E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > spacers on car making possible wheel vibrate
Reply
      03-29-2013, 05:03 PM   #1
SyL3nTFoRcE
Drives: 2008 335xi
would 10mm in the fron and 15mm in the rear knock off balance and make the wheel and car shake? its rough around 60mph and annoying at 40 and 80mph
any help i didnt have so much shake before the spacers but i honestly do not know and some wheel balance places wont touch my car because of the spacers
the spacers are bms btw
      03-29-2013, 05:23 PM   #2
CT335xi
CT335xi's Avatar
684
Drives: 2022 x5 m50i, 2005 evo 8
The only way I see that happening is if your spacers aren't hub centric . I run the bms 15 mm spacers out back and have no issues. Maybe one of your wheels is damaged or out of balance?
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno
Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr,
04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp
2014 x5 50i msport
      04-16-2013, 04:20 PM   #3
cmascis
Drives: '07 335xi
you can take them off and check if a piece of dirt or Rust got stuck in between the spacer in the hub or if the tires just need to be balanced
      04-16-2013, 05:06 PM   #4
N0Chill 335i
N0Chill 335i's Avatar
Drives: 13' F30 335i M Sport AW
Make sure your wheels are torqued down properly as well. Very easy to overlook the obvious.
      04-17-2013, 06:20 AM   #5
SyL3nTFoRcE
Drives: 2008 335xi
UPDATE:
Took spacer off car runs like a dream...........stupid rotors are warped though also :facepalm:
      04-17-2013, 06:57 AM   #6
mrbillytalent
Drives: '99 e46 323i & '07 e90 335i
When installing spacers be sure to:
A) Ensure the hub size is the same, if not invest in a set of hub rings to MAKE them fit
B) Clean the spacer and the hub, any bits of rust of dirt can't be in them. Any of this can cause the hub to not be perfectly aligned and cause vibrations
C)Be sure to torque down your wheels in a star pattern, if you don't know what that is google it. I always take ~3 steps in tightening mine down, prgressivelt tighter each time.
If you do these 3 things you should be able to get rid of any steerig wheel wobble or vibrations from the rear caused by spacers of any size.
      04-17-2013, 08:48 PM   #7
Jnat
DisplacementReplacement
Jnat's Avatar
431
Drives: 2020 X3M
Spacers are bad news, period!
      04-18-2013, 06:53 AM   #8
dangeris
dangeris's Avatar
22
Drives: 08 e92 328xi
I had the same issue...come to find out that there were these thin plastic "spacers that go between the hub and the spacers themselves. When I put on my winter wheels the car vibrated when I hit 40-60mph. If your spacers came with those plastic spacers...put them on and it should stop the vibrations.
2008 e92 328Xi - Daily Driver
M-Tech Lip/ M-side Skirts/ Painted Grille/ 18" LM Reps/ BMS Powerbox/ Koni Sport/ B&G S2 Springs
2008 997.1 TT Porsche; 2008 Nissan Altima Coupe - Show Car; 1995 300ZX SMZ #36
Reply
e90post
