09-02-2020, 01:41 PM | #23 | |
Rep 360
Thank you. I think I am going to stick with the 19s that come as standard on the M340i and add some Eibach Spacers and lowering springs from AC. Lorcan, may I ask, what sort of drop do you recommend on my vehicle if I was to use the AC springs? |
09-02-2020, 02:39 PM | #24 |
Rep 2,960
For reference here are stock wheels/tires with a 13mm spacer in the rear and a 15mm spacer in the front / lowered about 1"(25mm) with dinan springs
09-02-2020, 04:35 PM | #25 | |
Rep 360
Also are your wheels 19 inch or 18 inch? The stock wheel/tires on the UK M340i are the 792m. Not sure which wheels you have on? |
09-03-2020, 03:08 AM | #26 |
Rep 258
https://www.ac-schnitzer.de/en/bmw/3...estouring.html
If you would like to maintain the warranty, then ACS springs are the only option I'm aware of. Check the above link to see many images of how the car will sit. You'll also find all the different options depending on your model. For info - you cannot determine the ride height. This is pre determined by the maker of the springs. |
09-03-2020, 11:28 AM | #27 | |
Rep 2,960
Yes
Thanks! Yes it came out exactly the way I had in mind - I know not low enough for many but just right for me :-) Quote:
ps- couple more pics here in this thread I started - hope this helped :-) https://g20.bimmerpost.com/forums/sh....php?t=1734524 |
09-03-2020, 02:37 PM | #28 | |
Rep 360
Don76172.00 |
09-04-2020, 09:36 AM | #29 |
The artist formerly known as AC Schnitzer UK
3610
Rep 4,518
09-08-2020, 06:57 AM | #32 |
Rep 360
01-06-2021, 04:57 PM | #34 | |
Rep 25
Ac-Schnitzer doesn't produce anything, they don't have any factory and just fine-tune products from others. The difference between the cheaper Eibach and the more expensive ACS isn't justifyied by any performance improvement unless you are a professional driver driving in a circuit. In terms of warranty you have the same protection mounting Eibach spending much less than AC-Schneitzer. Last edited by dinocorse; 01-06-2021 at 05:19 PM.. |
