04-19-2021, 02:44 AM | #111 | ||
Rep 567
It looks like ACR Helmond sells everything as a package now? It mentions the MEC in the list, but nothing about the 1.7RAM. https://www.acr-helmond.nl/shop/car-...h-up-7bmw-ram/ Quote:
04-25-2021, 07:35 PM | #112 | |
Rep 35
Here is a breakdown of what I got: - MATCH UP 7BMW Amp/DSP - MATCH PP-BMW 1.7RAM - MATCH MEC ANALOG IN - UP 7BMW / UP 7DSP - MATCH MS 42C-BMW.1 - MS 4X-BMW.2 - MATCH UP W8BMW-S |
Calamari208.50 |
05-26-2021, 10:30 AM | #113 |
Rep 6
Does anybody know if there's a reason the PP-BMW 1.7RAM Harness wouldn't work with a G22 2021 M440i with a HiFi system?
On the AF "upgrade finder", that particular combination has a "not compatible" indicator, which is why I've held off on getting an amp for my car. But the more I think about it, I don't even see the Match UP 7DSP in the upgrade finder if I enter the models you all are clearly installing them on… so I'm wondering if I shouldn't treat that as my source of truth. Apologies, I'm super new at all of this stuff so I have no idea what I'm doing. |
05-26-2021, 11:36 AM | #114 | |
Rep 310
makkhiato0.00 |
05-26-2021, 01:35 PM | #115 | ||
Rep 6
Ordered a 7DSP set with the relevant components. Will take it to an installer and update this post with how it goes. Last question, are you able to use the PC tool once the amp has already been installed? Or does the PC need to be connected to the amp during the installation process? Wondering if it will require opening everything back up to tweak the tune. |
05-26-2021, 03:14 PM | #116 | |
Rep 425
2) just run the USB cable wire into the trunk. I just went through the opening in the left cubby and have my usb cable sitting there. You can then program it when it’s fully installed, or tune whenever you want. |
05-27-2021, 04:28 AM | #117 | |
Rep 310
The same with me. I've left the USB cable in the left cubby. Althrough I adjusted everything in 2 rounds last year when I installed the amp and haven't touched it since. BTW, Just went on a long trip the other day after a looong period of short drives (due to Covid). I must say that I was so happy to crank it up and enjoy the music for hours. This upgrade is worth every penny. All the details, the precision, kick of the bass and drums, warmth of the guitars. It's just on a different level compared to both HiFi and Harman Kardon. P.S. My Setup is Match UP amp, all Eaton mids/tweeters and Focal under-seat woofers. Last edited by Calamari; 05-28-2021 at 09:15 AM.. |
pneumodoc235.00 |
06-13-2021, 10:40 AM | #119 |
Rep 67
Another successful install!
Hello guys,
I just wanted to say thanks for sharing all of this with the community, I was one of the early buyers of the MATCH UP 7BMW for a 2019 X5 G05 that in the time Audiotec Fischer had it listed as compatible before they identified that the RAM module could not be removed... Long has passed since then, the family grew so we changed from X5 to X7, and it has a pretty decent audio, so I just installed Audison speakers all around, including underseat subwoofers and left it there. A few weeks ago I had the opportunity to purchase a Demo 2020 G20, so after reading this thread I tried installing my UP 7BMW in the car and.... what do you know? It's a plug and play solution! What I'm thinking is that the G20 3 series, and the G01 X3 came before iDrive 7 and RAM module implementation, so, the year of production shouldn't be determining factor for the RAM module, I think is the presence of iDrive 6 vs iDrive 7.. If you have iDrive 6 like I do, then, in theory you shouldn't need to buy the MEC module and extra harness, and you should be fine with the UP 7BMW. And if you have iDrive 7, then you should go with the Match UP 7DSP + MEC + Extra harness to work with RAM module. Maybe the ones that didn't have the RAM module can confirm that they are indeed on iDrive 6, like me. I'm really happy, I installed it yesterday and it's a day and night difference, especially after Calamari's DSP Setup file + some tweaks of my own, as I installed a trunk subwoofer as well.. I honestly think that is totally unnecessary with the right underseat subwoofer and configuration. Cheers Last edited by RO-CK; 06-13-2021 at 10:50 AM.. |
06-13-2021, 11:50 AM | #120 | |
Rep 35
You will only need to buy wire for the UP7 DSP/AMP to power it off the battery. The positive/negative wire is not included so don't want till everything is pulled apart to realize it....like I did! As you've seen in this thread you'll need to download the proper "tune" from manufacturer website for the DSP. If you'll add an aftermarket secondary amp/sub also minor tweaking of the DSP program is necessary, but again not difficult. |
06-14-2021, 11:10 AM | #121 | |
Rep 310
I'm glad to hear you found my DSP setup file useful. It's great to share with people in all corners of the globe. Did you upgrade your speakers in the G20 or you're running factory speakers? |
06-17-2021, 07:40 PM | #122 |
Rep 16
Hey guys I have a Match up 7 DSP with Mec analog in and I was wondering, do any of you know what the "info" LED is for? Mine is always orange. I know the status LED is orange because I have DSP file 2 loaded but I've searched everywhere and I can't find what the info LED is for. It doesn't even show up in the manual or on any pictures of the unit online. I think it's only on the Match Up 7 DSP with MEC analog in that are factory installed.
Anybody know? |
06-28-2021, 10:08 AM | #123 | |
Rep 67
I have installed Focal K2 Power in the front, and Focal Integration IFBMW-S in the back. I also added 2 8" JL Audio subwoofers in the trunk. I'm still tweaking the equalizer part of the Audiotec to find my sweet spot for listening. Cheers! |
06-30-2021, 07:45 AM | #124 |
Rep 6
So, basically you have the RAM module if there are other cables beside the harness, and the "normal" amp if you have only one harness?
I'm asking because I have a 2020 F40 (I know, wrong forum), and this topic is the only source of information about this amp installation. My car hasn't the maps, and my amp has just the harness. It looks like the G20 amp that you can see in a post in this topic (https://g20.bimmerpost.com/forums/sh...4&postcount=30), there the user claimed he had no maps. So, if that is true, there are still some 2020 F40 with iDrive 6 / no Ram where the MatchUp 7BMW can be used. |
06-30-2021, 10:54 AM | #125 | |
Rep 310
If you have HiFi audio (not Harman Kardon) system, just go ahead and swap the HiFi amp with MatchUp 7BMW. There is no RAM in your car. |
06-30-2021, 01:04 PM | #126 | |
Rep 6
Audiotech Fisher website doesn't help with this distinction, for them every F40 model after 2019/?? has RAM, so they list the Matchup 7DSP as the only compatible. What bothers me is that in my car the battery is in the front, so installation is VERY different. I Guess I will pull the trigger very soon |
07-01-2021, 02:40 AM | #127 | |
Rep 310
MatchUp 7BMW amp gets power from the connector harness. It doesn't need power directly from the battery. So, no worries there. When I tried all audio systems, I had exactly the same thinking. HiFi was best value for money. Basic system was unacceptable. HK was too expensive for how it sounds. |
07-26-2021, 02:40 AM | #128 |
Rep 1
Greetings! I'm from Malaysia and I have a BMW 320i Sport (G20) with iDrive 6 and basic sound system (6-speaker) with no AMP or RAM modules in the trunk. I was made to understand that the headunit (NBT-EVO) drives all 6 speakers (4 mids, 2 subwoofers) directly.
Question: Which MATCH amplifier (UP 7BMW, UP 7DSP, etc.) and cable harness is compatible for my vehicle? Audiotec Fischer website listed cable harness "PP-BMW 1.7RAM" to be compatible with G20, however, description states that it's for BMW with RAM module. |
07-26-2021, 09:38 AM | #129 | |
Rep 2,180
There is no UP-7BMW harness yet for either of those G20 OEM HU, only for the RAM. |
07-27-2021, 10:32 PM | #130 |
Rep 6
Wrong harness?
Been following the thread for months and finally got the Match 7DSP along with the associated cable for the RAM. But my excitement died when the harness would not fit into the RAM side. Not sure what is going on except maybe my version of 2019 X5 (built in 12/18) has a different RAM unit that makes the entire solution useless. Anyone seen this before? I believe I have the HK audio version.
Appreciate the feedback and ideas. Best. S. |
07-28-2021, 12:17 AM | #131 | |
Rep 425
