05-20-2024, 01:30 PM | #1 |
Rep 442
Track-focused coilovers
Is anyone aware of any vendors that offer either coilovers or separate damper/spring setups that are track-focused? I'm not talking a hybrid street/track, like KW V3 or even Ohlins R&T. I'm talking something more along the lines of a KW Clubsport (which doesn't appear to be offered).
Closest I can find is the Bilstein Evo R, but I've seen no information on folks running these. Otherwise seems like Ohlins R&T with a different spring is the best we have if we want to skew towards track performance versus street? |
05-20-2024, 05:03 PM | #2 | |
Rep 1,534
https://3dmmotorsport.com/products/b...uspension-kits
05-20-2024, 06:22 PM | #3 | |
Rep 442
05-20-2024, 07:09 PM | #4 |
Rep 1,534
*JRZ
Apologies, did not see my typo. I would contact them. https://www.jrzsuspension.com Another possible outlet is MCS.
05-20-2024, 08:15 PM | #5 | |
Rep 442
I've accepted I need another vehicle to daily, but I need to decide this year if I stick with this platform for a plated track/weekend car, or if I move to something more "traditional" and proven like an E46. There's something to be said about being unique though. |
peelerec1419.50 |
05-20-2024, 08:24 PM | #6 |
Rep 138
I'm replacing my Ohlins with 2-way remote JRZs. Spring rates are similar to competition spec Supras. I'm working with Shaftworks USA to get them revalved. It's uhh not cheap, so I recommend going with a more modest setup.
05-20-2024, 08:44 PM | #7 |
Rep 1,534
Chris, you are pioneering the G20 track platform for us all
05-21-2024, 09:21 AM | #8 |
Rep 442
05-21-2024, 06:39 PM | #11 |
Rep 138
Nah, the braking is more than sufficient. If I ever add power (doubtful) or aero (doubtful), then I'll consider a BBK. The gains from it will be so marginal, and the cost will be as much as my suspension. I could also run into clearance issues.
05-21-2024, 07:18 PM | #12 |
Rep 442
Anything to help with brake cooling? I know there’s kits for the G8x and I wouldn’t think they’d be too difficult to mod for our cars, or even fabricate something to replace the existing dust shield and use tubing to connect to our OEM ducts.
05-21-2024, 11:18 PM | #13 |
Rep 138
You can either try girodisc rotors, or experiment with a couple kits that are out there.
Specifically, speed engineering in Germany makes a kit for G8X (). The entire kit won't fit, but comparing part numbers, it looks like the brake air duct for the G20 is the same as the G87, so it's possible that their air duct adapter will fit. You can then reach out to Verus and see if you can buy their dust shield for the A90 since that will 100% fit our car (https://www.verus-engineering.com/sh...ota-supra-1956). All this assumes the hose is the same, which should be. |
05-22-2024, 01:12 AM | #14 | |
Rep 1,534
Perhaps it’s your track that forces you to be heavy on the brakes?
05-22-2024, 09:12 AM | #15 | |
Rep 442
I haven't inspected my brakes/swapped for daily pads yet to see if there's any ill-effects, but I don't want to have to be constantly replacing pressure seals and dust boots because they cannot handle the caliper heat. I'm also concerned about tracks like Road America that have multiple very long straights with heavy, heavy braking into 90 degree turns. |
05-22-2024, 09:44 AM | #16 |
Rep 138
I've done laguna seca a bunch of times last year and earlier this year, and that track has lots of heavy and downhill braking zones. When I was on CSG street pads, they couldn't handle the braking very well, and I think the compound degraded or something because it became noisy on the street, the rotors would get tons of deposits, and thus lots of pedal vibration. When I upgraded to CSG's sprint pads, I no longer have those issues. They're not kind to my rotors though (lots of micro cracks), but that's fine since the FCP euro strat for replacing rotors is very cost effective.
That said, my calipers have retained their blue. |
05-22-2024, 09:52 AM | #17 | |
Rep 442
05-22-2024, 01:08 PM | #18 | |
Rep 1,534
05-23-2024, 09:49 AM | #19 | |
Rep 442
I guess I need to look into brake cooling as my first priority after rebuilding. Probably will try Ti shims, cobble together a duct cooling kit and throw in an extra cool down lap with driving around the paddock for 5 minutes afterwards. |
05-30-2024, 05:37 PM | #20 | |
Rep 442
chrispy28_xd101.00 |
05-30-2024, 06:33 PM | #22 |
Rep 442
Will do. Both my front inside pads wear a bit more than the outside, and have since Day 1, so I suspect the cooling solution we have stock isn't effective. We'll see.
