| 03-30-2023, 03:01 AM | #45 | |
![]() 178
Rep 258
| 03-30-2023, 03:12 AM | #46 | |
![]() 178
Rep 258
| 03-30-2023, 03:36 AM | #47 | |
B58 Power
1070
Rep 1,437
Atleast for the Kombi there´s some downside like no display of the drive mode you´re in. Not possible at all with Bimmercode, because you can only change values. M software need E-Sys and a flash of the Kombi/HU.
| 03-30-2023, 04:39 PM | #48 | |
Rep 97
| 04-03-2023, 09:58 AM | #49 | |
B58 Power
1070
Rep 1,437
I´ve sent you a PM ;-)
You can switch between them by changing the setting in the iDrive HUD menu. You need to set the view to either Sport for shift lights in the HUD or assisted driving for shift lights in the Kombi.
| 04-04-2023, 10:04 AM | #50 |
B58 Power
1070
Rep 1,437
Another update...
Seems like one of the codings killed parts of my HUD information. The Driving Assistant isn´t showing in the HUD anymore. And also the navigation won´t be shown in the HUD. I need to check that again. Maybe it´s the reason why my car doesn´t had shift lights, because it doesn´t work in combination with DAP. It´s probably a bug.
| 04-04-2023, 08:09 PM | #51 | |
![]() 178
Rep 258
| 04-05-2023, 02:54 AM | #52 | |
![]() 178
Rep 258
![]() CB_SHIFTLIGHTS => aktiv HMI_SHIFTLIGHTS_HUD_ENABLE => aktiv HMI_SHIFTLIGHTS_KOMBI_ENABLE => aktiv PIA_SHIFTLIGHTS => aktiv Very weird stuff, will post pics to reference soon. |
| 04-05-2023, 03:10 AM | #53 | ||
B58 Power
1070
Rep 1,437
Everything worked until i coded the shift lights. Quote:
What software does your car have? I´m on 11/2022.31
| 04-05-2023, 03:33 AM | #54 | |
![]() 178
Rep 258
| 04-07-2023, 02:04 AM | #56 | |
B58 Power
1070
Rep 1,437
I still have a problem with the HUD. Since trying to code the shift lights my HUD neither shows any Driving Assistant nor navigation graphics. So what´s the things we need to do for M shift lights without loosing the DA and navigation graphics?
| 04-07-2023, 06:01 AM | #57 | |||
Rep 2,046
This is on G30 so i dont know if there is difference.
HTML Code:
3000 Anzeige_Konfiguration, A0 > HMI_DRVLG_ENABLE: aktiv [01] 3000 Anzeige_Konfiguration, A0 > HMI_MVIEW_FAHRSTUFE_ENABLE: gang_1_9 [01] 3000 Anzeige_Konfiguration, A0 > M_VARIANTE: motorsport [01] 3000 Anzeige_Konfiguration, A0 > HMI_M_MODI_ENABLE aktiv (01) 3000 Anzeige_Konfiguration, A0 > SHOWROOM_MODE_SEQUENZ: sequenz_1 [00] 3000 Anzeige_Konfiguration, A0 > CB_TAG_NACHT_UMSCHALTUNG nicht_aktiv (00) 3000 Anzeige_Konfiguration, A0 > CB_DIGIT_GESCHW_M_ANSICHT aktiv (01) 3000 Anzeige_Konfiguration, A0 > SPA_ZIEL_GANG_ENABLE: nicht_aktiv [00] 3000 Anzeige_Konfiguration, A0 > HUD_TAG_NACHT_ENABLE nicht_aktiv (00) 3000 Anzeige_Konfiguration, A0 > GLOBAL_LAYOUT_VARIANTE: m_gmbh [01] 3000 Anzeige_Konfiguration, A0 > M_RACE_FAHRMODUS: aktiv [01] 3000 Anzeige_Konfiguration, A0 > SERVICE_PACK_VARIANTE sp_2018 (01) 3000 Anzeige_Konfiguration, A0 > HMI_VORWARNFELD_KOMBI_ENABLE aktiv (01) 3000 Anzeige_Konfiguration, A0 > BC_KVA_VARIANTE kva_mit_igr_batterie (02) 3000 Anzeige_Konfiguration, A0 > CB_HUD_FAS: aktiv [01] 3000 Anzeige_Konfiguration, A0 > HMI_WELCOME_GOODBYE_LAYOUT: m_sport [02] 3001 KI_Parameter, FC > LOGO_SCHRIFTZUG m_logo (15) 3001 KI_Parameter, FC > HUD_VARIANTE: high_3+ [06] 3001 KI_Parameter, FC > DZM_VARIANTE m_gmbt_s63t4 (05) 3001 KI_Parameter, FC > DZM_VORWARNBEREICH_ANFANG 7200 U/min (48) 3004 ERM_Konfiguration, 50 > CTR_DISP_M_SYS_TIMEOUT: nicht_aktiv [00] 3004 ERM_Konfiguration, 50 > CTR_DISP_M_SYS_APPL: nicht_aktiv [00] |
| 04-18-2023, 02:45 PM | #58 | |
![]() ![]() 8062
Rep 6,584
can you get the shift lights on the dash cluster with M tacho? for example coding M tacho means you lose the sport display on HUD so there is no shift lights on HUD but will it still show on dash? |
| 04-19-2023, 04:13 AM | #59 | |
B58 Power
1070
Rep 1,437
Haven´t tried that because i don´t like the M tacho. Currently i don´t have the shift lights coded and got problems with the HUD not showing Driving Assistant or navigation graphics. When had them coded you had to choose between shift lights in the dash cluster or in the HUD. This was controlled by the iDrive setting for sports view in the HUD. If you have sports view in HUD enabled, the shift lights will be shown only in the HUD. If it´s disabled, the shifts lights will be shown only in the dash cluster. It wasn´t possible to have them in both like the real M cars. I had an G82 over the weekend and made a backup of all the coding. This could help but probably wont because of the different software. FYI: MaximK never answered my PM.
| 04-23-2023, 08:03 AM | #60 |
B58 Power
1070
Rep 1,437
I finally solved my issue with missing navigation and driving assistant data.
The problem was so trivial... I had reflashed HU_MGU and DKOMBI, VO coded every ECU with the original VO and still had the issue. Someone tried to help me and send me a video of his HUD settings with the M View active. This was the point where i remembered i had this menue coded... I had the M View enabled in the HUD menue and didn´t changed it back to standard before disabling the menue again. I´ll update this thread once i´m back to my codings and can try something new.
| 12-06-2023, 06:49 AM | #61 |
![]() ![]() ![]() ![]() 493
Rep 629
Hi
Trying to finalize coding the shift lights I have the feeling I'm close, but not close enough 😁 Going through the pages I coded pretty much everything I could find for my 2020 M340 and here is the result The shift lights don't appear unfortunately in any mode, if you have any suggestions they are welcome thx. Edit: It works I wasn't revving high enough 😅 |
| 01-12-2024, 04:37 PM | #62 | ||
Rep 198
Current car: G20 M340i Black Sapphire (Stage 2 BM3 and xHP with Downpipe)
Previous cars: 2019 VW Arteon (Stage 1+), 2017 Audi TTS, 2015 Audi S3 Sportback, 2006 BMW 335i Coupe |
| 03-27-2024, 08:52 AM | #63 |
Rep 362
Drives: G20 330ix M Sport
Any updates?
| Bookmarks |
