2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Touch-up paint options
      03-11-2025, 08:14 AM   #1
willougs
willougs's Avatar
313
Drives: BMW 330e
I have a pretty deep, small'ish (5mm long) chunk taken out of the paintwork on my drivers door, just below the mirror. I have an unopened official BMW touch-up set, which seems to consist of a paint pen and a lacquer. Now, I'm not the most patient, hands-on DIY'er, so was looking around for alternatives that can be applied in a single go, as simple as possible.
I checked Chipex and their kit seems overkill (and pretty pricey), and could probably start up my own bodyshop with the equipment needed.
Has anyone ever used an alternative to BMWs official paint and had good results? Is the Chipex solution worth the 40 quid and close to fool-proof? Car is Black Sapphire if that makes any difference.
Thanks in advance
For cheaper charging, switch to Octopus Energy using this link and get £50 free credit
      03-11-2025, 10:04 AM   #2
xenon
xenon's Avatar
1570
Drives: 2025 ID.7 Pro Touring
Use the proper BMW one, it's quite easy even if you're a bit cack-handed but you're right in that it's two-step. Clean the scratch, ideally with an alcohol wipe, and then very gently "fill" the scratch with the base colour by dabbing it in with a wooden cocktail stick - IME the brush is too big / coarse. Leave it a few hours and then repeat with the clearcoat. You'd be surprised how well you can make a small scratch like that almost invisible. 5mm is small enough for the lease company not to kick up a fuss if it's going back.
Ian
Current: 2025 ID.7 Pro Touring
Previous: 2021 G21 330i, 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
willougs312.50
Tommo3166.50
      03-12-2025, 06:45 AM   #3
lnlyssg
236
Drives: BMW 320i
I've used Chipex on my Black Sapphire to touch up loads of paint chips on the bonnet and a couple of minor scuffs on the doors and I'm happy with it. CHIP10 gets you 10% off but there may be other codes available.
quick edit: plenty of reviews on YouTube if you want to see some real-world examples e.g.
I've also seen https://www.drcolourchip.co.uk mentioned but that's even more expensive!
willougs312.50
      03-12-2025, 09:48 AM   #4
alFR
Drives: BMW 3 Series
There seem to be quite a few alternatives about now (I've been looking as I need to touch up a chip on mine):
  • Official BMW 2-part kit (if they supply in your colour - I understand they don't for some e.g. Skyscraper grey which is my colour, not asked the dealer yet though).
  • Chipex 1-step system (paint and blending solution)
  • Dr Colourchip 1-step system (paint and blending solution)
  • Paintnuts.co.uk 2-step system (paint & lacquer)
  • Touch Up Paint Factory 1-step system (mix of paint and clear coat in 1 applicator)
No idea if any of them is better than the others, although my gut feeling is that a 2-part paint and lacquer system is going to be more durable than a 1-step system. I have no evidence for that though!
Be interested to hear how you get on with whatever you choose.
willougs312.50
      03-12-2025, 11:13 AM   #5
willougs
willougs's Avatar
313
Drives: BMW 330e
quick edit: plenty of reviews on YouTube if you want to see some real-world examples e.g. https://www.youtube.com/watch?v=NWuhDucj4Aw I've also seen https://www.drcolourchip.co.uk mentioned but that's even more expensive!
That's really useful. Thanks. Gives me an idea what I'm in for if I go that route (and probably other routes too). The scratch I have is pretty deep, so looks like it may be taking me a while
      03-12-2025, 12:56 PM   #6
Bianchi Dave
432
Drives: G21 M340i
Another one for Chipex. Nothing comes close IME. It lasts for ages but if you do ever need extra blending solution they do sell it separately so no need to buy another full kit.
Bigger chips or deeper scratches just require some patience, with plenty drying time between coats to 'build up' the paint.
A word of warning though if you have a ceramic coating - I've only had to use it once since my G21 was ceramic coated and it did not play well with the little blue 'blending cloths'. Marred a small section of bonnet which required a revisit to my detailer
Works perfectly fine otherwise, as I also use it on our Mini, which has no ceramic
willougs312.50
