2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Cold weather warning below 37 degrees?
      01-16-2025, 12:40 PM   #1
Smudge
Drives: BMW M340i
Where I currently live it has been about 20 degrees each morning. I am relatively new to BMW's. At what point should I get the cold weather warning? I can never remember seeing this warning/alert. Thanks!
      01-16-2025, 01:01 PM   #2
jg4c
jg4c's Avatar
452
Drives: 2022 M340i XDrive
I get it every time I start the car when
outside temp is below 37 degrees F.
Try resetting Idrive.
      01-16-2025, 02:10 PM   #3
Elderado82
Elderado82's Avatar
151
Drives: 2025 M340i XDrive
The warning might be turned off in the settings. I believe it's located under "Vehicle Settings," then "Climate Settings." In there, you should be able to enable the "Cold Weather Warning." Hope this helps.
      01-17-2025, 09:45 AM   #4
aidanmurphy
Drives: BMW M340i RWD
Lol gives me a bit of a freak every time it comes on, but it is endearing!
      01-17-2025, 10:01 AM   #5
RCKYMTN M34OI
BMW has had this warning on vehicles for decades now. My 01' 330 has it also. Supposedly 37* is the magic temperature that ice can form and road conditions are affected. I've never looked to see if you can disable it.
      01-17-2025, 07:59 PM   #6
thestumper
thestumper's Avatar
23
Drives: 2024 BMW 330i xDrive
It's my constant reminder that I still live in this Northern poop-hole. It motivates me to look to properties in a warmer climate. At this point it's daily
Three. More. Years.
      01-18-2025, 03:24 PM   #7
brianeck
brianeck's Avatar
1035
Drives: 2022 M340ix Mineral Grey
This note is to let you know that if you're on the stock summer performance PSS tires that they have officially turned into hockey pucks and will be attempting to eject you from the road.
BMWbiker774.50
MoeTE871328.00
