01-22-2025, 01:58 PM | #1 |
Rep 3
Drives: G21 318i, F48 X1 20i sDrive
Location: Germany, Cologne Area / Netherlands, Enschede
Guide on retrofitting shifter paddles on non wired G20/G21
Retrofitting Paddle Shifters to a Non-Prewired BMW G20
When I decided to retrofit paddle shifters to my BMW G20, I couldn’t find a complete guide tailored to non-prewired vehicles. After successfully completing the process, I wanted to share my experience so others can benefit from clear instructions and avoid guesswork. This guide includes detailed steps and clear explanations to make it easy for everyone, even novices, to follow. As a side note, I was unable to find a ready-made cable online for this retrofit. To solve this, I worked on creating a suitable product, now available at my store, Motorsport Werk. I also offer optional remote coding services to simplify the final step, but please know this guide is meant to help anyone, regardless of where they choose to source parts or services. Preparation Before starting, gather the following tools and materials: Parts & Services:
Tools:
Safety: Disconnect the battery before beginning to avoid electrical damage or airbag deployment risks. Step-by-Step Process Step 1: Access the BDC Module The Body Domain Controller (BDC) is located in the passenger footwell. Follow these steps to access it:
Step 2: Access the SLZ Module To connect the other end of the cable to the SLZ: Remove the Steering Wheel:
Access the SLZ Connector:
Insert the Cable Pin into Pin 3:
Step 3: Route the Cable To connect the BDC to the Steering Column Module (SLZ):
Step 4: Reassembly
Step 5: Coding For coding, you need to update the Vehicle Order (VO) to include 2TB (Sport Automatic Transmission), replacing the standard 205. If you prefer to code the car yourself, tools like Esys can be used. Why I Wrote This Guide I wrote this guide because I couldn’t find clear instructions for retrofitting paddle shifters in a non-prewired BMW G20. I’ve also worked on making this process easier for others by offering a compatible retrofit cable and coding services. However, I want to emphasize that this guide is intended to help everyone, regardless of where they source their parts or services. My goal is simply to share what I’ve learned and make this upgrade more accessible. Tips & Additional Notes BDC and SLZ Pin Locations: The BDC connection goes into Pin 5, while the SLZ connection goes into Pin 3. Both connectors are numbered at Pin 1 with a big "1" for easy identification. Refer to the attached image for the SLZ pin layout. Cable Management: Take your time routing the cable to ensure it’s neat and secure. Avoid sharp bends or interference with moving parts. Testing: After reassembly and coding, test the paddle shifters in manual mode to ensure they’re functioning correctly. Important Note: Options for Retrofitting Paddle Shifters on a Non-Prewired G20 For anyone following this guide, I wanted to share some additional information to help you plan your retrofit. Depending on your current setup and preferences, there are two main options for adding paddle shifters to your G20: Option 1: Retrofitting Paddle Shifters to Your Existing Steering Wheel If you want to keep your current steering wheel:
Option 2: Replacing Your Steering Wheel with a Pre-Fitted Paddle Shifter Wheel Alternatively, you can purchase a steering wheel that already includes paddle shifters:
Final Tips
Feel free to ask any questions or share your experiences—happy retrofitting!
Motorsport Werk
BMW Retrofitting, Coding & Custom Solutions 📍 Based in Germany & Netherlands – In-person services and shop available 💻 Visit us: motorsport-werk.com Last edited by Motorsport-Werk; 01-22-2025 at 02:07 PM.. |
