Technical Topics DIYs and Coding Discussions Yes! Bimmercode works partially with 2025 G20 LCI 2 (with iDrive 8.5)
      12-15-2024, 08:57 AM   #1
0xABADB01
Drives: BMW G20 LCI 2 (2025)
Hey, just want to share that I just managed to modify the following settings on my newly acquired 2025 G20 LCI 2 (the newest facelift introduced in 2024 which comes with iDrive 8.5)!
What don't work
- Modules that requires Secure Coding 2.0 -- notably the “Headunit” HU_MGU or “Headunit” HU_NBT_EVO control unit
- Auto Start Stop function memory {I have the start-stop button}
What works (Bimmercode Options that I tested to work)
+ Exterior lighting switch-off allowed {you can switch off the low beam but DRL remains on}
+ Ambient lighting color bottom (i-level 22-07 and later)
+ Ambient lighting color contour
Hope this information will help those with the newer LCI2 models!
Also, wondering if anyone could share more information about switching off the DRL when ignition is on. This feature is actually requested by the staff at my local drive-through manual car wash. Currently, I have resorted to switching off the engine to disable the headlights.
      12-19-2024, 06:59 PM   #2
M8fam
M8fam's Avatar
76
Drives: 2025 M340xi
Any workarounds for Auto Start/Stop memory? I really need this
      12-20-2024, 05:28 AM   #3
hrf
General
hrf's Avatar
Drives: BMW e46 M3, BMW M340i XDrive, BMW X3
Looks like we will stick with AAS button for now. Thanks that they at least brought it back, this was the main reason I cancelled my 2024 order and waited for 2025. I hate this so much, only inconvenience is to turn it off each time I start the car. Did you try coding Active Sound?
      12-20-2024, 07:08 AM   #4
0xABADB01
I don't have the Active Sound package, so didn't try it out.
Yes, fortunately, we still have the AAS button. It'd be perfect if the memory setting works.
hrf1195.00
      12-24-2024, 12:34 PM   #5
M8fam
M8fam's Avatar
76
Drives: 2025 M340xi
Anyone try to code out ASD on a 2025?
      12-29-2024, 09:16 PM   #6
rmedina
Drives: 2023 M340i
I just got around to using bimmercode for my 23 m340i ( I rarely drive the car ). I only wanted it to change it to start up in sport mode and change the interior color to red.
Question: I used the Bluetooth feature to connect. Is it normal for bimmercode to take 2 1/2 minutes to read the ecu and an additional 2-3 minutes to do the actual coding? Of course when looking at the youtube videos it takes seconds to code. Thanks
      12-30-2024, 02:07 AM   #7
hrf
General
hrf's Avatar
Do you guys know when headunit coding will be available? I just coded seatbelt continuous warning and trunk close with remore. Need to remove annoying disclaimer message on starting.
      01-04-2025, 01:48 AM   #8
omalley72
Drives: 2026 X5 M60i
Might be a dumb question…how do you know if you have active sound?
      01-04-2025, 01:17 PM   #9
M8fam
M8fam's Avatar
76
Drives: 2025 M340xi
Most newer BMW models have Active Sound Design (ASD), a feature that amplifies the engine sound and plays it through the car's speakers:
  • M performance models: The BMW M240i, BMW M235i, and other M performance models are known for having fake engine noise.
On the M340s the ASD is pretty aggressive imo. You can definitely hear it from the speakers.
      01-04-2025, 02:37 PM   #10
hrf
General
hrf's Avatar
I have it and i do not feel that it is that agressive. It compliments well my MPE. It would be good to have an option to turn it off, but unfortunately of you turn off from IDrive it actually affects the flap and reduces all good sound from the exhaust.
      01-04-2025, 11:12 PM   #11
omalley72
Hmmm, okay. I just ordered an amp from BimmerTech, I wonder if it bypasses that feature.
      01-14-2025, 09:26 PM   #12
rmedina
Drives: 2023 M340i
Bimmercode seems to be very limited with the LCI. I wanted to disable the "heated steering wheel" when using remote start. This option does not come up for my 23. Bimmercode's websites states it comes up, but there's nada.
      01-20-2025, 11:23 PM   #13
UnrealM
UnrealM's Avatar
103
Drives: 2025 M340
I coded out ASD on my 2025 with Bimmer code. The ASD button in ID8 now only controls the exhaust valve.
hrf1195.00
      02-20-2025, 10:13 PM   #14
Mashour
Mashour's Avatar
Drives: 2025 g20 m340
Was anybody able to successfully code off Auto Start Stop for idrive 8.5? Feature is super annoying on my 25 m340
      02-21-2025, 02:05 AM   #15
hrf
General
hrf's Avatar
No, it is not available to code. At least we have a button in 2025
      07-16-2025, 01:11 PM   #16
Frans
Drives: 520i G30 2020
How did you do that???
Can you tell us how you coded the exhaust flap?
      07-18-2025, 01:22 AM   #17
XaleriaN
Drives: 320i - G20 LCI 2
Hello, is it possible to code Sport+ and Comfort+ on ID 8.5 with using Bimmercode?
      07-26-2025, 04:46 PM   #18
UnrealM
UnrealM's Avatar
103
Drives: 2025 M340
You have to buy the MHD OBDII connector. Download Bimmer code connect to the car. There will be an option labeled Activ Sound Design. Flip it from ACTIV to INACTIV for everything (Upshifts, downshifts, startup, etc.)
If you get comfortable with Bimmer code, you can go in expert mode and just delete the code one time. Do this at your own risk.
2025 M340i - Xdrive
      07-29-2025, 09:39 PM   #19
Equilibrandt
Auto/DCT Zealot
Equilibrandt's Avatar
Drives: Miata, M340iX, Telluride
I just tried today on my 2025 M340ix; inside BimmerCode, there's no option to code anything related to the HeadUnit (HU). I can half-code Comfort+ (in the BDU) but can't do the other Comfort+ enable step (in the HU_MGU).
- 2025 BMW M340i xDrive / Vegas Red
- 2024 Kia Telluride SX Prestige X-Line
- 2020 Mazda MX-5 Grand Touring / Machine Grey / Soft Top / (Awaiting CARB-EO) Edelbrock Supercharger
      07-30-2025, 12:18 AM   #20
Equilibrandt
Auto/DCT Zealot
Follow up for those of use with ID8.5, as I started using BimmerCode for the first time today.
I'll need someone with ID8.5 and BimmerUtility (not BimmerCode) to confirm that we can't touch certain things (to verify that they're locked, not simply missing from BimmerCode but available in BimmerUtility).
Even though https://bimmercode.app/cars/g20/ lists a bunch of features that would be cool to code, it appears that ID8.5 has a bunch of locked ECUs. A lot of the cool features require activation in two spots, one of which is almost always locked.
Here are the ECUs you can touch:
That means you can code:
  • BDC_Body3 - Ambient Lighting, Ready-to-Drive tone, horn when you lock the car with it running, window lifter when door interrupt, default driving mode, mirror tilt angle,
  • RAM - Signal Tones for PDC, gong, telephone, and blinker (Rolls-Royce, BMW, BMW 2021 [Default], MINI)
  • ACSM_5 - PDC and Rear Camera shut off speed and range, seatbelt reminders,
  • HKFM_2015 - tailgate commands, speeds, button presses or pulls,
You cannot code:
  • (Head Unit) HU_MGU or HU_NBT_EVO - tons of stuff like Comfort+ or Comfort Individual, start up warning deletions, start animations, tire widget, sport displays
  • (Instrument Cluster) DKOMBI4 and KOMBI_CT_RD1 - instrument cluster layout, logo, screen refresh rate, start logo, etc
It's a shame that the HU options are locked, as they're half of Comfort+/Comfort Individual, as well as enabling Sport+ damping and steering as a menu option in Sport+.
TLDR: if you scan https://bimmercode.app/cars/g20/ for stuff you'd like to code in your ID8.5 car, there's a good chance you cannot touch any Head Unit nor Instrument CLuster options, or any options that require activation in multiple places (like Comfort+ in BDC and HU).
      07-31-2025, 10:06 AM   #21
Equilibrandt
Auto/DCT Zealot
For idrive 8.5, from a bimmerpost user/coding service:
Originally Posted by Equilibrandt View Post
According to https://chris3g.com/:
Secure Coded/Locked:
- HU, KOMBI, DME, EGS, WAVE, others
Unlocked/Code-able:
- BDC, ACSM, FLM, HKFM, DSC, EPS, RAM, others
Unsure about KAFAS, we'll see what he says.
      08-09-2025, 09:55 PM   #22
Kbpolaris
Drives: 2025 M340 Dravit Gray
2025 BMW M340  [0.00]
Will BimmerCode eventually be able to unlock more modules in IDrive 8.5?
