Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Supposedly Stock BMW M340i Requesting 24 PSI Boost
      10-25-2024, 04:54 PM   #1
mttbrd
Drives: BMW M340i 2022
Hello everyone,
I bought a second-hand 2022 BMW M340i from a BMW dealership, with a warranty until 2027.
My car was supposed to be stock, right? So I bought a JB4, and I noticed that when I activated map 2, the car was reaching 29.5 PSI. I did a datalog on map 0, and the ECU is actually requesting 24 PSI at full load.
Oh, one more information, I tried to use bootmod and the APP says that my ECU is locked.
What do you guys think?
      10-26-2024, 10:19 AM   #2
20M340i
20M340i's Avatar
37
Drives: 2020 BMW M340i
That seems like a lot but I know on mine once you get past the first few gears my factory 20psi gauge is pinned and I’m still on the stock tune.
      10-26-2024, 10:53 AM   #3
totalone
Drives: x5 e45, M440
You should never get that much psi. 29 is way too high. Are you sure you looking at proper parameters?
There are multiple boost indicators
Boost1 and boos2
Boost at charge pile abd boost st mainfold
Also what you request and what you get can be different things. I don't think anyone running 24psi on stock. These turbos pretty much dead after 23psi, they can't really handle it.
Look for timing corrections. If you running that much boost on 93, you probably pulling timing
Current: 2022 BMW M440gc / 2022 BMW x5 45e
      10-27-2024, 01:57 PM   #4
mttbrd
Boost1 and boos2
Oh lord, sorry, I'm a newbie.
I was only looking at boost1. I checked again, and boost2 is reaching a max of 21.3 PSI on MAP 0 (stock). That seems a bit high for a 'stock' car.
      10-27-2024, 05:21 PM   #5
totalone
I think that is ok not too much. in what gear was it requesting 21?
      10-28-2024, 04:49 AM   #6
cyam
Hello everyone,
Umm 29.5psi pressure is STOCK.
29.5 - 14.5 = 15psi boost, that's pretty much stock boost.
Don't confuse boost with pressure. Absolute pressure is boost PSI plus atmospheric pressure.
jpowers36274.50
