| 06-22-2025, 10:08 AM | #1 |
![]() ![]() ![]() 281
Rep 538
Drives: Sold - e90 335
M440i Square or Staggered Tire Size?
I'm working on my build for an M440i and was wondering what the pros and cons are of a square vs a staggered tire setup.
Looking at an AWD if that has any benefit. |
| 06-23-2025, 01:09 AM | #3 |
Rep 41
Drives: Future car: 2025 M440i Gran Coupe in Dravit Grey
| 06-23-2025, 11:46 AM | #5 |
![]() ![]() 308
Rep 367
If you are thinking tire rotation to balance out front vs rear tire wear, with an AWD car as OP is getting, front vs rear tire wear is not as pronounced as you probably had with your RWD IS350F.
| 06-23-2025, 11:59 AM | #7 |
Member
98
Rep 135
Not true as my ‘26 M440i is 19” square. I think when 19” all season tires are ordered it will be square and 19” summer tires will be staggered at least on the coupe version. Looks like the BMW configurator has staggered for both tires for GCs though.
‘26 BMW X3 M50
‘26 MINI Cooper JCW ‘26 Ford F-450 Lariat 6.7L PS HO Last edited by Van1; 06-23-2025 at 12:08 PM.. |
| 06-23-2025, 04:46 PM | #8 |
![]() ![]() ![]() 309
Rep 518
This, besides BMW does not recommend rotating tires (and I can totally agree).
| 06-23-2025, 06:06 PM | #10 | |
Rep 92
Another reason to rotate is that many tire warranties require rotation. |
snekjumpr439.50 |
| 06-25-2025, 12:20 PM | #11 |
![]() 43
Rep 77
| 06-25-2025, 12:36 PM | #12 |
![]() 43
Rep 77
When I chose wheel options it had two choices for the Black 995's. Staggered and not staggered. My build sheet shows 1HH for squared. Staggered is 1HF.
| 06-25-2025, 12:44 PM | #14 |
![]() 43
Rep 77
Clarification on rotating. I have an RWD on order and I live in California where we have 2.5 seasons. Rain is a memory and a government conspiracy on some days.
| 06-27-2025, 08:23 AM | #15 |
![]() 188
Rep 298
I have staggered on my RWD M340i and wouldn't change to squared. Yea rotating the tires is nice but the aesthetic is nice and as RWD the extra traction in the back is necessary
| 11-20-2025, 08:52 PM | #16 |
![]() 5
Rep 127
Recently swapped from a M235i to a '25 M440i G2x. Today, some dude was watering his lawn and I turned onto the main street and the little bit of water on the road caused me to lose traction at like 15-20 mph from a stop going around the corner.
I looked at my tires this evening...they're square 225/40/19s. Really BMW? Who approved this nonsense? Coming from my staggered M235i, there seems to be significantly less traction in the rears....and the tires are brand new. This never happened in the M235i. |
| 11-21-2025, 01:28 AM | #17 | |
![]() ![]() ![]() 378
Rep 438
| 11-21-2025, 12:53 PM | #18 | |
![]() ![]() ![]() ![]() 709
Rep 821
| 11-21-2025, 01:13 PM | #19 |
Rep 527
Drives: 2025 M340i XDrive
235/40R19 non‑run‑flats are a solid choice. You’ll get a wider contact patch and a bit more sidewall compared to stock, which helps both grip and ride quality.
Keep in mind the xDrive system isn’t pure RWD; there’s always some power going to the front axle, unless you flash the transmission with xHP. Running the same size front and rear usually works best on AWD cars. If you go wider in the back than the front, you’ll increase rear grip relative to the front, which tends to create understeer. A square setup keeps the handling balance more neutral and makes rotation easier, especially if you plan on pushing the car. Plus, it keeps the xDrive happy and reduces wear and tear. |
snekjumpr439.50 |
| 11-22-2025, 09:22 AM | #20 | |
![]() 5
Rep 127
Yes, they are the no-season tires - which I haven't driven on in over 10 years. Last edited by Firebirdof06; 11-22-2025 at 09:41 AM.. |
| 11-22-2025, 10:16 AM | #21 |
Rep 518
Elderado82631.00 |
| Bookmarks |
