12-10-2019, 07:54 PM | #45 |
Rep 1,481
Drives: 2020 M340Xi (G20)
Sling56 ,
From p290 of owner's manual: "Coasting. Efficiency can be optimized by disengaging the engine and coasting with the engine idling. Under certain conditions the engine is automatically decoupled from the transmission in the D selector lever position. The vehicle continues traveling with the engine idling to reduce consumption. Selector lever position D remains engaged. This driving condition is referred to as coasting. As soon as you step on the brake or accelerator pedal, the engine is automatically coupled again." Coasting is when the engine is disengaged and saves fuel. Think of it as either pushing in the clutch on a manual transmission or on a bike just holding your feet on the pedals while you have the pedals disengaged from drive wheel. BTW, my car has that already in the menu Hope that helps
Al
phillyd2219.00 |
12-10-2019, 08:09 PM | #46 |
Rep 44
12-10-2019, 11:26 PM | #48 | |
Rep 123
Drives: 2020 BMW M340i
2020 M340i RWD | C3Z | MAPQ | ZDA | ZDY | ZPK | ZPP | 1CR | 1PU | 688 | 6NW | 2VF | 316 | 4UR
Visit my Instagram |
12-11-2019, 12:25 AM | #49 |
Rep 332
I changed these 2 codes but can't get auto heated wheel to work. It shows in the menu but I cannot select it. Checking the box doesn't actually check it and the temperature setting only has 0 degree celsius there
12-11-2019, 07:55 AM | #50 |
Rep 23
12-11-2019, 09:10 AM | #51 |
Rep 547
Can you confirm that the auto steering wheel heat works? I coded the two values above and I can see the option now under the A/C menu but I can't select the checkbox and I can't select a temperature.
Current: 2020 M340xi Previous: 2016 340xi |
12-11-2019, 11:37 AM | #52 | |
Rep 332
12-11-2019, 07:03 PM | #54 | |
Rep 123
12-11-2019, 07:15 PM | #55 |
Rep 44
So the instructions are wrong.. It clearly says to email a receipt, which I did, PDF.. I didn't even bother to redact PII since I didn't want to deal with rejection.. That's fine, I'll donate again.
12-11-2019, 07:17 PM | #56 | ||
Rep 751
Try setting IKF_ENABLE to "ikf_alle_sitze" in BDC_BODY. I left that out as it references seats, but it is a setting I was messing with and have not yet reverted. Quote:
The instructions he sent me stated explicitly to NOT do this. From where did you get your instructions? Last edited by siegester; 12-11-2019 at 07:29 PM.. |
12-11-2019, 08:03 PM | #57 | ||
Rep 44
12-11-2019, 08:49 PM | #58 |
Rep 547
That worked for me. Able to check off the auto heated steering wheel box and set a temp. Also confirmed the wheel heating comes on automatically. Thanks!
12-11-2019, 10:26 PM | #59 | |
Rep 751
Sorry about that, table updated to reflect this additional value too. |
12-11-2019, 10:43 PM | #60 | |
Rep 123
Here's the latest email response I got from TokenMaster...
These instructions may change. Send a note to him and get your own. Quote:
12-11-2019, 11:00 PM | #61 |
Rep 332
So the ///m start up animation.
Is it just the idrive screen or digital dash too? Mine only works for idrive. Dash is still bmw. Also i coded lane change assist. Doesn't seem to change lane for me. |
12-12-2019, 11:46 AM | #62 | |
Rep 547
And the lane change feature works for me after coding those 3 values in OP's post. Do you have the option to enable it in the idrive settings? I enabled it there then I was able to change lanes automatically by having the assisted driving on and then holding the turn signal to the resistance point.
12-12-2019, 11:48 AM | #63 | ||
Rep 332
12-12-2019, 06:34 PM | #64 | |
Rep 13
Here ///M in Display and BMW in iDrive |
12-12-2019, 07:01 PM | #65 |
Rep 13
I'd like to enable Easy Entry, that feature that the seat backs off when the car is turned off or unlocked to make driver entry easier
golferboy231278.50 |
12-12-2019, 07:05 PM | #66 |
Rep 332
I tried didn't work
