| 01-02-2025, 11:48 PM | #1 |
Rep 5
2020 G20 M340i 600hp Roadmap Advice
Hey guys,
Been lurking here for a while getting tips here and there, now looking for a bit of advice. I'm looking to take my 2020 M340i xDrive to 600+whp and wondering if anyone can chime in on what's needed vs what's not, different routes in terms of port injection, tunes etc.. Now I'm not the most knowledgeable person around when it comes to modding the b58 or in general so some of these things may not be needed with the other mods but bare with me. Goals - Get 600whp with as much reliability as possible. Be able to run 98 everyday and switch to e85 for track use. Do the above as cost effectively as possible (Haha) This is what I've put together so far (All prices are in AUD) FTP Charge Pipe - $450 PURE900 Turbo - $6250 PRW Stage 2 LPFP - $1000 DORCH DS25 HPFP - $3000 (Needed?) ArmaSpeed Full Carbon Intake - $2100 Wagner or Project Gamma Intake Manifold w/port injection - $4250 / $3250 (Needed? / Difference?) Flex Fuel Kit (Needed?) NGK Plugs + Labour - $1000 Custom Stage 3 ECU+TCU Tune - $2500 Total - $19,500 *Note - car already has a aftermarket valved exhaust system. Please pull apart my list and let me know anything I've missed/don't need, anything thats overkill for the goal or different routes i could take this given the goal, post is pretty open ended i know but appreciate any help anyone can give. Cheers Last edited by PEAK340; 01-03-2025 at 01:12 AM.. |
| 01-03-2025, 12:55 AM | #2 |
Rep 618
Drives: 21' M340iX, '25 M340iX
Unless you have that "eff you" money, I would recommend that you watch some youtube videos on how to install spark plugs, your intake, HPFP, charge pipe (etc) if you're going to modify your car. Unless you're just going for bling, you don't need a carbon intake and could go for an MST or similar. You can make 600hp on a pure 800 or 850, spend less money, and possibly spool faster and have a more usable powerband. In my limited experience, larger turbos spool later, hit harder once they do, and become a bit less streetable. Which turbo you go with will really depend on how you want your car to drive, and if you're able to hit that 600hp number on pump and E. To give you a rough idea, M340s on e50 with stock turbos make around 520hp/tq-ish depending on DA/conditions.
| 01-03-2025, 01:06 AM | #3 |
Rep 5
Yeah i could definitely do the intake, HPFP, charge pipe etc.. myself as i did some similiar mods on my 330i.
Was more thinking if I'm getting all this done and its going to be in the shop anyway for the sake of an extra $500ish might as well get them to do it all at once haha but your 100% right. Thanks for the recommendation with the turbo. |
| 01-03-2025, 02:28 PM | #4 |
![]() ![]() ![]() ![]() 291
Rep 681
I would suggest some cooling mods, like larger radiator, auxiliary cooling radiators, etc
Also, you will probably need a transmission if you plan to “use” the car after the mods : ) |
| 01-03-2025, 04:20 PM | #5 |
Rep 531
Drives: 2025 M340i XDrive
For a reliable setup to run 600 hp on E85 (and potentially push closer to 750 hp), consider the following components. Also, you can save significantly by doing much of this yourself:
FTP Charge Pipe: $450 PURE850 Turbo: $3,200 Precision Raceworks Stage 2 LPFP: $650 B58TU HPFP: $450 (Yes, this is essential) MAD Intake: $400 Precision Raceworks Port Injection: $1,450 Motiv Re|Flex+ and all necessary connections for E85: $1,300 NGK Plugs: $85 Custom MHD Tune: $1,200 xHP Transmission Tune: $315 Pure Stage 1 Transmission: $6,000 Wagner Tuning Radiator: $1,250 CSF Auxiliary Oil Cooler: $300 Total: $16,050 |
| 01-03-2025, 07:48 PM | #9 |
![]() ![]() ![]() ![]() 357
Rep 991
Sorry, not quite up to date with market now. Is it going to be that much more expensive?
Also, I don't think you'll enjoy it as much, like driving dynamics etc... again this is just a guess.
Current: 2022 BMW M440gc / 2022 BMW x5 45e
| 01-03-2025, 11:10 PM | #11 |
Rep 991
70k for 2020 m340????
| 01-04-2025, 12:05 AM | #13 |
![]() 76
Rep 112
Drives: 2025 M340xi
How badly do you want 600whp haha. 500whp is downpipe and a e50 tune. Fairly cheap
| 01-04-2025, 06:56 AM | #15 | |
Rep 5
Approx 5 year time frame (9-10 year old car) $125,000 > $75,000 M3 $70,000 > $30,000 M340 Total "loss" is approx 40-50k either way, if anything higher loss for the M3. And that's only if either car is still relatively low in kms. Last edited by PEAK340; 01-04-2025 at 07:31 AM.. |
| 01-04-2025, 11:52 AM | #16 | |
Rep 618
| 01-08-2025, 04:30 PM | #17 | |
BMW Enthusiasts
55
Rep 46
Drives: BMW G20 M340i pre-LCI
| Bookmarks |
