02-13-2023, 10:19 AM | #309 |
Rep 3
I would like my 330e 2022 to default start in BATTERY CONTROL mode. Is this possible to code with any of the programming tools? I can see it's possible to code the car to start in other modes (ADAPTIVE, COMFORT, COMFORT INDIVIDUAL, COMFORT+, ECO PRO, ECO PRO INDIVIDUAL, ECO PRO+, SPORT, SPORT INDIVIDUAL), but I can't find any information if BATTERY CONTROL is possible.
02-14-2023, 03:29 PM | #311 |
Rep 215
02-15-2023, 01:34 PM | #313 | |
Rep 110
However, once coded - you can then use Basic Mode to set Comfort Plus as the default - this is what I have done, so Comfort Plus is shown in the instrument panel at start-up. Regards, Mike. |
02-15-2023, 02:48 PM | #314 |
Rep 73
Thanks Mike and tylers1027. Think I've done something wrong so will look in to it again on bimmercode. Double pressing the comfort button does nothing, no comfort plus in the instrument panel, it does show in the I drive screen but greyed out so think I've not done something right.
02-16-2023, 04:24 PM | #316 | |
Rep 572
02-17-2023, 08:29 AM | #317 |
Rep 362
Drives: G20 330ix M Sport
Has anyone coded brake force display? I found these.
Emergency Brake Force Display ‐ Off [US Default] 00007083 BDC_BODY3 3075 GEFAHRENBREMSLICHT_TYP >nicht_aktiv< Emergency Brake Force Display ‐ Flashing [Europe Default] 00007083 BDC_BODY3 3075 GEFAHRENBREMSLICHT_TYP >bremslicht_blinkend< Emergency Brake Force Display ‐ Area Enlargement 00007083 BDC_BODY3 3075 GEFAHRENBREMSLICHT_TYPA >flaechenvergroesserung<
02-17-2023, 03:32 PM | #319 |
Rep 71
Drives: 2021 BMW 330i
No, nothing will change. I retrofitted the charger on my car and even without coding it still works. The coding is just to display that the device is charging in idrive.
02-25-2023, 01:17 AM | #320 |
Rep 4,250
look i went back to RAM - System - Derivat
and tried G21 G80 G82 G83 G30 they are all slightly different I do feel that 80, 82 and 83 give you a fuller sound 82 and 83 seem to have the fullest sound now I'm on G83 but G82 might be better being less full, it's almost like G83 adds reverb which may or may not be useful |
02-25-2023, 01:19 AM | #321 |
Rep 4,250
regarding Sport PLus attenuation it might just be in my head, as i removed sport steering and what it does is it removes the option from Sport Individual configuration but I'm sticking with sport plus attenuation just in case it helps with roll but i think it's in my head for this one
02-28-2023, 03:47 AM | #322 |
Rep 1
Hey all.
I saw some comments regarding Lane Change Assist, and I wanted to see if anyone knows if it is code-able yet? I have a 2020 M340i that was a demo model, so I just coded in the assisted driving display. I would love to get the Lange Change Assist, as that was the last piece I miss from my previous 2021 M340i (I was hit and it was a total loss ) So, does anyone know if it is possible with just BimmerCode? I wanted to try Esys but it is just impossible to find all the downloads and files, so I had to give up. Thank you all! |
gnolivos319.00 |
03-06-2023, 11:26 PM | #323 |
Rep 71
I saw in another forum the coding of automatic pdc braking intervention. Is this possible without driving assistant pro?
03-06-2023, 11:27 PM | #324 |
Rep 71
03-07-2023, 06:26 PM | #325 |
Rep 71
Bimmercode doesn’t let you go into expert mode for ASCM so never mind 🤷🏻‍♂️
03-07-2023, 11:53 PM | #326 |
Rep 63
What is coding
I have a 45e on order and I’ve been on this site in preparation for the arrival. This will be my first BMW and I see the blogs on coding and other than maybe figuring out it’s a method of changing the way the car reacts to different inputs I’m just unsure. Can some point me to ways I can learn what coding can do as I would like to see if it may be of interest to me.
03-08-2023, 07:17 AM | #327 | |
Rep 694
https://www.bimmerpost.com/forums/sh....php?t=1990401
03-08-2023, 09:12 AM | #328 | |
Rep 1
Go here: Instrument Cluster (DKOMBI) Expert Mode 300A CC_Konfiguration Meldung 295 Nicht_Aktiv Meldung 296 Nicht_Aktiv Meldung 297 Nicht_Aktiv Meldung 298 Nicht_Aktiv Meldung 299 Nicht_Aktiv Meldung 300 Nicht_Aktiv ✅ The SOS system still works but the alarms are all disabled. I turned mine off for a few months because I didn’t have time to get the SOS battery changed. In the end it was done under warrantee when I had my end of warentee inspection carried out. It’s crazy how that warning covers your milage so you can only find out your odometer reading from the app. It’s also an MOT failure because it’s classed as a warning light. Madness. |
03-12-2023, 12:04 AM | #329 |
Rep 22
03-12-2023, 01:25 AM | #330 |
Rep 71
How about being able to use manual while driving and full text on idrive
