Technical Topics Suspension / Chassis / Brakes 330i MSport Brakes
      09-14-2024, 01:47 PM   #1
BeeEhmWie
BeeEhmWie's Avatar
Drives: 2024 G20 330i MSport Tanzanite
330i MSport Brakes
Hi there,
I’ve got a ‘24 330i with the optional Msport brakes.
Is it just me or are the brakes very touchy and nonlinear on initial application? Like the first couple % is smooth then it ramps up big time then it becomes linear again.
Is it the master cylinder?
Is it the power brake assist?
Is it a mismatch between the bigger brakes and a (maybe) stock 330i master/power brake system?
Must be super careful on initial brake to go over the 5-10% “hump” in brake application smoothly. Super whack, it should be perfectly linear.
My Corolla had nicer brake pedal application, just shitty small brakes.
      12-04-2024, 07:17 PM   #2
Jerolec
Drives: 330i Xdrive
I have a 2019 with the Msport brakes too and they are very sensitive at low speed and a bit vague when braking strongly at 50mph+ speed.
My theory is that at low speed they are very sensitive but what's making them non-linear is not the brake themselves but the engine braking effect used to recharge the battery. When the transmission is downshifting from 3 to 2nd and 2nd to 1st you really can feel the engine braking and that is creating the non-linear feeling on the brake pedal and even the car lurching (pretty ordinary for a nice car like that I would say).
Pay close attention when you slowdown to a stop and look at the battery icon in your cluster when the car downshift.
      12-07-2024, 10:19 AM   #3
cyam
Just the pads. Different pads can eliminate this.
      12-08-2024, 03:10 PM   #4
Jerolec
Drives: 330i Xdrive
You experienced this with OEM pads? They had changed discs and pads when I bought the car. I thought the twitchy feeling would have desapeared over time or after the break in period but no. Might worth trying while the discs are not much used.
      12-09-2024, 04:20 AM   #5
helmet91
helmet91's Avatar
Netherlands
390
I went from the stock 1-piston gray brakes to M-Sports - I also had Turner stainless lines installed while using RBF660 fluid. On stock pads and discs the setup has been fantastic.
He has a 2024... it seems OEM and iSweep are the only options for the revision thus far.
      12-09-2024, 07:46 PM   #6
BeeEhmWie
BeeEhmWie's Avatar
I played around with it. It’s mainly the transmission. If I put it into neutral it’s more linear. Sometimes the engine braking / clutch engagement is strange when getting on the brakes initially.
However when in neutral and then applying the brakes while coasting, it’s still touchy but more linear.
Also, while the brakes are touchy, when you actually lay on them the stopping power isn’t that great, it falls off in linearity.
A lot of initial bite but not a lot of actual power.
      12-09-2024, 07:47 PM   #7
BeeEhmWie
BeeEhmWie's Avatar
Hopefully less initial bite but still solid friction
      12-09-2024, 08:25 PM   #8
Jerolec
Drives: 330i Xdrive
Same experience on my 2019 with M sport brakes. Will change the pads for probably Project MU PS and see if there's a difference in the initial bite and hard stop. Will let you know in a month or so.
      12-16-2024, 07:45 AM   #9
snekjumpr
Drives: M340i xdrive
Ceramic brakes should solve the initial bite issue caused by the OEM semi-metalics and eliminate jerky stops. I'm still on the fence between the iSweep 1500 and 2000s...
      12-16-2024, 02:02 PM   #10
BeeEhmWie
BeeEhmWie's Avatar
Good suggestion
