2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions BMW G20/G22 Service Bulletin List
      08-26-2025, 11:37 PM   #1
analogue
analogue's Avatar
Drives: 1M, iX
Here you will find all of the service bulletins BMW has submitted to NHTSA for 3 and 4 series (G20/G22). Bulletins usually take several weeks to appear in the NHTSA database after they are published internally in BMWTIS.
This thread will be updated with recent bulletins after they land at NHTSA and a reference is published here: https://itsanalogue.github.io/bmw-tsb/G20.html. You can find all of this information on the NHTSA website if you know where to look, but this is a consolidated list and should help search engines find and index the SIB PDFs faster.
Appreciate 6
Gaviatrix239.00
CSBM53139.50
EXE462074.50
rmedina237.00
Kool3628.00
      08-26-2025, 11:37 PM   #2
analogue
analogue's Avatar
Drives: 1M, iX
Recent Bulletins
SIB 51 06 26 (2026-04-23)
BMW 430I 2022,2023,2024,2025,2026
(plus 2 other models)
STRUCTURE: BODY
While driving on rough surfaces, a “tapping” noise can be heard from the tailgate area
MC-11031566-0001.pdf
ReleaseNotes_2603_US_BMW (2026-04-13)
BMW 330I 2026
ELECTRICAL SYSTEM, UNKNOWN OR OTHER
This communication contains the Release Notes for the BMW 2026-03 Remote Software Upgrade.
MC-11031600-0001.pdf
SIB 32 01 23 (2026-04-06)
BMW 330E 2021,2022,2023
BMW 330I 2019,2020,2021,2022,2023,2024
BMW 430I 2021,2022,2023,2024
BMW M340I 2020,2021,2022,2023
BMW M440I 2021,2022
(plus 15 other models)
STEERING, SUSPENSION
When turning the steering wheel while stationary or when driving on uneven roads; cracking, creaking, or knocking noises may be heard.
MC-11031574-0001.pdf
InVeh-InApp-Comm (2026-03-25)
BMW 330I 2025
EXTERIOR LIGHTING, LANE DEPARTURE: WARNING
It was determined that the lane change warning in the exterior mirror may not light up bright enough. To correct this issue, the vehicle’s software needs to be updated.
MC-11030328-0001.pdf
BMW 430I 2025
STRUCTURE: BODY
There are body openings on the vehicle underbody, which are closed with paint plugs or adhesive pads. Your vehicle might not have been fitted with a paint plug on the vehicle underbody. Your vehicle will be checked for paint plugs on the underbody, and any missing paint plugs will be installed.
MC-11030321-0001.pdf
BMW 430I 2025
(plus 1 other model)
ENGINE
It was determined that due to a manufacturing defect, there may be a peeling of the sliding layer of the main bearing shells. The peeling may cause engine damage to your vehicle in some cases. The main bearing shells will need to be replaced.
MC-11030317-0001.pdf
BMW 430I 2025
ELECTRICAL SYSTEM
It has been determined that the Telematics Control Unit for the vehicle’s backup antenna may not have been programmed correctly. If the main antenna is damaged, the backup antenna may not be available due to the faulty programming. To correct this issue, the vehicle will need to be reprogrammed.
MC-11030315-0001.pdf
SIB 51 22 24 (2026-03-18)
BMW 330I 2024,2025
(plus 10 other models)
STRUCTURE: BODY, UNKNOWN OR OTHER
On the main door seal, detachment behaviorcan be detected at the sealing joint . Over time, the seal gradually and increasinglydetaches which can cause it to- Dangle Become visible to the customer Prevent the door from closing properly
MC-11030306-0001.pdf
SIB 65 08 26 (2026-03-16)
BMW 330I XDRIVE 2025
BMW 430I 2025
ELECTRICAL SYSTEM
After the software update to version …25-07-5XX, existing activation points for the “Automate My Habits”function no longer work.
MC-11030312-0001.pdf
SIB 65 04 26 (2026-03-16)
BMW 430I 2025
UNKNOWN OR OTHER
Customers may report issues with the alarm system not functioning correctly. These concerns may includeone or more of the following: Missing confirmation sound (function cannot be selected or deselected in the Central InformationDisplay (CID) menu). Alarm system deactivated (interior mirror light off). Alarm does not function. DWA LED without function after locking (no flashing/flashing). Acoustic acknowledgement is unavailable or cannot be enabled/disabled via the CID menu underdoors/windows. Tilt alarm sensor “SINE” cannot be reached via diagnostics.
MC-11030310-0001.pdf
SIB 01 03 25 (2026-03-06)
(plus 3 other models)
STRUCTURE: BODY
The Radiator Grilles Lower Active Air Flap Assembly limited warranty for defects in materials and/or workmanship has been extended to 15 years / 150,000 miles as determined from the original first in-service / delivery date.
MC-11030060-0001.pdf
SIB 65 27 25 (2026-02-11)
BMW 330I 2026
BMW 430I 2025,2026
(plus 13 other models)
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications
MC-11028927-0001.pdf
InVeh-InApp-Comm (2026-02-05)
BMW 330I 2019
SUSPENSION
It was found that the rubber mounts of the wishbone or the tension strut were not correctly pressed in due to a manufacturing fault at the supplier's end. This can lead to an acoustic abnormality in the vehicle.
MC-11029010-0001.pdf
SIB 31 01 26 (2026-02-04)
BMW 430I 2024
(plus 6 other models)
SUSPENSION
When driving over an uneven road surface, a “thumping” noise can be heard from the front axle. Seeattached video V 31 01 26. Under certain weather conditions, a “groaning” noise may be heard during steering movements
MC-11028921-0001.pdf
RECALL 26V056000 (2026-02-02)
Affecting 87394 total vehicles built between 2020-12-14 and 2022-12-14
BMW 330I 2021,2022,2023,2024
ELECTRICAL SYSTEM: STARTER ASSEMBLY
BMW of North America, LLC (BMW) is recalling certain 2021-2023 Toyota Supra, 2022-2023 2 Series Coupe, 2021-2024 5 Series (xDrive), 2021-2022 Z4, 2022-2024 4 Series (Gran Coupe), 2021-2024 4 Series (Convertible and xDrive Convertible), 2021-2023 4 Series (Coupe), 2021-2024 3 Series, 2021-2023 X4, 2021-2024 X3 vehicles. Please see the recall report for a complete list of all models. The engine starter may overheat and catch fire due to wear on an internal component.
RCRIT-26V056-2459.pdf
SIB 65 20 25 (2026-01-15)
BMW 330I 2025
BMW 430I 2025
(plus 11 other models)
ELECTRICAL SYSTEM
After replacing the Multifunctional Display (MFD), the Central Information Display (CID) is black. Thebacklight of the CID is illuminated, and touch function does register an audible sound.
MC-11027777-0001.pdf
SIB 41 07 25 (2026-01-08)
BMW 330I 2020,2021,2022,2023,2024,2025
STRUCTURE: BODY
While driving on a smooth and/or unevenroad, a “cracking” sound is heard from therear wheel arch area (highlighted in orange) on either the right or left side.
MC-11027766-0001.pdf
SIB 64 13 25 (2025-12-18)
BMW 330I 2024,2025,2026
BMW 430I XDRIVE 2024,2025,2026
(plus 5 other models)
ELECTRICAL SYSTEM
When performing a vehicle test, diagnostic trouble code “ 8013FE Software run time error” is found in theIHKA module. If this fault is set for two consecutive life cycles, it will turn on the check engine light on vehicles with an I-level lower than 24-11-570. This fault memory entry does not cause an impairment of functionality of the automatic air conditioningsystem.
MC-11026960-0001.pdf
SIB 34 09 25 (2025-12-17)
BMW 430I 2024,2025,2026
SERVICE BRAKES
There may be an internal leakage in the brake fluid expansion tank (aka brake fluid reservoir). In the rarecase of a leak, the filling level sensor might malfunction over a relatively long period of time.
MC-11026950-0001.pdf
SIB 11 10 25 (2025-12-12)
BMW 330I 2025
BMW 430I 2025
(plus 4 other models)
ENGINE
Coolant is leaking from the oil filter housing.
MC-11026946-0001.pdf
SIB 65 28 25 (2025-12-10)
BMW 330I 2026
BMW 430I 2026
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the Multifunction Display such as: Intermittent black screen Permanent black screen Intermittent head unit functions not displayed (i.e., Navigation screen only is black)
MC-11026964-0001.pdf
ReleaseNotes_2511_US_BMW (2025-12-02)
BMW 330I 2026
This communication contains the Release Notes for the BMW 2025-11 Remote Software Upgrade.
MC-11026705-0001.pdf
SIB 65 25 25 (2025-10-10)
BMW 330I 2025
BMW 430I 2025
(plus 7 other models)
ELECTRICAL SYSTEM
After the software update to I-level version …25-07-530, the Alexa app may disappear from the App Menu in the head unit (HU-H5).
MC-11024727-0001.pdf
SIB 84 06 25 (2025-10-03)
BMW 330I 2024,2025
(plus 17 other models)
ELECTRICAL SYSTEM
In some situations, an emergency call may be triggered in the vehicle without either the customer pressing the SOS Call button, or an airbag deployment event. In some cases, the customer may not even be inside the vehicle.
MC-11024211-0001.pdf
RECALL 25V644000 (2025-09-26)
Affecting 145102 total vehicles built between 2018-03-20 and 2025-02-11
BMW 340I 2020
BMW of North America, LLC (BMW) is recalling certain 2020 340I, X6, 2020-2025 840I, 2020-2022 740LI, 2019-2020 X7, and X5 vehicles. After repeated attempts, the starter motor may overheat from an electrical overload.
RCRIT-25V644-4636.pdf
RECALL 25V643000 (2025-09-26)
Affecting 4 total vehicles
BMW 430I 2026
ELECTRICAL SYSTEM: 12V/24V/48V BATTERY: CABLES, ELECTRICAL SYSTEM: WIRING: POWER DISTRIBUTION MODULE/IPDM
BMW of North America, LLC (BMW) is recalling certain 2026 M4 and 430i vehicles. The positive battery cables may not be properly connected to the power distribution box, resulting in an engine stall and a fire.
RECALL 25V636000 (2025-09-24)
Affecting 199674 total vehicles
BMW 430I 2021,2022
BMW 430I CONVERTIBLE 2021,2022
ELECTRICAL SYSTEM: STARTER ASSEMBLY: RELAY
BMW of North America, LLC (BMW) is recalling certain 2019-2021 BMW 330i, 2019-2022 BMW Z4, 2020-2022 BMW 530i, X3, X4, Toyota Supra, 2021-2022 BMW 430i, 430i Convertible, and 2022 BMW 230i vehicles. The engine starter relay may corrode, causing the relay to overheat and short circuit.
RCRIT-25V636-7824.pdf
RCRIT-25V636-7118.pdf
SIB 51 22 22 (2025-09-17)
BMW 430I 2021,2022,2023,2024,2025
BMW M440I 2021,2022
(plus 8 other models)
LATCHES/LOCKS/LINKAGES: HOOD: LATCH, STRUCTURE: BODY
Hood lever is pulled twice but the hood only achieves the pre-latch position on both sides.
MC-11024208-0001.pdf
SIB 65 19 25 (2025-08-26)
BMW 330I 2025
BMW 430I 2025
(plus 9 other models)
ELECTRICAL SYSTEM
Central Information Display (CID) in the vehicle is black or only displays “BMW”. The head unit (HU-H5) is not responding in ISTA. Additionally, the Receiver Audio Module (RAM), Instrument Cluster (KOMBI) and Telematic Module 4 (TCB4) may not be responding in ISTA.
MC-11022856-0001.pdf
SIB 41 04 24 (2025-08-20)
BMW 330I 2025
BMW 430I 2025
(plus 12 other models)
STRUCTURE: BODY
A groaning sound from the front of the vehicle while driving can be heard, particularly while cornering. The groaning sound can be heard in the A-pillar/instrument panel area.
MC-11022859-0001.pdf
SIB 51 03 24 (2025-08-20)
BMW 430I 2024,2025
STRUCTURE: BODY
While opening any of the doors, a groaning sound is heard from the door brake. Doors open and close stiffly.
MC-11022103-0001.pdf
SIB 84 05 25 (2025-08-13)
BMW 430I 2023,2024,2025
ELECTRICAL SYSTEM
SITUATION After the telematics module (TCB4) has been replaced, the replacement part control unit is not accepted byISTA.
MC-11022119-0001.pdf
SIB 51 12 23 (2025-07-02)
BMW 330I 2020,2023,2024,2025
STRUCTURE: BODY
After carrying out the vehicle test, one or more of the stored faults indicate that the operation of the front bottom active air flap is obstructed or blocked.
MC-11020911-0001.pdf
SIB 72 02 25 (2025-06-11)
BMW 330E 2021
BMW 340I 2020
BMW M340I 2021
AIR BAGS, ELECTRICAL SYSTEM
The Supplemental Restraint Systems (SRS) Front Passenger’s Seat Occupancy Capacitive Interior Sensor (CIS) Mat for defects in materials and/or workmanship that causes a false seat occupancy alert to occur has been extended to 10 years / 120,000 miles as determined from the vehicle's original in-service / first delivery date.
MC-11019576-0001.pdf
SIB 65 11 25 (2025-06-11)
BMW 330I 2025
BMW 430I 2025
ELECTRICAL SYSTEM
When navigation is selected, only the start animation with the text “Starting navigation system...” isdisplayed. The Navigation application does not start. This only applies to vehicles where Navigation hasbeen enabled and has been verified to work previously.
MC-11019572-0001.pdf
SIB 27 02 20 (2025-06-06)
BMW 330I 2019,2020,2024,2025
BMW 430I 2025
BMW M340I 2020
(plus 37 other models)
LANE DEPARTURE, POWER TRAIN, WHEELS
There is a jerking or shuddering during either or both of the following: Cornering or accelerating from low speeds Driving with low to medium loads
MC-11019579-0001.pdf
SIB 65 35 24 (2025-06-03)
BMW 330I 2024,2025
BMW 430I 2024,2025
ELECTRICAL SYSTEM
Customers may report that the Central Information Display (CID) side of the Multifunction Display flickersonce on and off. This flickering is not continuous but may occur once every 15 to 50 seconds. No fault memory entry is stored for this customer complaint.
MC-11019580-0001.pdf
SIB 66 07 25 (2025-05-30)
BMW 330I 2024
BMW 430I 2024
(plus 14 other models)
ELECTRICAL SYSTEM
The speed limit warning adopted speed, which is set by the customer, is automatically reverting to lowervalue after an extended duration of the sleep cycle.
MC-11018732-0001.pdf
SIB 12 05 25 (2025-05-24)
BMW 330I 2024
ELECTRICAL SYSTEM, ENGINE
Moisture may enter the start generator supply line and cause corrosion inside the line.
MC-11018723-0001.pdf
SIB 06 32 25 (2025-05-21)
BMW 330I 2024
BMW 430I 2024
VISIBILITY/WIPER
Inspection and Return - Linkage for Wiper System
MC-11018835-0001.pdf
SIB 65 15 25 (2025-05-20)
BMW 330I 2024
BMW 430I 2024
ELECTRICAL SYSTEM
When initiating a phone call to a specific saved contact, Intelligent Personal Assistant may not be able tolocate the contact or may call the incorrect contact.
MC-11018549-0001.pdf
SIB 01 04 25 (2025-05-19)
BMW 330E 2023,2024
ENGINE
The high-voltage battery assemblys refrigerant circuit expansion valves limited warranty for defects in materials and/ or workmanship has been extended to 15 years / 150,000 miles as determined from theoriginal first in-service / delivery date.
MC-11018560-0001.pdf
SIB 01 08 25 (2025-05-14)
BMW 330E 2020,2021,2022
STRUCTURE: BODY
A vehicle listed above may arrive with a Check Control Message (CCM), and/or malfunction indicator lamp(MIL) illuminated. After carrying out the vehicle test, one or more of the stored faults indicate that the operation of the front bottomactive air flap is obstructed or blocked. Thoroughly inspect the front bottom air flap, when applicable, remove any contamination that is found caught inand between the bottom air flaps (aka “blinds”) and/or the housing.
MC-11018730-0001.pdf
SIB 84 02 25 (2025-05-13)
BMW 330I 2024
BMW 430I 2024
ELECTRICAL SYSTEM
When making phone calls via BMW Bluetooth (not Apple CarPlay) in the vehicle, the person in the calloutside the vehicle hears a distorted voice reproduction.
MC-11018554-0001.pdf
SIB 65 09 25 (2025-05-08)
BMW 330I 2024
BMW 430I 2024
ELECTRICAL SYSTEM
Customer may complain that Projected Modes (Apple CarPlay/Android Auto) do not connect in the vehicle. Itis found that the WiFi in the vehicle is also not active and cannot be turned on.
MC-11018546-0001.pdf
SIB 16 01 25 (2025-05-05)
BMW 330I 2024,2025
BMW 430I 2024,2025
FUEL/PROPULSION SYSTEM
Please have the Integrated Fuel Module control unit (IFM) programmed in the vehicles concerned(according to the vehicle identification number selection), if possible, before vehicle delivery.
MC-11018511-0001.pdf
SIB 32 04 25 (2025-05-02)
BMW 330I 2024
BMW 430I 2024
STEERING
After prolonged straight-ahead driving (e.g. highway driving), there may be a temporary, slightly noticeable increase in steering forces when steering out of the steering wheel center position. This minimally noticeable increase in steering forces is perceived as a slight, brief resistance. After overcoming this brief resistance when steering out of the steering wheel center position, no permanent increase in steering forces is noticeable.
MC-11018514-0001.pdf
SIB 51 30 19 (2025-04-29)
BMW 330E 2020,2021,2022,2023
BMW 340I 2020,2023
STRUCTURE, STRUCTURE: BODY
A groaning noise is present from the door frame of any door, most commonly when driving over rough roadsor during body flex. This situation may be worse in vehicles which are regularly waxed in th e area of the door jamb.
MC-11017506-0001.pdf
SIB 65 08 25 (2025-04-28)
BMW 330I 2025
BMW 430I 2025
ELECTRICAL SYSTEM
Central Information Display (CID) side of the Multifunction Display may intermittently black out.
MC-11017569-0001.pdf
SIB 63 02 22 (2025-04-25)
BMW 430I 2021
VISIBILITY/WIPER
Excessive condensation in one or both headlights.
MC-11017571-0001.pdf
SIB 51 07 25 (2025-04-17)
STRUCTURE: BODY
The trunk lid trim panel may partially comeloose/dangle (red arrows show the mostprevalent areas).
MC-11017284-0001.pdf
SIB 01 07 25 (2025-04-15)
BMW 330E 2021,2022
STRUCTURE: BODY
MC-11017102-0001.pdf
SIB 34 02 25 (2025-04-03)
BMW 330I 2025
BMW 430I 2025
SERVICE BRAKES
Due to a manufacturing defect, there might be an internal leakage of the brake fluid expansion tank. In therare case that there is a leakage, the filling level sensor might malfunction over a relatively long period oftime .
MC-11017082-0001.pdf
RECALL 25V202000 (2025-04-01)
Affecting 4557 total vehicles
BMW 330I 2025
BMW 430I 2025
BMW 430I XDRIVE 2025
ELECTRICAL SYSTEM: ALTERNATOR/GENERATOR/REGULATOR, ELECTRICAL SYSTEM: STARTER ASSEMBLY
BMW of North America, LLC (BMW) is recalling certain 2025 330i, 330i xDrive, 530i, 530i xDrive, 4 Series Coupe (430i, 430i xDrive), 4 Series Convertible (430i, 430i xDrive), 4 Series Gran Coupe (430i, 430i xDrive) and X3 30 xDrive vehicles. The electrical connection between the starter-generator and battery may come loose.
RCRIT-25V202-3123.pdf
SIB 51 16 24 (2025-03-31)
BMW 430I 2024
UNKNOWN OR OTHER
On G22 and G23 xDrive vehicles, the “xDrive”emblem was not installed on the left side ofthe trunk (circled). Only the “430i” emblemwas installed to the right side of the trunk. Without the “xDrive” emblem on the trunk, thecurrent emblem on the vehicle corresponds tovehicles without all-wheel drive.
MC-11016437-0001.pdf
SIB 34 02 25 (2025-03-06)
BMW 330I 2025
BMW 430I 2025
SERVICE BRAKES
Delivery Stop - Brake Fluid Expansion Tank
MC-11016435-0001.pdf
SIB 64 01 25 (2025-02-28)
BMW 330I 2024
UNKNOWN OR OTHER
The customer may hear an intermittent “humming” or “foghorn” type sound in vehicle. It sounds like a lowhum that last for only a few seconds. This can occur with the engine operating or may be heard for up to one hour after engine shut down.
MC-11014665-0001.pdf
SIB 52 05 25 (2025-02-28)
BMW 330I 2025
ELECTRICAL SYSTEM
The customer states: The driver’s seat will not return to its last saved position. No seat memory. The heated seats settings in the menu are missing/different than in their previous BMW vehicle. They canno longer select, under the climate rules, at what temperature Fahrenheit the heated seats willautomatically turn on. Certain other “apps” and functions are not available The driver’s seat moves to an unknown memory position
MC-11014660-0001.pdf
SIB 52 03 25 (2025-02-28)
BMW 330I 2025
BMW 430I 2025
ELECTRICAL SYSTEM
The driver’s seat heater doesn’t work after the installation of a replacement seat harness part number (P/N)52 10 7 414 701.
MC-11014658-0001.pdf
SIB 16 01 25 (2025-02-22)
BMW 330I 2024,2025
BMW 430I 2024,2025
Update - Delivery Stop: Integrated Fuel Module
MC-11014964-0001.pdf
SIB 16 01 25 (2025-02-21)
BMW 330I 2024,2025
BMW 430I 2024,2025
B16 01 25 Integrated Fuel Module Delivery Stop Software Update
MC-11014965-0001.pdf
SIB 64 07 23 (2025-02-03)
BMW 430I 2023
ELECTRICAL SYSTEM, ELECTRICAL SYSTEM: WIRING: FUSES AND CIRCUIT BREAKERS, EQUIPMENT: OTHER: OWNERS/SERVICE/OTHER MANUAL
DELIVERY STOP: EKK (eKMV) Circuit Board
MC-11014040-0001.pdf
SIB 51 46 16 (2025-02-03)
BMW 340I 2019,2020
BMW M440I 2021,2022
(plus 67 other models)
STRUCTURE: BODY, STRUCTURE: BODY: TAILGATE
Upon opening and closing the tailgate, a creaking/groaning sound can be heard from tailgate actuator.
MC-11014038-0001.pdf
SIB 12 06 24 (2025-01-29)
BMW 330I 2024
ENGINE
BMW AG has decided on a service campaign for certain vehicles from the G0x, G12 and G20 series. Please have the starter motor checked and, if necessary, replaced in the vehicles concerned (according to the vehicle identification number selection) if possible before vehicle delivery. If vehicles have already been delivered, please have the measure carried out the next time the vehicles enter the workshop. A bolting fault on the long bolt screws can cause the magnets in the starter motor to twist. As a result, the power of the starter motor decreases. As a result, the engine does not start.
MC-11013434-0001.pdf
SIB 01 18 24 (2025-01-16)
BMW 330I 2019,2020
ELECTRICAL SYSTEM
The Telematics Control Units (TCU) Internal Emergency (Backup) Battery for defects in materials and/or workmanship has been extended to 6 years without mileage limitation, as determined from the vehicles original first in-service / delivery date. This coverage is subject to the same vehicle eligibility requirements, limitations, and exclusions that apply to the BMW New Vehicle Limited Warranty.
MC-11013037-0001.pdf
SIB 11 09 24 (2025-01-15)
BMW 330I 2024,2025
POWER TRAIN
During manufacturing, the dual-mass flywheel has not been sufficiently greased. The insufficient grease may result in acoustic abnormalities and vibrations in the vehicle's powertrain.
MC-11013112-0001.pdf
SIB 65 02 25 (2025-01-14)
BMW 330I 2025
BMW 430I 2025
UNKNOWN OR OTHER
If the Head-Up Display (HUD) is deactivated when Navigation View is selected, upon reactivation the Head-Up Display (HUD) will revert to the Standard View. This is most noticeable when the Head-Up Display (HUD) deactivates for automatic mandatory reasons, such as rear camera activation or emergency call activation.
MC-11013062-0001.pdf
SIB 61 06 15 (2024-12-18)
BMW 330E 2021
BMW 330I 2019,2020,2021,2024
BMW 430I 2021,2024
BMW M340I 2020,2021
BMW M440I 2021
EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, STRUCTURE: BODY, VISIBILITY: WINDSHIELD WIPER/WASHER
Rattling noises heard from vicinity of glove box.
MC-11012091-0001.pdf
SIB 65 38 24 (2024-12-13)
BMW 330I 2024
BMW 430I 2024
ELECTRICAL SYSTEM
Customers may report issue with Personal eSIM operation, to include: Personal eSIM does not finish the set-up process in the vehicle Telephone function via eSIM is not possible WiFi Hotspot function cannot be used Streaming video service via the BMW Theater Screen is not possible
MC-11012099-0001.pdf
SIB 84 04 24 (2024-12-06)
BMW 330I 2024
BMW 430I 2024
ELECTRICAL SYSTEM
Customers may report issue with Personal eSIM operation, to include: Personal eSIM does not finish the set-up process in the vehicle Telephone function via eSIM is not possible WiFi Hotspot function cannot be used Streaming video service via the BMW Theatre Screen is not possible
MC-11012103-0001.pdf
SIB 11 05 21 (2024-12-06)
BMW 330E 2021,2022
BMW 430I 2021,2022
BMW M340I 2020,2021
BMW M440I 2021,2022
ENGINE, ENGINE AND ENGINE COOLING, FUEL SYSTEM, GASOLINE
The belt pulley on the mechanical coolant pump may fracture allowing the engine drive belt to come off thecoolant pump and alternator.
MC-11012077-0001.pdf
SIB 24 03 24 (2024-11-14)
BMW 330E 2024
ELECTRICAL SYSTEM
Electric driving: A power reduction while electric driving Electric driving is not possible even though the high voltage (HV) battery is sufficiently charged Starting of the internal combustion engine (ICE): There is a noticeable cutting in of the ICE when it starts The cutting in of the ICE is slower Check Control Message (#2390): “Engine is starting… Please wait.” The possibility of the electric drive not starting the ICE Hybrid Driving: Reduced acceleration Jolts during upshifts Delays during downshifts Possible stored fault codes- EGS-EME: 039A2A – EGS-EME, temperature sensor, coolant: Excess temperature 039A2B – EGS-EME: Excess temperature BA0842 – EGS-EME, temperature sensor, coolant circuit: upper threshold value exceeded BA0845 – EGS-EME, temperature sensor, coolant circuit: Gradient implausible DME: 034D5C – Cooling failed: Inverter
MC-11010756-0001.pdf
SIB 41 03 24 (2024-11-07)
BMW 430I 2024
STRUCTURE: BODY
There is possibility that two body plugs were not correctly installed on the vehicle during production.Possible water ingress at the two points and typical faults such as corrosion or musty odor can occur.
MC-11010760-0001.pdf
SIB 51 27 24 (2024-11-04)
BMW 330I 2024
BMW 430I 2024
ELECTRICAL SYSTEM
The Ethernet bus of the Body Domain Controller (BDC) is interrupted so that audio output, rear viewcamera, or the driver assistance systems fail. The symptoms begin to appear during auto locking at approx.10 mph, or after the Central Locking button is activated. Dependent upon vehicle equipment, the following permanent SAE faults may be stored in the vehicle: S 0219, No Communication possible with: Amplifier S 0261, No Communication possible with: Camera-based driver assistance S 0273, No Communication possible with: Headunit S 0313, No Communication possible with: All-round vision camera S 0386, No Communication possible with: Instrument Panel S 0394, No Communication possible with: Telematics control unit
MC-11010762-0001.pdf
SIB 61 26 24 (2024-11-01)
BMW 330I 2024,2025
ELECTRICAL SYSTEM
Both 12 V and 48 (V) volt ground cables may not have been secured correctly to the underbody of theaffected vehicles. Please, ensure that both ground lines (12 V and 48 V) are reworked before vehicledelivery.
MC-11010763-0001.pdf
SIB 61 22 24 (2024-10-31)
BMW 330I 2024
BMW 430I 2024
ELECTRICAL SYSTEM
A limited number of 12 and 48 (V) volt vehicle batteries may have been damaged during the manufacturing process, which could lead to a premature battery failure.
MC-11009558-0001.pdf
SIB 31 02 23 (2024-10-31)
BMW 330I 2023,2024
BMW 430I 2023,2024
MC-11009555-0001.pdf
SIB 01 07 22 (2024-10-25)
BMW 330I 2019,2020
BMW 340I 2019,2020
(plus 19 other models)
EXTERIOR LIGHTING, FUEL SYSTEM, GASOLINE, FUEL/PROPULSION SYSTEM
Fuel tank limited warranty for leakage, due to defects in materials or workmanship, has been extended to 15 years/150,000 miles as determined from the original in-service date
MC-11009423-0001.pdf
SIB 11 04 24 (2024-10-17)
BMW 330I 2024
ENGINE
One of the following faults are stored in the DME: 123432 - Electrical wastegate valve, adaptation: Limit position shut, implausible 123433 - Electrical wastegate valve, adaptation: adjustment range implausible 123511 - Electrical wastegate valve: stiff movement
MC-11008988-0001.pdf
SIB 01 03 24 (2024-09-12)
BMW 330I 2019
ENGINE
For this vehicle, the EVAP systems purge (vent) valve limited warranty for defects in materials or workmanship has been extended to 15 years / 150,000 miles as determined from the original in-service date. This coverage is subject to the same vehicle eligibility requirements, limitations, and exclusion criteria that apply to the BMW New Vehicle Limited Warranty.
MC-11008101-0001.pdf
SIB 65 21 24 (2024-09-11)
BMW 330I 2024
BMW 430I 2024
ELECTRICAL SYSTEM
When the navigation app is opened in the vehicle, the navigation map is not displayed. Instead, the navigation loading screen is shown on a constant loop and the message "Navigation starts" is displayed.
MC-11008120-0001.pdf
SIB 51 18 23 (2024-08-27)
A groaning noise is heard from the trunk whendriving on rough roads.
MC-11006732-0001.pdf
SIB 51 09 23 (2024-08-19)
BMW M440I 2021,2022
VISIBILITY/WIPER, VISIBILITY: POWER WINDOW DEVICES AND CONTROLS
Sudden failure of the power window(s).
MC-11006730-0001.pdf
RECALL 24V576000 (2024-08-01)
Affecting 105588 total vehicles
BMW M340I 2020
ELECTRICAL SYSTEM: STARTER ASSEMBLY, ENGINE AND ENGINE COOLING: ENGINE: ENGINE CONTROL MODULE (ECU/ECM): SOFTWARE
BMW of North America, LLC is recalling certain 2019-2020 X5, X7, 2020 3 Series Sedan, X6, 2020-2021 7 Series Sedan, 2020 8 Series Convertible, 8 Series Coupe, and 2020 8 Series Gran Coupe vehicles. Please see the recall report for the complete list of models. In the event the starter motor fails, repeated attempts to start the vehicle can cause the starter motor to overheat from an electrical overload.
RCRIT-24V576-3778.pdf
RCRIT-24V576-0658.pdf
RCRIT-24V576-9007.pdf
SIB 51 12 19 (2024-07-29)
BMW 330E 2021
BMW M340I 2020,2021
ENGINE, ENGINE AND ENGINE COOLING, STRUCTURE
A check control message or MIL (Malfunction Indicator Lamp) may be illuminated, with one or more of thefollowing faults stored: 138207 - Active cooling damper control (AKKS), top: blockage at warm ambient temperature 21B043 - Active cooling damper control (AKKS), top: blockage at all ambient temperatures 138222 - Active cooling damper control (AKKS), above: positional deviation error detected at warm ambienttemperature 138209 - Active cooling damper control (AKKS), top: Control deviation at all ambient temperatures 13822B - Active cooling damper control (AKKS), top: Control deviation at all ambient temperatures 21B042 - Active cooling damper control (AKKS), below: blockage at all ambient temperatures 138206 - Active cooling damper control (AKKS), bottom, blockage at warm ambient temperature 138225- Active air-flap control, bottom: top limit position not detected 138224- Active air-flap control, bottom: bottom limit position not detected
MC-11005449-0001.pdf
SIB 65 20 24 (2024-07-16)
BMW 330I 2024
ELECTRICAL SYSTEM
When getting into the vehicle, the wrong driver profile is selected. As a result, the seat adjusts to the wrong position.
MC-11005243-0001.pdf
SIB 65 17 24 (2024-07-08)
BMW 330I 2023
ELECTRICAL SYSTEM
It is not possible to complete the setup of the BMW Digital Key function in the vehicle with a smartphone. The main digital key cannot be paired using the My BMW App. The digital key pairing process does notrespond after the message “Please place your smartphone on the NFC tray” appears in the CentralInformation Display (CID). No function is available with the NFC (near-field commumication) card either.
MC-11005242-0001.pdf
SIB 18 01 24 (2024-07-03)
BMW 330I 2024
ENGINE
DELIVERY STOP: CATALYTIC CONVERTER
MC-11005215-0001.pdf
SIB 65 01 21 (2024-06-12)
BMW 330E 2021
BMW 330I 2019,2020,2021,2023
BMW 430I 2021
BMW M340I 2020,2021
BMW M440I 2021
EQUIPMENT, UNKNOWN OR OTHER
No Bass or a cracking noise can be heard from the bass speakers.
MC-11002864-0001.pdf
SIB 65 04 21 (2024-06-04)
BMW 330E 2021
BMW 430I 2021
BMW M340I 2020,2021
BMW M440I 2021
EQUIPMENT: ELECTRICAL: RADIO/TAPE DECK/CD ETC., STRUCTURE: BODY
A rattling/ droning noise is heard in the vehicle interior when the air conditioning (AC) is activated. Vibrationsare felt in the driver’s footwell.
MC-11002861-0001.pdf
SIB 65 12 24 (2024-05-30)
BMW 330I 2023
BMW 430I 2024
ELECTRICAL SYSTEM
The Central information Display (CID) screen goes black and the Headunit (HU-H3) resets sporadically.After a short period of time, the function of the CID and HU-H3 is available again. Additionally, fault code B7F8F9 – “HU-H: Reset” will be stored in the HU-H3. The issue may occur multiple times while driving longer distances. CAUSE Unfavorable
MC-11000616-0001.pdf
SIB 36 01 21 (2024-05-01)
BMW 330E 2020,2021,2022,2023,2024
BMW 340I 2019,2020,2023
BMW M340I 2019
BMW M440I 2021,2022,2023,2024
(plus 69 other models)
EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY, SERVICE BRAKES, AIR: DISC, STEERING
At low outside temperatures (below 40 degrees F) and slow driving speeds (i.e. when parking, maneuvering)with a large steering angle, the front end can be slightly axially misaligned.
MC-11000563-0001.pdf
SIB 12 07 21 (2024-03-04)
(plus 24 other models)
Check Control message (CCM) indicates: (ID 213): Stop, exercising due care. Voltage supply The Service Engine Soon light is on with the following DME Fault Code: 21B209 - Starter alternator / belt for 48V system (OSA_RIEMEN_RISS): Belt betweenCombustion engine and starter generator torn And/or one or more of the following other issues are also occurring: Noise in the area of the belt drive. Odor from the engine compartment. Smoke formation in the area of the belt drive. Drive belt damaged or prematurely worn. Torn drive belt.
MC-10252038-0001.pdf
SIB 61 03 21 (2024-02-28)
BMW 330E 2021
BMW 430I 2021
BMW M340I 2020,2021
BMW M440I 2021
ELECTRICAL SYSTEM, ELECTRICAL SYSTEM: SOFTWARE, EQUIPMENT, FUEL SYSTEM, GASOLINE: STORAGE: EVAPORATIVE EMISSIONS: CANISTER
SITUATION BMW AG is conducting a Voluntary Emissions Recall (effective April 23, 2021) on a certain Model Year 2020 - 2021 BMW vehicles that were produced between August 13, 2019 and December 11, 2020. Do not deliver to a customer, a New, Certified Pre-Owned or Used vehicle subject to an emissions recall, until the vehicle is repaired. Do not use or sell replacement equipment/parts subject to an emissions recall. The 12 V battery" s dual storage system (DSS) may contain a software error which intermittently causes a continuous resetting of the microcontroller and communication failure. The error is displayed by a red Check Control message.
MC-10250893-0001.pdf
SIB 66 07 20 (2024-02-21)
BMW 330E 2021
BMW M340I 2020,2021
ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY
The functionality of the left rear SRR sensor could be reduced which would display the Driving Assistance Check Control Message.
MC-10250601-0001.pdf
SIB 66 08 20 (2024-02-20)
BMW 330E 2021
BMW M340I 2020,2021
BACK OVER PREVENTION: SENSING SYSTEM: CAMERA, ELECTRICAL SYSTEM, EQUIPMENT, EQUIPMENT ADAPTIVE/MOBILITY
The functionality of the right rear SRR sensor could be reduced which would display the "Driving Assistance"- Check Control Message.
MC-10250600-0001.pdf
SIB 64 04 22 (2024-02-16)
(plus 16 other models)
ELECTRICAL SYSTEM, VISIBILITY: DEFROSTER/DEFOGGER/HVAC SYSTEM
An interference noise (groaning noise) can be heard from within the heating and air-conditioning unit in thecenter of the instrument panel. The groaning noise always occurs when either a ventilation flap, air stratification flap or the recirculated airflap moves to a different position. Due to the complex design of the heating and air-conditioning unit, the kinematics causing it (top or bottom,left or right) may not be able to be precisely located. Depending on the vehicle model, the number of servomotors (and the associated kinematics unit) varies.Various models use either 2 or 3 servomotors.
MC-10250374-0001.pdf
SIB 51 08 19 (2024-01-16)
(plus 230 other models)
ELECTRICAL SYSTEM, VISIBILITY: POWER WINDOW DEVICES AND CONTROLS
The basic conditions for initializing the power windows are not met.
MC-10249437-0001.pdf
SIB 61 13 05 (2024-01-11)
BMW M340I 2019,2020,2021,2022,2023
(plus 358 other models)
The electrical system of BMW vehicles has been subject to an ongoing development process over the last few years. This has led to increased demands being placed on the battery. This document covers important information for the dealer on how to handle "discharged battery" complaints.
MC-10249027-0001.pdf
SIB 61 05 24 (2024-01-05)
(plus 53 other models)
ELECTRICAL SYSTEM, EQUIPMENT: ELECTRICAL: INFOTAINMENT
The Central Information Display goes black intermittently due to resets of the Head Unit (HU-H3). FaultB7F8F9 " "HU-H: Reset" will be stored in the HU-H3.
MC-10249032-0001.pdf
This is an automated post created with code written by a human.
Appreciate 16
CSBM53139.50
eep237815.00
Eljefe25125.00
darthry107.50
Athena285.00
EXE462074.50
SimbaE46120.00
zlatko225.00
rmedina237.00
b58jam62.00
      01-04-2026, 03:20 PM   #3
Tars435i
Drives: BMW 435i coupe
service bulletins for 435i coupe
Where do I find bmw service bulletins for this model from 2016 to 2025?
      01-23-2026, 07:30 AM   #4
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-01-23
BMW 330I 2025
BMW 430I 2025
ELECTRICAL SYSTEM
STRUCTURE: BODY
      02-07-2026, 07:30 AM   #5
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-02-07
      02-24-2026, 07:57 AM   #6
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-02-24
BMW 330I 2026
BMW 430I 2025,2026
ELECTRICAL SYSTEM
BMW 430I 2024
SUSPENSION
      03-14-2026, 08:33 AM   #7
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-03-14
STRUCTURE: BODY
      03-31-2026, 09:13 AM   #8
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-03-31
BMW 430I 2025
ELECTRICAL SYSTEM
BMW 330I 2024,2025
BMW 430I 2025
ELECTRICAL SYSTEM
BMW 430I 2025
UNKNOWN OR OTHER
      04-07-2026, 02:02 PM   #9
seydel2001
Drives: 2022 BMW M440i X
Anyone have any info on this. I have a 2022 M440i xdrive. I was entering data to the service logs and by accident rest the Headunit. Well went in a coded all my stuff back in and it all worked again but now when I’m driving the Active blind spot detection malfunctions and shuts off but I can still drive just the just no rear and side detection. Front stuff all work just the Active Blindspot. I can shut it down and restart and it drive again for 5 to 10 miles depending on traffic and does the same stuff.
Reading your post I forgot I also installed aftermarket mirror blinkers COULD THAT BE IT??????
I’m about to reset it again but don’t know if that caused it and I’m missing something???? Any help please???
      04-28-2026, 06:36 PM   #10
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-04-28
STRUCTURE: BODY
BMW M440I 2021,2022
      04-29-2026, 09:56 AM   #11
analogue
analogue's Avatar
Drives: 1M, iX
New 2026-04-29
BMW 330I 2026
