05-03-2024, 04:46 PM | #10 |
2040
Rep 5,100
Seems to be a self installer. Our arch nemesis
05-03-2024, 05:34 PM | #12 |
Rep 1,069
Then g82king ain’t much of a king then, huh? Thing that’s throwing me off is he said “I got my downpipes installed.”… didn’t say “I installed my downpipes and” which leads me to believe someone else did it for him. Maybe grammar is to blame here? 🤷*♂️
05-03-2024, 06:20 PM | #13 | |
2040
Rep 5,100
"I installed ARM Catless Downpipes on my G82 M4 Competition 2024." I would hope a shop wouldn't have to resort to the customer reaching out for help on the forums for o2 wiring.
05-03-2024, 09:24 PM | #14 |
Rep 389
Unplug everything being sure to disconnect negative battery terminal first. Trace every wire to the correct spot. Might be annoying because you may have to take off the bottom shield with its 40,000 bolts. Installing the downpipes is straight forward so the only issue would be wiring.
05-06-2024, 01:55 PM | #15 | |
2040
Rep 5,100
Yesterday, 11:37 PM | #16 |
Rep 172
So what was the final verdict to this issue? Curious to know 🤔🤔🤔
